- 积分
- 30714
- 明经币
- 个
- 注册时间
- 2013-1-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
查找替换,是经典功能,本坛很多,我也有,不是没有,展示下:
提不出全部源码,见谅。。。。
支持几乎所有含有 文字的实体类型,包括标注,块类,多行MTEXT等
注:还是走了弯路,因为我解决不了一大片MTEXT文字,取字符串和定位的问题,也是刚发帖求助了
http://bbs.mjtd.com/thread-186647-1-1.html?_dsign=34261847
如果能解决上述问题,代码将大大的不一样,速度也会快的很多,并且还不出BUG。
- ;;替换改字并换色---------------
- (defun c:chgtext (/ std ss os ns oldcho dcl_id name)
- (setq oldcho (getvar "cmdecho"))
- (setvar "cmdecho" 0)
- (setq std 1 os "" ns "")
- (while (> std 0)
- (setq dcl_id (load_dialog (th-dcl)))
- (new_dialog "replace" dcl_id)
- (set_tile "oldword" os)
- (set_tile "newword" ns)
- (action_tile "oldword" "(setq os (get_tile \"oldword\"))")
- (action_tile "newword" "(setq ns (get_tile \"newword\"))")
- (action_tile "pick_1" "(done_dialog 1)")
- (action_tile "pick_11" "(done_dialog 2)")
- (action_tile "accept" "(done_dialog 0)")
- (setq std (start_dialog))
- (slunloaddcl dcl_id)
- (cond
- ((= std 1)
- (setq name (car (entsel (slmsg "\n 点选旧字符串:" "\n 點選舊字符串:" "\n Click the old string:"))))
- (setq os (getstr name))
- ((= std 2)
- (setq name (car (entsel (slmsg "\n 点选新字符串:" "\n 點選新字符串:" "\n Click the new string:"))))
- (setq ns (getstr name))
- (princ (slmsg "\n 选择含有文字类实体:" "\n 選擇含有文字類實體:" "\n Select entities containing text:"))
- (while (setq ss (ssget ":S" '((0 . "ATTDEF,DIMENSION,TEXT,MTEXT,INSERT,TCH_ARROW,TCH_TEXT,TCH_DRAWINGNAME,TCH_MULTILEADER,TCH_ELEVATION,TCH_MTEXT,ATTRIB"))))
- (if (and ss (/= os "") (/= ns ""))
- (reptext ss os ns)
- (setvar "cmdecho" oldcho)
- (defun th-dcl (/ lst_str)
- (setq lst_str
- (cond
- ((= $Lgver 1)
- (list
- "replace:dialog {"
- "label = \" 替换含文字实体中指定子串\";"
- "initial_focus=oldword;"
- ":boxed_row{"
- "label=\"旧字符串:\";"
- ":edit_box {key = \"oldword\";edit_width = 25;allow_accept=true;}"
- ":button{label=\"<--点取+\";key=\"pick_1\";}"
- ":boxed_row{"
- "label=\"新字符串:\";"
- ":edit_box {key = \"newword\";edit_width = 25;allow_accept=true;}"
- ":button{label=\"<--点取+\";key=\"pick_11\";}"
- $okbt
- ((= $Lgver 2)
- (list
- "label = \" 替換含文字實體中指定子串\";"
- ":boxed_row{"
- "label=\"舊字符串:\";"
- ":button{label=\"<--點取+\";key=\"pick_1\";}"
- ":boxed_row{"
- ":button{label=\"<--點取+\";key=\"pick_11\";}"
- $okbt
- ((= $Lgver 3)
- (list
- "label = \"Replace the middle stator string of entities with text\";"
- ":boxed_row{"
- "label=\"Old String:\";"
- ":button{label=\"<--Pick+\";key=\"pick_1\";}"
- ":boxed_row{"
- "label=\"New String:\";"
- ":button{label=\"<--Pick+\";key=\"pick_11\";}"
- $okbt
- (dcl2lisp lst_str)
- ;;筛选选择集中文字,文字中字符 以旧换新-------【一级】---------
- ;; (reptext ss <要找的文字> <替换成的文字>)
- (defun reptext (ss oldch newch / enam p n tp etext txtln subln n1 schct newtext readch)
- (repeat (setq n (sslength ss))
- (setq enam (ssname ss (setq n (1- n))) tp (dxf1 enam 0))
- (cond
- ((or (= tp "MTEXT") (= tp "TCH_MTEXT"))
- (sl-mtext-old-new enam oldch newch)
- (ssdel enam ss)
- ((= tp "INSERT")
- (blk-reptext enam oldch newch)
- (ssdel enam ss)
- (if (setq p (sslength ss) subln (strlen oldch))
- (progn
- (setq n 0 n1 0)
- (while (< n p)
- (if (setq etext (getstr (setq enam (ssname ss n))))
- (progn
- (setq txtln (strlen etext) schct 1 newtext "")
- (while (<= schct txtln)
- (setq newtext
- (strcat newtext
- (if (= (setq readch (substr etext schct subln)) oldch)
- (setq n1 (1+ n1) schct (+ schct subln) newch newch)
