- 积分
- 31011
- 明经币
- 个
- 注册时间
- 2013-1-25
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
- ;;图元合并删除、合并----【开始】------
- (defun c:duprem (/ ss)
- (setq ss (ssget '((0 . "LINE,*POLYLINE,TEXT,MTEXT,CIRCLE,ARC,INSERT"))))
- (ssduppe ss)
- ;;(删除选择集中重叠的线、多段线、圆、圆弧、块、文字)----(一级)----
- (defun ssduppe (ss / e name lis lw ly cl tp p1 p2 e_lst n slinearc spline scircle sinsert stxt)
- (setq e_lst (sysvar '("OSMODE" "CMDECHO")))
- (setvar "OSMODE" 0)
- (setvar "CMDECHO" 0)
- (_undo1)
- (command "_.ucs" "")
- (setq slinearc (ssadd) spline (ssadd) scircle (ssadd) sinsert (ssadd) stxt (ssadd))
- (repeat (setq n (sslength ss))
- (setq name (ssname ss (setq n (1- n))) tp (dxf1 name 0) ly (dxf1 name 8) cl (ss-getcolor name) lw (linwind name))
- (cond
- ((or (= tp "LINE") (= tp "ARC"))
- (ssadd name slinearc)
- ((and (= tp "LWPOLYLINE") (= lw 0) (= (dxf1 name 90) 2)) ;;0宽度两点多段线
- (setq p1 (vlax-curve-getstartpoint (en2obj name))
- p2 (vlax-curve-getendpoint (en2obj name))
- (entdel name) (ssdel name ss)
- (fy_lineformat (makeline p1 p2) nil nil nil nil)
- (ssadd (entlast) slinearc) ;转直线集处理
- ((and (= tp "LWPOLYLINE") (= lw 0) (> (dxf1 name 90) 2) ;;0宽度3点以上多段线
- (= (sl:pts-onLine (setq lis (order-pt (get-pl-pt name)))) t) ;共线
- (fy_lineformat (makeline (car lis) (last lis)) nil nil nil nil)
- (ssadd (entlast) slinearc);转直线集处理
- (= (sl:pts-onLine (get-pl-pt name)) nil) ;不共线
- (ssadd name spline) ;转多段线集处理
- ((and (= tp "LWPOLYLINE") (> lw 0)) ;有宽度二维多段线
- ((and (= tp "POLYLINE") (> lw 0));有宽度三维多段线
- (setq lis (get-pl-pt name))
- (if (= (dxf1 name 70) 8) ;不闭合
- (slch:lwpolyline lis nil lw ly cl nil)
- (slch:lwpolyline lis t lw ly cl nil)
- (entdel name)
- (ssadd (entlast) spline) ;转多段线集处理
- ((and (= tp "POLYLINE") (= lw 0));0宽度三维多段线
- (repeat (setq i (1- (length lis)))
- (fy_lineformat (makeline (nth i lis) (nth (1- i) lis)) nil nil nil nil)
- ((= tp "CIRCLE")
- (ssadd name scircle)
- ((= tp "INSERT")
- (ssadd name sinsert)
- ((or (= tp "TEXT") (= tp "MTEXT"))
- (ssadd name stxt)
- (if (> (sslength slinearc) 1) (vl-catch-all-apply 'undup (list slinearc))) ;直线 弧
- (if (> (sslength spline) 1) (vl-catch-all-apply 'unduppl (list spline))) ;多段线
- (if (> (sslength scircle) 1) (undup-cir scircle)) ;圆
- (if (> (sslength stxt) 1) (deladtxt stxt)) ;文字
- (if (> (sslength sinsert) 1) (congfukuai sinsert)) ;块
- (mapcar 'eval e_lst)
- (_undo2)
