查看: 1592|回复: 7
[提问] 如何将下面的源码修改成下悬窗或左侧平开窗或者右侧平开窗?
发表于 2022-10-26 15:38:43 | 显示全部楼层 |阅读模式
;;;拾取内部点创建上悬窗
(defun C:tt5 (/ tc col oldc pt ee pts pa pc)
    (setvar "cmdecho" 0)
    (vl-load-com)
    (princ "\n拾取内部点创建上悬窗: ")
    (while (setq pt (getpoint))
      (setq ee (bpoly pt))
      (setq ss (entlast))
      (vla-offset (vlax-ename->vla-object ee) -50)
      (setq ee (entlast)
            pts (acet-ent-geomextents ee)          ; ET function
            pa (car pts)
            pc (cadr pts)
      (command "_.ERASE" ss "")
      (command "pline" "none" pa "none"
        (mapcar
          (function (lambda (a b) (/ (+ a b) 2)))
          pc
          (list (car pa) (cadr pc))
      "none"
       (list (car pc) (cadr pa))
    );while
发表于 2022-10-26 17:15:49 | 显示全部楼层
(defun C:tt5 (/ ee pt pts ss ys yx zs zx)
        (vl-load-com)
        (setq pt (getpoint "\n拾取内部点创建上悬窗:"))
        (while pt
                (setq ss (entlast))
                (setq
                        ee (entlast)
                        zx (car pts)
                        ys (cadr pts)
                        zs (list (car zx) (cadr ys))
                        yx (list (car ys) (cadr zx))
                (command "_.erase" ss "")
                (command "pline" "none" zx "none" (mapcar '(lambda (a b) (/ (+ a b) 2)) ys zs) "none" yx "")
                (command "pline" "none" zs "none" (mapcar '(lambda (a b) (/ (+ a b) 2)) zx yx) "none" ys "")
                (command "pline" "none" zs "none" (mapcar '(lambda (a b) (/ (+ a b) 2)) ys yx) "none" zx "")
                (command "pline" "none" ys "none" (mapcar '(lambda (a b) (/ (+ a b) 2)) zx zs) "none" yx "")
        );while
发表于 2022-10-26 15:58:19 | 显示全部楼层
门窗这些为什么要去这样画出来呢?做成图块,特别是参数化动态块,而且能附加各种属性,能存储与表达各种设计信息(其实就是BIM的思想)。
 楼主| 发表于 2022-10-26 16:27:10 | 显示全部楼层
e2002 发表于 2022-10-26 15:58
门窗这些为什么要去这样画出来呢?做成图块,特别是参数化动态块,而且能附加各种属性,能存储与表达各种设 ...
还停留在原始社会
发表于 2022-10-26 17:17:53 | 显示全部楼层
各有需求 有的人都不会做动态块
发表于 2022-10-26 17:26:44 | 显示全部楼层
用院长的9点函数
 楼主| 发表于 2022-10-26 18:29:01 | 显示全部楼层
        (vl-load-com)
谢谢出手----
发表于 2022-10-27 09:48:57 | 显示全部楼层
        (vl-load-com)
真是个热心的好人啊~
GMT+8, 2025-5-15 07:14 , Processed in 0.145098 second(s), 27 queries , Gzip On.