- (progn
- (setq schct (1+ schct))
- (substr readch 1 1)
- (if (/= etext newtext)
- (chzi-enam enam newtext)
- (setq n (1+ n))
- ;;取实体字符串-----(一级)------
- (defun getstr (enam / e pt str en tp tp1 en2 obj lis)
- (setq e (entget enam) tp (dxf1 e 0) obj (en2obj enam))
- (cond
- ((member tp '("TEXT" "TCH_TEXT"))
- (setq str (dxf1 e 1))
- ((member tp '("MTEXT" "TCH_MTEXT"))
- (setq lis (str->lst (dxf1 e 1) ";"))
- (if (> (length lis) 1)
- (setq str (cadr lis))
- (setq str (car lis))
- ((= tp "DIMENSION")
- (setq str (vla-get-textoverride obj))
- (if (or (= str "") (wcmatch str "*<>*"))
- (setq str (rtos (vla-get-measurement obj) 2 (vla-get-toleranceprecision obj)))
- ((= tp "MULTILEADER")
- (setq str (dxf1 e 304))
- ((= tp "TCH_ARROW") ;天正箭头引注
- (setq str (vlax-get-property obj 'Text2))
- ((member tp '("ATTDEF" "TCH_MULTILEADER")) ;如果是属性字,则取“标记”为源文字 ;天正引出标注
- (setq str (dxf1 e 2))
- ((and (= tp "INSERT") (= (dxf1 e 66) 1)) ;;属性块 文字
- (setq en (entget (entnext enam)))
- (setq str (dxf1 en 1))
- ((and (= tp "INSERT") (= (dxf1 e 66) 0)) ; 块内文字
- (if (null pt) (setq pt (cadr (grread 5))))
- (if (not (setq en2 (car (nentselp pt))))
- (setq en2 enam)
- (setq tp1 (dxf1 en2 0))
- (if (member tp1 (list "TEXT" "MTEXT" "ATTRIB"))
- (setq str (vla-get-textstring (en2obj en2)))
- str
- ;MTEXT中字符以旧换新-----(一级)------
- (defun sl-mtext-old-new (enam oldch newch / e)
- (setq e (entlast))
- (command "EXPLODE" enam)
- (reptext (last_ent e) oldch newch)
- (setq enam (sl-ss-txt2mtext (last_ent e)))
- enam
- ;;块内实体文字,以旧换新---(一级)----
- ;(blk-reptext <块实体名> <要找的文字> <替换成的文字>) (setq enam (car(entsel)))
- ;;返回替换后的复原块 (blk-reptext (car(entsel)) "0" "1")
- (defun blk-reptext (enam oldch newch / nam e ss)
- (setq nam (dxf1 enam 2))
- (while (tblsearch "block" nam)
- (setq nam (strcat nam (slsjqs)))
- (vl-catch-all-apply 'exp-blk (list enam))
- (if (setq ss (last_ent e))
- (progn
- (reptext ss oldch newch) ;;(reptext ss "0" "1")
- (setq ss (last_ent e))
- (emkblk ss (ssmpt ss) nam) ;;作普通块
- (entlast)
- ;文字合并到 MTEXT-----(一级)-------
- ;返回合并后的MTEXT
- (defun sl-ss-txt2mtext (ss / e_lst n el box boxl l blst strl h h0 hn py st)
- (setq e_lst (sysvar '("textsize" "textstyle")) h0 0.5)
- (setq
- el (entget (ssname ss (setq n (1- n))))
- box (textbox (vl-remove (assoc 50 el) el))
- boxl (cons box boxl)
- l (+ (abs (caadr box)) (abs (cadadr box)))
- blst (cons l blst)
- strl (cons (list (dxf1 el 10) (dxf1 el 1)) strl)
- hn (dxf1 el 40)
- st (if (not st) (dxf1 el 7) st)
- (if (> hn h0) (setq h hn) (setq h h0))
- (setq h0 h)
- (sl:-erase ss)
- (setvar "textsize" h)
- (if (/= (getvar "textstyle") st) (setvar "textstyle" st))
- (setq strl
- (vl-sort strl
- '(lambda (e1 e2)
- (if (equal (cadar e1) (cadar e2) 0.00001)
- (< (caar e1) (caar e2))
- (> (cadar e1) (cadar e2))
- py (apply 'max (mapcar 'cadr (apply 'append boxl)))
- (vla-addmtext *Model-Space*
- (vlax-3d-point (list (caaar strl) (+ py (cadaar strl))))
- (apply 'max blst)
- (apply 'strcat (mapcar '(lambda (x) (strcat (last x) "\\P")) strl))
- (mapcar 'eval e_lst)
- (entlast) ;返回合并后MTEXT实体
以下为 信的文字选择集转MTEXT,这个比较好,存在的大缺憾就是垂直方向需要改写。
- ;单行文字选择集转多行文字----(一级)------
- ;ssText 文字选择集 fSpace 行距比例
- (defun sl-ss-txt2mtext (ssText fSpace / e_lst ptLeftTop fRecWidth Mats y lstText eText edata fHeight fWidth ang
- lst1 lstText1 e e1 e2 box lstReplace ename)