- ;;删除重复的线LINE 弧 CIR----(一级)-------
- ;;s:选择集
- (defun undup (s / ang k a a1 a2 sty sline sarc n enam tp e_lst)
- (defun t-ang (ang k)
- (rem (+ 2pi ang) k)
- ;;判断a是否在 a1至a2两点连线上----
- (defun on_ent (a a1 a2 sty)
- (if (= sty "line")
- (equal (+ (distance a1 a) (distance a a2)) (distance a1 a2) 0.01)
- (if (> a2 a1) (>= a2 a a1) (or (<= a a2) (>= a a1)))
- ;;s:选择集 sty:实体类型字符串"line""arc"
- (defun slundup (s sty / nm m n ss nam enam1 enam2 spt1 ept1 cpt1 r1 r2 spt2 ept2 cpt2 ptlis d1 d2 d3 d4)
- (setq nm 0)
- (if (= sty "line") ;;删除长度小于 0.01的直线
- (repeat (setq n (sslength s))
- (setq enam1 (ssname s (setq n (1- n))))
- (setq spt1 (dxf1 enam1 10) ept1 (dxf1 enam1 11))
- (if (<= (distance spt1 ept1) 0.01)
- (progn (ssdel enam1 s) (entdel enam1) (setq nm (1+ nm)))
- (repeat (setq n (sslength s)) ;合并重复线、弧
- (setq spt1 (t-ang (dxf1 enam1 50) 2pi)
- ept1 (t-ang (dxf1 enam1 51) 2pi)
- cpt1 (dxf1 enam1 10)
- r1 (dxf1 enam1 40)
- (if
- (setq ss
- (ssget
- "CP"
- (list
- (polar spt1 (angle ept1 spt1) (* SLBL 0.2))
- (polar ept1 (- (angle spt1 ept1) pi4) (* SLBL 0.25))
- (polar ept1 (+ (angle spt1 ept1) pi4) (* SLBL 0.25))
- '((0 . "LINE"))
- (ssget "X" (list (cons 0 "ARC") (cons 10 cpt1) (cons 40 r1)))
- (progn
- (ssdel enam1 ss) ;;次选择集先删除主线
- (repeat (setq m (sslength ss))
- (setq nam (ssname ss (setq m (1- m))))
- (if (not (ssmemb nam s)) (ssdel nam ss)) ;;如果主选择集都没有,选择集不交差,删除次选择集实体
- ) ;以上确保 主集S 次集 SS 正确
- (setq enam2 (ssname ss (setq m (1- m))))
- (setq spt2 (dxf1 enam2 10) ept2 (dxf1 enam2 11))
- (setq spt2 (t-ang (dxf1 enam2 50) 2pi)
- ept2 (t-ang (dxf1 enam2 51) 2pi)
- cpt2 (dxf1 enam2 10)
- r2 (dxf1 enam2 40)
- (cond
- ((and (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty)) ;;次线落在主线上
- (entdel enam2) ;;删除次线
- ((and (on_ent spt1 spt2 ept2 sty) (on_ent ept1 spt2 ept2 sty)) ;;主线落在次线上
- (entdel enam1) ;;删除主线
- (setq enam1 enam2 spt1 spt2 ept1 ept2) ;;次线转为主线
- (if (= sty "arc")
- (setq cpt1 cpt2 r1 r2)
- ((and
- (if (= sty "line") (equal (angle spt1 ept1) (angle spt2 ept2) 0.001)) ;;平行
- (or (on_ent spt2 spt1 ept1 sty) (on_ent ept2 spt1 ept1 sty)) ;;且一点在线上
- (entdel enam2) ;删除次线
- (progn
- (if (on_ent spt2 spt1 ept1 sty)
- (setq spt2 ept2)
- (if (> (distance spt1 spt2) (distance ept1 spt2))
- (progn (sl_subupd enam1 11 spt2) (setq ept1 spt2))
- (progn (sl_subupd enam1 10 spt2) (setq spt1 spt2))
- (progn (sl_subupd enam1 51 ept2) (setq ept1 ept2))
