查看: 1157|回复: 4
[提问] 谁会lisp, 请教,lisp 修改一个线段的 startpoint 为点(0,0,0) 怎么写?
发表于 2022-8-31 17:06:50 | 显示全部楼层 |阅读模式
发表于 2022-8-31 17:31:06 | 显示全部楼层
(vlax-3d-point '(0 0 0))
(vlax-put obj 'StartPoint '(0 0 0))
;;直线
(vlax-put-property (vlax-ename->vla-object(car(entsel))) 'StartPoint (vlax-3d-point '(0 0 0)))
(vla-put-StartPoint (vlax-ename->vla-object(car(entsel))) (vlax-3d-point '(0 0 0)))
;;多段线
(vla-put-ControlPoints obj p)
发表于 2022-8-31 22:41:00 | 显示全部楼层
黄老,直线的好看懂,多段线的可否具体点,没成功。
发表于 2022-8-31 23:28:50 | 显示全部楼层
;多段线
(vla-put-Coordinates ven(vlax-make-variant(vlax-safearray-fill(vlax-make-safearray vlax-vbdouble(cons 0 (1- (length (setq lst2(append '(0 0)(cddr (vlax-safearray->list(vlax-variant-value(vla-get-Coordinates (setq ven(vlax-ename->vla-object(car(entsel)))) ))))))))))lst2)))
发表于 2023-11-14 16:36:44 | 显示全部楼层
真牛逼,还有这么多种方法。
GMT+8, 2025-5-14 06:22 , Processed in 0.161963 second(s), 26 queries , Gzip On.
