查看: 1730|回复: 8
[讨论] 请教大家,如何让ssget函数多次选择生成图层.如下程序有问题,帮忙看看
发表于 2022-11-26 11:18:30 | 显示全部楼层 |阅读模式
;*************************************************************选中线框创建8块模板,原线保留
(defun c:ct2()
         (setq n -1)
         (princ "\n选择模板外形")
         (setq sg_name(ssget))
         (setq sl(sslength sg_name))
        (princ "\n选择模座外形")
        (setq sg_name1(ssget))
        (setq s2(sslength sg_name1))
        (repeat sl (setq n (+ n 1))
                    (setq es_name(ssname sg_name n))
;*****Create Layer "D01"创建模板虚拟框
         (command "copy" es_name  "" "0,0" "" )
         (setq el_name(entlast))
         (command "chprop" es_name "" "color" "9"  "ltype" "center" "layer" "D01"  "s" "5" "")
;*****Create Layer "D02"
         (command "chprop" es_name "" "layer" "D02" ""  )
;*****Create Layer "D03"
         (command "chprop" el_name "" "layer" "D03" "" )
;*****Create Layer "S01"
         (command "chprop" el_name "" "layer" "S01" "" )
;*****Create Layer "S02"
         (command "chprop" el_name  "" "layer" "S02" "" )
;*****Create Layer "P03"
         (command "chprop" el_name "" "layer" "P03" "" )
;*****Create Layer "P02"
         (command "chprop" el_name ""  "layer" "P02" "" )
;*****Create Layer "P01"创建模板虚拟框
         (command "chprop" el_name "" "color" "9"  "ltype" "center"  "layer" "P01"  "s" "5" "")
;*****Create Layer "P01、D01"
(repeat s2 (setq n (+ n 1))
                    (setq es_name1(ssname sg_name1 n))
         (command "copy" es_name1  "" "0,0" "" )
         (setq el_name1(entlast))
         (command "chprop" el_name1 "" "layer" "P01" "")
         (command "chprop" es_name1 "" "layer" "D01" "")
发表于 2022-11-26 15:19:38 | 显示全部楼层
dear sir,
opt 1.
  1.
  2. (setq lst'("0""1""2""3"))
  3.         (defun _layersel ( lst)
  4.                 (apply 'append (subst nil (list nil) (mapcar 'list lst)))
  5.                 ( foreach layer lst (ssadd (ssget "_A" (list (cons 8 layer))) ss))
  6.         )
oot.2
  1. (setq layerlist (list "0" "Layer1" "Layer2" "Layer3" "ABCD" "DEFG" "HIJK"))
  2.   (setq ll '((-4 . "OR>")))
  3.   ( foreach l layerlist
  4.         (setq ll (cons (cons 8 l) ll))
  5.   (setq ll (cons '(-4 . "<OR") ll))
  6.   (setq ss (ssget "X" ll))
opt.3
  1. (defun _strcat (layers delim)
  2.   (vl-string-right-trim
  3.     delim
  4.     (apply
  5.       'strcat
  6.       (mapcar (function (lambda (x) (strcat x delim))) layers) ) )
  7.     [
  8. ;----------------------------
  9. (setq layerlist (list "0" "Layer1" "Layer2" "Layer3" "ABCD" "DEFG" "HIJK"))
  10. (sssetfirst nil (ssget "_x" (list (cons 8 (_strcat layerlist " ,")))))
发表于 2022-11-26 15:26:52 | 显示全部楼层
opt.4
  1. (ssget
  2.   "_X"
  3.   '((-4 . "<OR")
  4.     (8 . "0")
  5.     (8 . "Layer1")
  6.     (8 . "Layer2")
  7.     (8 . "Layer3")
  8.     ( 8 . "ABCD")
  9.     (8 . "DEFG")
  10.     (8 . "HIJK")
  11.     (-4 . "OR>")
  12.   )
  13. )
  14. ;------------------ -----------------
  15. (ssget "_x" (list (8 . "0,Layer1,Layer2,Layer3,ABCD,DEFG,HIJK")))
发表于 2022-11-27 09:21:50 | 显示全部楼层
看不懂楼主的程序,程序和题目不相符吧。你是想根据选中的图形,挨个复制到特定图层内?
 楼主| 发表于 2022-11-27 11:23:59 | 显示全部楼层
;;;;;;;;;原程序
(defun c:ct22()
         (setq n -1)
         (princ "\n选择模板外形")
         (command "chprop" el_name "" "color" "9"  "ltype" "center" "layer" "D01"  "s" "5" "")
         (command "chprop" el_name "" "layer" "D02" ""  )
以上选择图形复制到图形,在选择其他图形添加到以下图层里面
;;;;*****Create Layer "P01"
;;;         (command "copy" es_name  "" "0,0" "" )
;;;         (command "chprop" el_namel "" "layer" "P01" "")
;;;  ;*****Create Layer "D01"
;;;         (command "chprop" el_namel "" "layer" "D01" "")
 楼主| 发表于 2022-11-27 11:25:57 | 显示全部楼层
谢谢  谢谢你  ,,,,还在学习中
发表于 2022-11-27 11:42:52 | 显示全部楼层
   这个代码中  改变图元的图层    "D01"图层名   必须要存在  如果没有该图层名  必须先建一个该名称的图层  否则"chprop"命令调用会失败 ;  另外,后面的代码中,每次复制图元后都命名el_name,会将前面复制的图元名覆盖掉,导致以前复制的图元不可检索 查询,这样似乎欠妥  ;类似这种的 相同类型的重复操作一般用循环来完成,多解读别人写的可正确执行的代码,慢慢熟悉
 楼主| 发表于 2022-11-27 18:17:06 | 显示全部楼层
         (s ...
谢谢老师指点,,,对循环语句的思路一直不怎么会用,困恼,还请请教。谢谢你
发表于 2022-11-27 19:59:33 | 显示全部楼层
谢谢分享支持
GMT+8, 2025-8-23 05:33 , Processed in 0.172287 second(s), 25 queries , Gzip On.