- (setq e_lst (sysvar '("TEXTSTYLE" "CLAYER")))
- (setq lstText (ss-enlst ssText))
- (setq ename (ssname ssText 0))
- (setq edata (entget ename))
- (command "UCS" "OB" ename)
- (setq lstText
- (mapcar
- '(lambda (eText / edata pt)
- (setq edata (entget eText))
- (setq pt (dxf1 edata 10))
- (trans pt 0 1)
- (list pt edata)
- lstText
- (setq lstText (vl-sort lstText '(lambda (e1 e2) (> (cadar e1) (cadar e2)))))
- (setq y (cadaar lstText))
- (foreach eText lstText
- (setq fHeight (dxf1 (cadr eText) 40))
- (if (< (abs (- y (cadar eText))) fHeight) ;同行
- (progn
- (setq lst1 (cons eText lst1))
- (setq y (cadar eText))
- (progn
- (setq lstText1 (cons lst1 lstText1)) ;加入
- (setq lst1 (list eText))
- (if lst1 (setq lstText1 (cons lst1 lstText1)))
- (setq lstText
- (mapcar
- '(lambda (lst1)
- (mapcar 'cadr (vl-sort lst1 '(lambda (e1 e2) (< (caar e1) (caar e2)))))
- lstText1
- (setq lstText (reverse lstText))
- (setq fRecWidth
- (apply
- 'max
- (mapcar
- '(lambda (e)
- (if (> (length e) 1)
- (apply
- (mapcar
- '(lambda (e1 / box)
- (setq box (textbox e1))
- (caadr box)
- e
- (caadr (textbox (car e)))
- lstText
- (setq fRecWidth (* fRecWidth 1.2) lst1 (caar lstText))
- (setq fHeight (dxf1 lst1 40))
- (setq ptLeftTop (dxf1 lst1 10))
- (setq ang (dxf1 lst1 50))
- (setq box (textbox lst1))
- (setq ptLeftTop
- (polar ptLeftTop ang
- (apply 'min
- (setq a
- (vl-remove nil
- (mapcar
- '(lambda (lst / str)
- (setq str (dxf1 lst 1))
- (cond
- ((wcmatch str " *, *") 0)
- ((> (ascii (substr str 1 1)) 128)
- 0
- (T
- (caar (textbox lst))
- (mapcar 'car lstText)
- (setq ptLeftTop (polar ptLeftTop (+ ang pi2) (apply 'max (mapcar '(lambda (e) (dxf1 e 40)) (car lstText)))))
- (sl:-erase ssText)
- (setvar 'clayer (dxf1 lst1 8))
- (setvar 'TEXTSTYLE (dxf1 lst1 7))
- (setq fWidth (dxf1 (tblsearch "Style" (getvar 'textstyle)) 41))
- (setq sText
- (mapcar
- '(lambda (e)
- (apply
- 'strcat
- (mapcar
- '(lambda
- (e1 / str h w c pre)
- (setq str (dxf1 e1 1))
- (setq h (dxf1 e1 40))
- (setq w (dxf1 e1 41))
- (setq c (dxf1 e1 62))
- (setq str (t-string-subst "\\{" "{" str))
- (setq str (t-string-subst "\\}" "}" str))
- (setq pre "")
- (if (not (equal h fHeight)) (setq pre (strcat pre "\\H" (rtos (/ h fHeight) 2 1) "x;")))
- (if (not (equal w fWidth)) (setq pre (strcat pre "\\W" (rtos w 2 1) ";")))
- (if c (setq pre (strcat pre "\\C" (rtos c 2 0) ";")))
- (if (/= pre "")
- (setq str (strcat "{" pre str "}"))
- str
- e
- lstText
- (setq sText (sl
ist->String sText "\\P")) - (command "UCS" "
") - (Make-MText sText ptLeftTop fRecWidth fHeight fSpace ang 1 1)
以下为我改写信的代码,目的减小码子,但调试发现BUG,目前没有找到问题之所在
- ;文字选择集转多行文字----(一级)------
- (defun sl-ss-txt2mtext (ssText fSpace / e_lst y ptLeftTop fRecWidth lstText sText eText edata fHeight fWidth ang lst1 lstText1 e e1 e2 plis ename)
- (setq plis (ss9pt ssText nil))
- (setq ptLeftTop (nth 6 plis) fRecWidth (distance (car plis) (caddr plis)))
- (setq lstText
- (mapcar
- (setq pt (trans (dxf1 edata 10) 0 1))
- (list pt edata)
- lstText
- (progn
- (progn
- (setq lstText
- (mapcar
- '(lambda (lst1)
- lstText1
- (setq lst1 (caar lstText))
- (setq sText
- (mapcar
- '(lambda (e)
- (apply
- 'strcat
- (mapcar
- '(lambda
- (setq pre "")
- (if (/= pre "")
- str
- e
- lstText
- (setq sText (sl
链接:https://pan.baidu.com/s/1RA53nRQM567jTvy12MZRtA
提取码:n3jd
