查看: 3652|回复: 18
[提问] 如何快速实现多个多段线进行标注
发表于 2022-10-19 17:52:48 | 显示全部楼层 |阅读模式
25明经币
如图所示,我想让a的内容变成B的内容,标注部分只标注上面和左边,A的内容为封闭的多段线,该如何写这样的程序呢,求大佬解决
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
(defun c:NM (/ sc h d oldos oldla ss lst n obj minx miny maxx maxy pt1 ss pt2 pt3) (prompt "\n请选择要标注的对象") (setq ss (ssget)) (setq sc (getvar "dimscale")) (setq h (getvar "dimtxt")) (setq d (getvar "dimgap")) (setq oldos (getvar "osmode")) (setq oldla (getvar "clayer")) (command "_.UNDO" "BE") (setvar "cmdecho" 0) (setvar "osmode" 0) (repeat ...
发表于 2022-10-19 17:52:49 | 显示全部楼层
                                                        pt2 pt3)
        (setq ss (ssget))
  (setvar "osmode" 0)
  (repeat (setq n (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
    (vla-getboundingbox obj 'x 'y)
    (setq lst (cons (vlax-safearray->list y)
        (cons (vlax-safearray->list x) lst)
  (setq  minx (car (vl-sort (mapcar 'car lst) '<))
                miny (car (vl-sort (mapcar 'cadr lst) '<))
                maxx (car (vl-sort (mapcar 'car lst) '>))
                maxy (car (vl-sort (mapcar 'cadr lst) '>))
  (setq pt1 (list minx miny))
        (setq pt2 (list minx maxy))
  (setq pt3 (list maxx maxy))
  (command "dimlinear"
                pt1
                pt2
                (polar pt1 (+ (* -1.5 pi) (angle pt1 pt2)) (* sc (+ d h h h)))
                pt2
                pt3
                (polar pt2 (+ (* -1.5 pi) (angle pt2 pt3)) (* sc (+ d h h h)))
  (setvar "osmode" oldos)
  (setvar "clayer" oldla)
  (setvar "cmdecho" 1)
  (command "_.UNDO" "E")
  (prin1)
tigcat + 1 很给力!
发表于 2022-10-19 18:30:21 | 显示全部楼层
此版本支持多个多段线对象
                                                        pt2 pt3)
  (setvar "osmode" 0)
        (mapcar '(lambda(a / lst maxx maxy minx miny n obj pt1 pt2 pt3 ss)
                                                 (setq ss(ssadd a))
                                                         pt1
                                                         pt2
                                                         pt2
                                                         pt3
                (vl-remove-if-not '(lambda(x)(= 'ENAME (type x))) (mapcar 'cadr (ssnamex (ssget '((0 . "*LINE,*POLYLINE"))))))
cj52000 + 1 很好用!
 楼主| 发表于 2022-10-19 18:45:36 | 显示全部楼层
                                                        pt2 pt3)
大佬牛,谢谢,学到了
发表于 2022-10-19 21:22:11 | 显示全部楼层
xj6019 发表于 2022-10-19 18:30
此版本支持多个多段线对象
谢谢大师,很实用,工作中需要防呆,所以不能有两个长宽相同的多段线,长宽必须唯一,我在想如果在标注长宽的同时,能不能把长宽一样的多段线用相同的颜色来显示,这样一看就知道是哪两个或哪几个多段线是一样的,一目了然,请帮忙看看,谢谢 !
发表于 2022-10-19 21:36:24 | 显示全部楼层
cj52000 发表于 2022-10-19 21:22
谢谢大师,很实用,工作中需要防呆,所以不能有两个长宽相同的多段线,长宽必须唯一,我在想如果在标注长 ...
搞不了,学艺未精, 这玩意判断太费劲了
发表于 2022-10-20 08:33:20 | 显示全部楼层
向高手学习666
发表于 2022-10-21 11:22:41 | 显示全部楼层
此版本支持多个多段线对象
大佬尺寸偏移距离能设置吗?
发表于 2022-10-21 11:24:51 | 显示全部楼层
h806600727 发表于 2022-10-21 11:22
大佬尺寸偏移距离能设置吗?
sc 换成你喜欢的比例就可以改了
发表于 2022-10-21 13:23:00 | 显示全部楼层
xj6019 发表于 2022-10-21 11:24
sc 换成你喜欢的比例就可以改了
好的,谢谢大佬
GMT+8, 2025-4-23 21:28 , Processed in 0.158861 second(s), 25 queries , Gzip On.