- (progn (sl_subupd enam1 50 spt2) (setq spt1 spt2))
- ((and
- (= sty "line")
- (= (sl:pts-onLine (list spt1 ept1 spt2 ept2)) t) ;共线判断
- (setq d1 (distance spt1 spt2))
- (setq d2 (distance spt1 ept2))
- (setq d3 (distance ept1 spt2))
- (setq d4 (distance ept1 ept2))
- (if (and (< (min d1 d2 d3 d4) (* SLBL 0.1)))
- (progn
- (setq ptlis (order-pt (list spt1 ept1 spt2 ept2)))
- (sl_subupd enam1 10 (car ptlis))
- (setq spt1 (car ptlis)) ;下次扩展延伸选择用
- (sl_subupd enam1 11 (last ptlis))
- (setq ept1 (last ptlis)) ;下次扩展延伸选择用
- (T (setq nm (1- nm)))
- (setq nm (1+ nm))
- );end repeat
- (prompt
- (strcat
- (slmsg " 选到" " 選到" " Select")
- (itoa (sslength s))
- (slmsg "个" "個" "num")
- sty
- (slmsg "消去" "消去" "delete")
- (itoa nm)
- ;;主程序开始-------------
- (setq e_lst (sysvar '("osmode" "cmdecho")))
- (setvar "cmdecho" 0)
- (setq sline (ssadd) sarc (ssadd))
- (setq enam (ssname s (setq n (1- n))))
- (setq tp (dxf1 enam 0))
- (cond
- ((= tp "LINE")
- (ssadd enam sline)
- ((= tp "ARC")
- (ssadd enam sarc)
- (if (> (sslength sline) 1) (slundup sline "line"))
- (if (> (sslength sarc) 1) (slundup sarc "arc"))
- (princ)
- ;;删除重复的多段线、重合点、共线点------(一级)--------
- (defun unduppl (ss / num i j lst lstx lsty lstx1 lsty1 ress tp nam e)
- ;;删除完全重合----------
- (setq i 0 num (sslength ss) ress (ssadd)) ;初始化变量,设置i为1的原因是方便j取值
- (repeat (1- num) ;外循环开始,循环次数为多段线个数减1
- (setq lst (get-pl-pt (ssname ss i)))
- (setq lstx (mapcar 'car (vl-sort lst '(lambda (a b) (< (car a) (car b)))))) ;按照X坐标从小到大排序并提取X坐标组成表
- (setq lsty (mapcar 'cadr (vl-sort lst '(lambda (a b) (< (cadr a) (cadr b)))))) ;按照Y坐标从小到大排序并提取Y坐标组成表
- (setq i (1+ i))
- (setq j i) ;j的值为i
- (repeat (- num i) ;内循坏开始,循坏次数为多段线个数减去i
- (setq nam (ssname ss j))
- (setq lst1 (get-pl-pt nam))
- (setq lstx1 (mapcar 'car (vl-sort lst1 '(lambda (a b) (< (car a) (car b))))))
- (setq lsty1 (mapcar 'cadr (vl-sort lst1 '(lambda (a b) (< (cadr a) (cadr b))))))
- (if (and (equal lstx lstx1 1e-5) (equal lsty lsty1 1e-5)) ;对比两个X和两个Y的表看是否一致,一致就删除
- (ssadd nam ress)
- (setq j (1+ j))
- (if ress
- (progn
- (setq ss (ssdiff ss ress)) ;;差集
- (if (> (sslength ress) 0) (sl:-erase ress))
- (prompt
- (strcat
- (slmsg "||选到" "||選到" "||Select")
- (itoa num)
- (slmsg "条多段线,消去完全重合->" "條多段線,消去完全重合->" "num Polylines,Erase Full Coincidence->")
- (itoa (sslength ress))
- (setq e (entlast))
- (slexpline ss);;->出口,线型实体3点以上者,炸开单线集成,宽度不变
