查看: 1717|回复: 4
[提问] 获取点的坐标
发表于 2022-7-21 10:26:34 | 显示全部楼层 |阅读模式
请问各位大神,有没有好的方法获取图纸里面点对象acdbpoint的坐标(vla-get-objectname Gobj)是AcDbPoint,如何获取Gobj的坐标
发表于 2022-7-21 12:08:25 | 显示全部楼层
10组码或者获取Coordinates
ForYang + 1 赞一个!
 楼主| 发表于 2022-7-21 18:33:43 | 显示全部楼层
d1742647821 发表于 2022-7-21 12:08
10组码或者获取Coordinates
嗯,用vla-get-Coordinates比较好,之前用vla-get-Coordinate一直报错,谢谢
发表于 2022-7-21 21:06:47 | 显示全部楼层
自带的帮助也坑,帮助里边Point object 确实有Coordinate属性,但实际上没有,只有Coordinates属性
;特性值:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00c2db8c>
;   Coordinates = (145.572 65.4109 0.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0646bbc4>
;   Handle (RO) = "4B1"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 17de7304>
;   Layer = "0"
;   Linetype = "CONTINUOUS"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 2130176520
;   ObjectName (RO) = "AcDbPoint"
;   OwnerID (RO) = 2130169024
;   PlotStyleName = "ByLayer"
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 17de7120>
;   Visible = -1
 楼主| 发表于 2022-7-22 11:26:55 | 显示全部楼层
是的,我就是用来Coordinate后一直报错,就没尝试后面的,应该列举出来看看的
GMT+8, 2025-5-15 13:35 , Processed in 0.185366 second(s), 26 queries , Gzip On.
