查看: 10199|回复: 68
好函数不敢独享,73哥的判断矩形
发表于 2022-11-22 21:59:30 | 显示全部楼层 |阅读模式
  1. ;llsheng_73哥的代码贴上来,方便搜索
  2. (defun isrectang(e / p1 p2 p3 p4)
  3.   (and(=(vlax-curve-getendparam e)4)
  4.       (vl-every(function(lambda(x y)(set x(vlax-curve-getpointatparam e y))))'(p1 p2 p3 p4)'(0 1 2 3))
  5.       (equal(distance p1 p2)(distance p3 p4)1e-5)
  6.       (equal(distance p1 p4)(distance p2 p3)1e-5)
  7.       (equal(distance p1 p3)(distance p2 p4)1e-5))
  8.   )
还有哦
;;判断矩形
(defun isrectang(e / p1 p2 p3 p4);;;(二维、三维、一般)多段线图元或图元对象或点表是否为矩形
  (and(or(and(listp e)(listp(car p))(=(length e)4)(vl-every(function set)'(p1 p2 p3 p4)e))
             (vl-every(function(lambda(x y)(set x(vlax-curve-getpointatparam e y))))'(p1 p2 p3 p4)'(0 1 2 3))))
发表于 2022-11-23 09:42:00 | 显示全部楼层
  • ;多义线是否矩形-----(一级)-------
  • (defun fy-recp (e / lst p1 p2 p3 p4)
  •   (if
  •     (and
  •       (= (type e) 'ENAME)
  •       (or (= "LWPOLYLINE" (dxf1 e 0)) (= "POLYLINE" (dxf1 e 0)))
  •       (= (dxf1 e 90) 4)
  •       (= (dxf1 e 70) 1)
  •     (progn
  •       (setq lst (cdr (get-pl-pt e)))
  •       (setq p1 (car lst))
  •       (setq p2 (cadr lst))
  •       (setq p3 (caddr lst))
  •       (setq p4 (cadddr lst))
  •       (setq ang1 (angle p1 p2))
  •       (setq ang2 (angle p2 p3))
  •       (setq ang3 (angle p3 p4))
  •       (setq ang4 (angle p4 p1))
  •       (if (and
  •             (or (equal (abs (- ang1 ang2)) pi2 1e-8) (equal (abs (- ang1 ang2)) 3pi2 1e-8))
  •             (or (equal (abs (- ang2 ang3)) pi2 1e-8) (equal (abs (- ang2 ang3)) 3pi2 1e-8))
  •             (or (equal (abs (- ang3 ang4)) pi2 1e-8) (equal (abs (- ang3 ang4)) 3pi2 1e-8))
  •         T
  •         nil
  •     nil
发表于 2023-1-17 10:11:19 | 显示全部楼层
杀猪杀屁股,另外一种搞定方法,请举证推翻。
  1. (and
  2.         (setq curve(car(entsel "\n选择对象:")))
  3.         (= (vlax-curve-getEndParam curve) 4)
  4.         (vlax-curve-isClosed curve)
  5.         (setq d1 (vlax-curve-getDistAtParam curve 1))
  6.         (setq d2 (- (vlax-curve-getDistAtParam curve 2) d1))
  7.         (equal (vlax-curve-getArea curve) (* d1 d2) 1e-6);判断矩形面积公式是否成立
  8. )
发表于 2022-12-6 14:33:05 | 显示全部楼层
gzxl 发表于 2022-11-30 11:08
对角线判断是不是矩形好些
当时帮楼主搞的,先判定它是不是刚好4个点,然后用对边相等,对角线相等进行判定的
发表于 2022-11-22 22:14:19 | 显示全部楼层
谢谢分享,看看什么宝贝
发表于 2022-11-22 22:37:59 | 显示全部楼层
看看什么好宝贝
发表于 2022-11-22 22:51:56 | 显示全部楼层
矩形四个点呀,四个直角.
发表于 2022-11-22 23:58:33 | 显示全部楼层
谢谢分享,看看什么宝贝
发表于 2022-11-23 04:46:42 | 显示全部楼层
看看什么好宝贝
发表于 2022-11-23 08:00:16 | 显示全部楼层
看看什么东西
发表于 2022-11-23 08:08:47 | 显示全部楼层
什么判断矩形啊
发表于 2022-11-23 08:13:12 | 显示全部楼层
谢谢大佬分享!看看什么好东西!
发表于 2022-11-23 08:16:12 | 显示全部楼层
看看什么好宝贝
GMT+8, 2025-5-1 09:57 , Processed in 0.206942 second(s), 25 queries , Gzip On.
