查看: 1392|回复: 3
[提问] 如何获得图层真彩色
发表于 2022-8-1 11:27:55 来自手机 | 显示全部楼层 |阅读模式
目前图层为真彩色255,255,255,使用vla-gei-color和tblobjname获得的是7号色
发表于 2022-8-1 11:51:26 | 显示全部楼层
highflybird大师写的
;;;下面的是几个简单的颜色函数
;;;把truecolordlg
;;;420构成的数值返回RGB列表
(defun Number->RGB (color)
  (list        (lsh color -16)
        (lsh (lsh color 16) -24)
        (lsh (lsh color 24) -24)
;;;把truecolordlg
;;;420构成的数值返回RGB列表.
(defun RGB->Number (R G B)
  (+ (lsh R 16) (lsh G 8) B)
;;;RGB转化成索引号
(defun RGB->Index (ColorObj r g b /)
  (if (and (equal 0 r 10) (equal 0 g 10) (equal 0 b 10))
    0
      (vla-setRGB ColorObj r g b)
      (vla-get-ColorIndex ColorObj)
;;;索引号转化成RGB
(defun Index->RGB (ColorObj ci /)
  (vla-put-ColorIndex ColorObj ci)
  (list        (vla-get-red ColorObj)
        (vla-get-green ColorObj)
        (vla-get-blue ColorObj)
发表于 2022-8-1 16:57:13 | 显示全部楼层
  1. ;;;lay是已经获取的layer对象
  2. (setq cor (vla-get-TrueColor lay))    ;;;获取真彩对象
  3. (setq Blue_cor (vla-get-Blue cor))    ;;;蓝色
  4. (setq Green_cor (vla-get-Green cor))  ;;;绿色
  5. (setq Red_cor (vla-get-Red cor))      ;;;红色
发表于 2022-8-1 20:09:43 | 显示全部楼层
直接获取
  1. (setq Tcolor(vlax-get-property(vlax-invoke-method *layers 'item"0")'TrueColor))
  2. (mapcar'(lambda(x)(vlax-get-property Tcolor x))'(Red Green Blue))
GMT+8, 2025-5-15 13:49 , Processed in 0.161556 second(s), 25 queries , Gzip On.
