查看: 1451|回复: 2
【delete】删除层内对象
发表于 2022-11-12 13:38:51 | 显示全部楼层 |阅读模式
最近接触到的几种删除对象的方法,这里以删除层内对象为例,分享给大家,也欢迎大佬补充完善。
01-首先,我们得有一个选择集:
  1. (setq ss (ssget "_x" (list '(8 . "0"))));选中0图层的所有对象
02-解锁图层,避免对象锁定无法删除
  1.     (setq LayObj (vlax-ename->vla-object (tblobjname "LAYER" "0")))
  2.     ;(vla-put-layeron  LayObj :vlax-true);打开
  3.     (vla-put-lock  LayObj :vlax-false);解锁
  4.     ;(vla-put-freeze  LayObj :vlax-false);解冻
注意:注释掉的部分可以相互替换
方法一:command / vl-cmdf
  1. (command "_ERASE" ss "")
  2. ;(vl-cmdf "_ERASE" ss "")
方法二:entdel / Vla
  1. (repeat (setq i (sslength ss))
  2.   (entdel (ssname ss (setq i (1- i))))
  3.   ;(vla-erase (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
  4.   ;(vla-delete (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
  5. )
方法二扩展:repeat也可以用while代替
  1. (setq i (sslength ss))
  2. (while (setq en (ssname ss (setq i (1- i))))
  3.   (entdel en )
  4.   ;(vla-erase (vlax-ename->vla-object en))
  5.   ;(vla-delete (vlax-ename->vla-object en))
  6. )
发表于 2022-11-13 01:29:15 | 显示全部楼层
感谢大佬分享,学习了
GMT+8, 2025-5-24 16:07 , Processed in 0.175876 second(s), 23 queries , Gzip On.
