当前代码暂时支持 字符串,实数 整数 ,图元,图元对象,选择集等。
原理说明:根据错误提示,用 arg0 arg1 ..逐步增加参数,直到参数个数满足函数要求。
再根据错误提示,参数修改参数类型。
最终通过探测时,返回函数及参数类型。
需要更多错误提示信息,以进行改进。期待您的提交。
持续更新中 最终源码见: https://gitee.com/atlisp/atlisp- ... c/ext/probe-fun.lsp
也欢迎到上面的源码网址回复 提交错误信息,我可以更快看到。
说明:本代码所调用的函数均在 @lisp函数库中,请自行查找。
也可以安装@lisp核心,可以自动调用需要的函数。
TODO: 成功后还可以尝试多加个参数进行可变参数的测试。
 - (defun ext:probe-fun (fun / *error* args iter iter-depth)
- "探测函数的参数个数(最小)及参数类型。"
- "expr or nil"
- "(ext:probe-fun 'boole)"
- (setq args '())
- (setq iter-depth 0)
- (setq str "string"
- intnum (fix 5)
- num 3.14
- ent (entity:make-circle '(0 0 0) 100)
- vlaobj (e2o ent)
- ss (ssadd ent)
- pt '(1 1 0)
- (defun get-type (x)
- (cond
- ((listp x)
- (cond
- ((equal x '(1 1 0))
- 'point)
- (t 'lst)))
- (t (type x))
- (defun iter ()
- ;;(princ args)
- (setq iter-depth (1+ iter-depth))
- (if (and
- (vl-catch-all-error-p
- (setq errobj
- (vl-catch-all-apply
- fun
- (reverse args))))
- (setq errmsg (vl-catch-all-error-message errobj)))
- (if (< iter-depth 100)
- (cond
- ((wcmatch errmsg "*参数太少*")
- (setq args (cons (read (strcat "arg" (itoa (length args)))) args))
- (iter))
- ((wcmatch errmsg "参数类型错误*")
- (@:log "INFO" errmsg)
- (setq typeerr (string:to-list errmsg " "))
- (@:log "INFO" (vl-prin1-to-string typeerr))
- (cond
- ((wcmatch (cadr typeerr) "stringp*")
- (setq args (subst str (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "listp*")
- (setq args (subst '(L I S T) (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "numberp*")
- (setq args (subst num (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "fixnump*")
- (setq args (subst intnum (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "lselsetp*")
- (setq args (subst ss (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "lentity*")
- (setq args (subst ent (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "VLA-OBJECT*")
- (setq args (subst vlaobj (read (last typeerr)) args)))
- ((wcmatch (cadr typeerr) "二维/三维点*")
- (setq args (subst pt (read (last typeerr)) args)))
- ;; TODO 参数类型错误扩展
- (iter))
- ((wcmatch errmsg "no function definition*")
- (setq args (subst 'princ (read (caddr typeerr)) args))
- (iter))
- (t
- (princ errmsg)
- (princ " near completed \n")
- (cons fun (mapcar 'get-type (reverse args)))
- (progn
- (princ "probe completed!\n")
- (iter)
