查看: 2026|回复: 2
[源码] CAD自动增减编号的代码及使用方法分享
发表于 2022-9-11 08:30:59 | 显示全部楼层 |阅读模式
使用方法
1、输入命令ATTDEF定义编号,标记为TAG,
2、创建块,名称为block
3、加载插件,窗口加载也可以,APPLOAD加载LSP文件也可以
4、输入VLIDE命令,新建一个文件,把代码粘贴进去,保存为LSP文件
5、有变动后,需要重生成模型
;;—————–=={ AutoLabel Attributes }==—————;;
;;  Automatically labels a specific attribute in a set of     ;;
;;  blocks, renumbering if blocks are added, copied or        ;;
;;  erased.                                                   ;;
;;  Author: Lee Mac, Copyright ?2011 – www.lee-mac.com       ;;
;;  Version 1.0    –    14-09-2011                            ;;
;;                         Settings                           ;;
;; [Note: Block names and Attribute Tags are *not* case-sensitive]
(setq *blockname* “block”  ;; Name of Block to be Updated
*blocktag*  “TAG”    ;; Attribute Tag to be Updated
;;                      Main Program                          ;;
(defun ObjectReactorCallback:RenumberBlocks ( object reactor params )
(setq *reactor* reactor)
(vlr-command-reactor “temp” ‘((:vlr-commandended . CommandReactorCallback:RenumberBlocks)))
(vlr-remove  reactor)
(defun CommandReactorCallback:RenumberBlocks ( reactor params / e f i l n s )
(if reactor (vlr-remove reactor))
(if
(and
(not *undoflag*)
(setq s (ssget “_X” *filter*))
(setq n 0)
(repeat (setq i (sslength s))
(if (eq *blockname*
(AutoLabel:EffectiveName
(setq o (vlax-ename->vla-object (setq e (ssname s (setq i (1- i))))))
(setq e (entnext e)
l (entget  e)
f nil
(while (and (not f) (eq “ATTRIB” (cdr (assoc 0 l))))
(if (eq *blocktag*  (strcase (cdr (assoc 2 l))))
(setq f (entmod (subst (cons 1 (itoa (setq n (1+ n)))) (assoc 1 l) l)))
(setq e (entnext e)
l (entget  e)
(if (and *reactor* (not (member o (vlr-owners *reactor*))))
(vlr-owner-add *reactor* o)
(if *reactor*
(progn (vlr-add *reactor*) (setq *reactor* nil))
(defun CommandReactorCallback:UndoCheck ( reactor params )
(setq *undoflag* (wcmatch (strcase (car params)) “*U,*UNDO”))
(defun CommandReactorCallback:BlockInserted ( reactor params / e l )
(if
(and
(not *undoflag*)
(wcmatch (strcase (car params)) “*I,*INSERT,*EXECUTETOOL”)
(setq e (entlast))
(setq l (entget e))
(eq “INSERT” (cdr (assoc 0 l)))
(= 1 (cdr (assoc 66 l)))
(eq *blockname* (AutoLabel:EffectiveName (vlax-ename->vla-object e)))
(AutoLabel:GetNewNumber e)
(defun AutoLabel:GetNewNumber ( ent / e f i l n r s )
(if (setq s (ssget “_X” *filter*))
(setq n 0)
(if (eq *blockname*
(AutoLabel:Effectivename
(vlax-ename->vla-object (ssname s (setq i (1- i))))
(setq n (1+ n))
(setq e (entnext ent)
l (entget e)
(setq f (entmod (subst (cons 1 (itoa n)) (assoc 1 l) l)))
(setq e (entnext e)
l (entget  e)
(if
(setq r
(vl-some
(function
(lambda ( r ) (if (eq *reacdata* (vlr-data r)) r))
(cdar (vlr-reactors :vlr-object-reactor))
(vlr-owner-add r (vlax-ename->vla-object ent))
(defun AutoLabel:EffectiveName ( obj )
(strcase
(if (vlax-property-available-p obj ‘effectivename)
(vla-get-effectivename obj)
(vla-get-name obj)
;;                   Loading Expressions                      ;;
(vl-load-com)
(lambda ( / i s l o )
(setq
*blocktag*  (strcase *blocktag*)
*blockname* (strcase *blockname*)
*reacdata*  “AutoBlockLabel”
*reactor*   nil
*undoflag*  nil
(foreach r1 (vlr-reactors)
(foreach r2 (cdr r1)
(if (eq *reacdata* (vlr-data r2)) (vlr-remove r2))
(if
(setq s
(ssget “_X”
(setq *filter*
(list
‘(0 . “INSERT”)
‘(66 . 1)
(cons 2 (strcat “`*U*,” *blockname*))
(cons 410 (getvar ‘CTAB))
(if (eq *blockname*
(setq o (vlax-ename->vla-object (ssname s (setq i (1- i)))))
(setq l (cons o l))
(CommandReactorCallback:RenumberBlocks nil nil)
(vlr-object-reactor l *reacdata*
(list
(cons :vlr-erased   ‘ObjectReactorCallback:RenumberBlocks)
(cons :vlr-copied   ‘ObjectReactorCallback:RenumberBlocks)
(cons :vlr-unerased ‘ObjectReactorCallback:RenumberBlocks)
(vlr-command-reactor *reacdata*
(list
(cons :vlr-commandwillstart ‘CommandReactorCallback:UndoCheck)
(cons :vlr-commandended     ‘CommandReactorCallback:BlockInserted)
;;                         End of File                        ;;
GMT+8, 2025-5-15 11:08 , Processed in 0.168806 second(s), 26 queries , Gzip On.
