查看: 1472|回复: 6
[源码] 俺是小白,谁能帮忙把统计的长度单位毫米为米
发表于 2022-9-5 14:09:02 | 显示全部楼层 |阅读模式
1明经币
附件: 您需要 登录 才可以下载或查看,没有账号?注册
发表于 2022-9-5 14:09:03 | 显示全部楼层
  1. (defun c:zz ()
  2.   "统计线段长度"
  3.   (if (and (setq SS (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
  4.            (setq pt (getpoint "\n点取标注点:"))
  5.       )
  6.     (progn
  7.       (setq i  -1
  8.             ll 0
  9.       )
  10.       (while (setq s1 (ssname ss (setq i (1+ i))))
  11.         (setq l1 (vlax-curve-getdistatparam s1 (vlax-curve-getendparam s1))
  12.               ll (+ ll (* l1 1e-3))
  13.         )
  14.       )
  15.       (setq ll (rtos ll 2 3)
  16.             tx (strcat "周长=" ll "m")
  17.             nn (itoa (sslength SS))
  18.       )
  19.       (command "text" "mc" pt 55 0 tx)
  20.       (princ (strcat "\n共选择 " nn " 条线段. 线段总长: " ll))
  21.     )
  22.   )
  23.   (princ)
  24. )
发表于 2022-9-5 14:42:35 | 显示全部楼层
(defun C:cd (/ CURVE TLEN SS N SUMLEN)
(vl-load-com)
  (setqSUMLEN 0)
  (setq SS(ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
  (setq N 0)
  (repeat(sslength SS)
    (setqCURVE (vlax-ename->vla-object (ssname SS N)))
    (setqTLEN (vlax-curve-getdistatparam
CURVE
(vlax-curve-getendparam CURVE)
    (setqSUMLEN (+ SUMLEN TLEN))
    (setq N(1+ N))
  (print(strcat "总长度:" (rtos SUMLEN 2 5)))
试试看是不是这样
发表于 2022-9-5 22:12:49 | 显示全部楼层
xyp1964厉害,值得学习
 楼主| 发表于 2022-9-6 20:53:35 | 显示全部楼层
song宋_74729 发表于 2022-9-5 14:42
(defun C:cd (/ CURVE TLEN SS N SUMLEN)  (vl-load-com)   (setqSUMLEN 0)   (setq SS(ssget '((0 . "CIRC ...
谢谢你,xyp1964已经回答了哈
发表于 2022-9-9 12:00:47 | 显示全部楼层
向你学习!
可标注长度并分类统计及总长吗?谢谢!
 楼主| 发表于 2022-9-10 18:12:14 | 显示全部楼层
kfh 发表于 2022-9-9 12:00
向你学习!
可标注长度并分类统计及总长吗?谢谢!
不可以啊,你再看看论坛
GMT+8, 2025-5-15 11:08 , Processed in 0.179589 second(s), 24 queries , Gzip On.