- (setq ss (last_ent e))
- ;;删除重合点、共线点-------
- (repeat (setq i (sslength ss))
- (setq nam (ssname ss (setq i (1- i))) tp (dxf1 nam 0))
- (cond
- ((= tp "LWPOLYLINE");;->出口,删除二维多段线重合点,共线点
- (x@-delvx nam nil nil)
- ((= tp "POLYLINE") ;;->出口,删除三维多段线重复点
- (dump2dPoly nam)
- ;;删除重块--------(一级)-------
- (defun congfukuai (ss / i pt10 sspt10 nam ssnam n ss1 ss88 ssn ssn1 u)
- (setq u 0 ss88 (ssadd))
- (repeat (sslength ss)
- (setq ssn (ssname ss u))
- (ssadd ssn ss88)
- (setq u (1+ u))
- (setq n 0 ss1 (ssadd))
- (setq ssn (ssname ss n))
- (setq pt10 (dxf1 ssn 10))
- (setq nam (dxf1 ssn 2))
- (setq i 0)
- (ssdel ssn ss88)
- (repeat (sslength ss88)
- (setq ssn1 (ssname ss88 i))
- (setq sspt10 (dxf1 ssn1 10))
- (setq ssnam (dxf1 ssn1 2))
- (if (and (< (distance pt10 sspt10) (* slbl 0.5)) (wcmatch nam ssnam))
- (ssadd ssn1 ss1)
- (setq i (1+ i))
- (setq n (1+ n))
- (setq n (sslength ss1))
- (sl:-erase ss1)
- (prompt
- (strcat
- (itoa (sslength ss))
- (slmsg "个图块,消去->" "個圖塊,消去->" "num blk,delete->")
- (rtos n 2 0)
- (slmsg "个重块!" "個重塊!" "num overlap blk!")
- ;;删除重叠文字------(一级)-------
- (defun deladtxt (ss / enam u ss88 n ss1 en_data dxfl dxf10 dxf101 dxf11 dxf40 dxf401 i)
- (setq enam (ssname ss u))
- (ssadd enam ss88)
- (setq u (1+ u))
- (setq enam (ssname ss n))
- (setq en_data (entget enam))
- (setq dxf10 (dxf1 en_data 10) dxf40 (dxf1 en_data 40) dxfl (dxf1 en_data 1))
- (ssdel enam ss88)
- (setq i 0)
- (setq en1 (ssname ss88 i))
- (setq en_data (entget en1))
- (setq dxf101 (dxf1 en_data 10) dxf401 (dxf1 en_data 40) dxf11 (dxf1 en_data 1))
- (if (and (equal dxf10 dxf101) (equal dxf40 dxf401) (= dxfl dxf11))
- (ssadd en1 ss1)
- (setq i (1+ i))
- (setq n (1+ n))
- (sl:-erase ss1)
- (prompt
- (strcat
- (slmsg "个文字,消去->" "個文字,消去->" "num txt,delete->")
- (rtos n 2 0)
- (slmsg "个重叠文字!" "個重疊文字!" "num overlap txt!")
- (princ)
- ;删除相同直径的圆(全图)-----(一级)------
- ;;s:circle 选择集
- (defun undup-cir (s / nm m n ss nam enam1 cpt1 r1 kk)
- (setq nm 0 kk (itoa (sslength s)))
- (setq cpt1 (dxf1 enam1 10) r1 (dxf1 enam1 40))
- (if (setq ss (ssget "x" (list (cons 0 "circle") (cons 10 cpt1) (cons 40 r1))))
- (progn
- (ssdel enam1 ss)
- (sl:-erase ss)
- (setq nm (+ nm (sslength ss)))
- (prompt
- (strcat
- (slmsg "\n 选到" "\n 選到" "\n Select")
- kk
- (slmsg "个圆" "個圓" "num circle")
- (slmsg "消去->" "消去->" "delete->")
- (itoa nm)
- ) ;;图元合并(删除图纸中重叠的线、圆、圆弧、块、文字)---【结束】-----
