查看: 1268|回复: 11
[提问] 求助-帮忙改程序的对齐点
发表于 2022-10-16 12:55:14 | 显示全部楼层 |阅读模式
(defun c:hbtz (/ tzml filelst i x y pmax pmin zx ys dx dy cdy dwg fn fd)
  (vl-load-com)
  (defun browseforfolder (msg / shfolder path catchit)
    (setq shfolder (vlax-invoke-method (vlax-create-object "Shell.Application")
                                       'browseforfolder
                                       (vlax-get-property
                                                          (vlax-get-acad-object)
                                                          'hwnd
                                       ) msg 1
          catchit (vl-catch-all-apply '(lambda ()
                                         (setq shfolder
                                               (vlax-get-property shfolder
        'self
                                               path
        'path
    (if (vl-catch-all-error-p catchit)
      nil
      path
  (setq tzml (browseforfolder "选择文件路径" ))
  (if (/= (substr tzml (strlen tzml)) "\\")
    (setq tzml (strcat tzml "\\"))
  (setq filelst (vl-directory-files tzml "*.dwg" 1))
  (setq filelst (acad_strlsort filelst)
        i -1
        x 0
        y 0
        cdy 0
  (setq fn (getint " \n [每行文件数量] <1>: " ))
  (if (not fn)
    (setq fn 1)
  (setq fd (getreal " \n [文件间距] <100>: "))
  (if (not fd)
    (setq fd 100)
  (setvar "osmode" 0)
  (setvar "attreq" 0)
  (setvar "cmdecho" 0)
  (command "ucs" "")
  (while (setq dwg (nth (setq i (1+ i))
                        filelst
    (prompt (strcat "\n" dwg))
    (command "insert" (strcat tzml dwg) (list 0 0) "" "" "")
    (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'mi 'ma)
    (setq pmax (vlax-safearray->list ma)
          pmin (vlax-safearray->list mi)
    (setq zx (list (car pmin) (cadr pmin))
          ys (list (car pmax) (cadr pmax))
    (setq dwg (entlast))
    (command "rectangle" pmin pmax)
    (command "change" (entlast) "" "p" "C" "1" "")
    (command "move" dwg (entlast) "" (list (car zx) (cadr ys))
             (list x y)
    (setq dy (- (cadr ys) (cadr zx))
          dx (- (car ys) (car zx))
    (if (> dy cdy)
      (setq cdy dy)
    (if (= (rem (1+ i) fn) 0)
      (setq x 0
            y (- y cdy fd)
            cdy 0
      (setq x (+ x dx fd))
以上程序是论坛中借用别个大佬的程序,可以实现多图纸的合并,但合并后的图纸是采用每个图纸的左上角对齐的关系排布的,而且每个图框外围会额外增加一个线框,现在想实现合并后的图纸是以每个图框的左下角对齐,然后去掉每个图框额外增加的线框,请哪位高手指点下程序的更改;
发表于 2022-10-23 00:23:48 | 显示全部楼层
甜兮兮 发表于 2022-10-22 20:41
是的   能否改个线框自动偏移10MM的样子
  (vl-load-com)
        'browseforfolder
        (vlax-get-property
        'hwnd
        ) msg 1
        (setq shfolder
        'self
        path
        'path
      nil
      path
                i -1
                x 0
                y 0
                cdx 0
                cdy 0
  (if (not fn)
    (setq fn 1)
  (if (not fd)
    (setq fd 100)
  (setvar "osmode" 0)
  (setvar "attreq" 0)
  (command "ucs" "")
        filelst
    (setq
                        pmax (polar (polar (vlax-safearray->list ma) 0 100) (* pi 0.5) 100)
                        pmin (polar (polar (vlax-safearray->list mi) pi 100) (* pi 1.5) 100)
    (setq
    (command "move" dwg (entlast) "" zx (list x y))
    (setq
    (if (> dy cdy)
      (setq cdy dy)
      (setq
                                x 0
                                y (+ y cdy fd)
                                cdy 0
                ;(if (> dx cdx)
                ;    (setq cdx dx)
                ;  (if (= (rem (1+ i) fn) 0)
                ;    (setq
                ;                y 0
                ;                x (+ x cdx 2300);行间距
                ;                cdx 0
                ;    (setq y (- y dy fd))
发表于 2022-10-16 21:05:48 | 显示全部楼层
(if (> dy cdy)
      (setq cdy dy)
                (if (> dx cdx)
      (setq cdx dx)
      (setq
                                y 0
                                cdx 0
就后面这几个x y改一改换就变位置了
甜兮兮 + 1 谢谢大佬
 楼主| 发表于 2022-10-16 20:28:29 | 显示全部楼层
飞雪神光 发表于 2022-10-16 15:43
去掉包围框 左下到右上排列
感谢大佬啊!能排列按左到右,行的排列从上到下排列吗?如果能手动输入图纸排列的行距功能就更齐全了
发表于 2022-10-16 15:43:25 | 显示全部楼层
去掉包围框 左下到右上排列
发表于 2022-10-16 21:00:31 | 显示全部楼层
seamopan 发表于 2022-10-16 20:28
感谢大佬啊!能排列按左到右,行的排列从上到下排列吗?如果能手动输入图纸排列 ...
没看懂怎么排列
 楼主| 发表于 2022-10-16 21:41:58 | 显示全部楼层
就是从左往右排列,分行的话就是自上而下排列,往Y的负方向分行啊
 楼主| 发表于 2022-10-16 21:46:05 | 显示全部楼层
飞雪神光 发表于 2022-10-16 21:05
(if (> dy cdy)
      (setq cdy dy)
谢谢您!在你的提示下我已经改成想要的结果了
发表于 2022-10-21 11:13:46 | 显示全部楼层
飞雪神光   大佬可否改成自动线框偏移10mm那种效果 ,
发表于 2022-10-22 00:09:22 | 显示全部楼层
去掉包围框 左下到右上排列
大佬   有空可否看看怎么改?
发表于 2022-10-22 14:11:49 | 显示全部楼层
你是想保留线框是嘛
GMT+8, 2025-2-21 03:07 , Processed in 0.182827 second(s), 28 queries , Gzip On.
