查看: 1518|回复: 3
请问这段代码中的错误是怎么回事,谢谢
发表于 2004-3-28 14:52:00 | 显示全部楼层 |阅读模式
目的是读取一条直线的起点终点坐标,调试的时候说类型不配,就是倒数第二句,谢谢指点。 Private Sub CommandButton1_Click()
Dim startPoint As Variant
Dim endPoint As Variant
Dim objName As String
Dim entry As AcadEntity
For Each entry In ThisDrawing.ModelSpace
objName = entry.ObjectName
If objName = "acadline" Then
startPoint = entry.startPoint
endPoint = entry.endPoint
End If
Next
MsgBox "This ellipse has a start point of " & startPoint(0) & ", " & startPoint(1) & ", " &_ startPoint(2) & " and an endpoint of " & endPoint(0) & ", " & endPoint(1) & ", " &_ endPoint(2), vbInformation, "StartPoint Example"
End Sub
发表于 2004-3-28 17:23:00 | 显示全部楼层
应该是If objName = "AcDbLine" Then吧。
 楼主| 发表于 2004-3-28 19:00:00 | 显示全部楼层
hehe~~那是有问题
不过 说这句也不对
MsgBox "This ellipse has a start point of " & startPoint(0) & ", " & startPoint(1) & ", " & startPoint(2) & " and an endpoint of " & endPoint(0) & ", " & endPoint(1) & ", " & endPoint(2), vbInformation, "StartPoint Example"
提示 类型不匹配
发表于 2004-3-28 19:42:00 | 显示全部楼层
类型不匹配是因为你的图形中没有直线吧。
所以显示部分应该也放到判断语句中。
GMT+8, 2025-5-25 16:35 , Processed in 0.178944 second(s), 23 queries , Gzip On.
