自己也是抄抄改改的小白,其中的函数出处不记得来自哪了,总之感谢乐于分享的前辈们
有需求的自取之
如果出错的话请先看看自己有没有E盘
 - (DEFUN C:44 (/ aa)
- (setq aa (car(entsel "\n选择多段线: ")))
- (getpt aa)
- (dcfc ptlst)
- (SET-CLIP-STRING wjyh1)
- (princ)
- ;;获取坐标函数
- (defun getpt(ss)
- (setq ptlst (vl-remove-if 'not (mapcar '(lambda (x) (if (= (car x) 10) (cdr x))) (entget ss))))
- ;;把坐标值写入E盘的“坐标表值.txt”里
- (defun dcfc (ptlst / wjmdz file1 n JXY1 xy X1 y1 TX1 Ty1 TXY J1 JXY JXY1)
- (setq wjmdz (strcat "e:/坐标表值.txt"))
- (setq file1 (open wjmdz "w"))
- (setq n 0)
- (setq JXY1 (strcat ""))
- (repeat (length ptlst)
- (setq xy (nth n ptlst))
- (setq X1 (RTOS (cadr xy) 2 2)) ;每一组坐标依次求出X的字符
- (setq y1 (RTOS (car xy) 2 2)) ;每一组坐标依次求出Y的字符
- (setq TX1 (strcat X1 "\t"))
- (setq Ty1 (strcat Y1 "\n"))
- (setq TXY (strcat TX1 Ty1))
- (setq n (+ n 1))
- (setq J1 (strcat "J" (itoa n) "\t"))
- (setq JXY (strcat J1 TXY))
- (setq JXY1 (strcat JXY1 JXY))
- (setq wjyh1 JXY1)
- (write-line wjyh1 file1)
- (alert wjyh1)
- (princ)
- (close file1)
- (princ)
- ;;;功能:向系统剪贴板写入文字
- (defun SET-CLIP-STRING (STR / HTML RESULT)
- (and (= (type STR) 'STR)
- (setq HTML (vlax-create-object "htmlfile"))
- (setq RESULT (vlax-invoke
- (vlax-get (vlax-get HTML 'PARENTWINDOW)
- 'CLIPBOARDDATA
- 'SETDATA
- "Text"
- STR
- (vlax-release-object HTML)
