- 积分
- 22760
- 明经币
- 个
- 注册时间
- 2016-10-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
针对这里的帖子的提问 创建直线并跟随鼠标 - AutoLISP/Visual LISP 编程技术 - AutoCAD论坛 - 明经CAD社区 - Powered by Discuz! (mjtd.com)
将朗大师的捕捉函数和类似的动态画法代码组合了下,勉强达到目标,但是存在圆心不能捕捉,有时候会莫名其妙地不能点击定点的毛病,请朋友们继续优化下,谢谢!
朗大师的捕捉函数
;;; grread捕捉子函数
;;; name为移动的图元名,pt为光标点
;;; 返回值:如果有捕捉点则返回捕捉点,无则返回光标点
(defun osnappt (name pt / color d h k lst nearpt nearpt2 osmo pt1 pt2 pt3 pt4 pt5 ptx pty x)
(if name (entdel name))
(redraw)
(if (< (getvar "osmode") 16384)
(setq color (vla-get-autosnapmarkercolor (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))))
h (/ (getvar "viewsize") (cadr (getvar "screensize"))) d (getvar "pickbox")
lst (list (* d h) (* (- d 0.5) h) (* (+ d 0.5) h)) k (* 1.5 d h))
(if (setq nearpt (osnap pt "_END,_CEN,_NOD,_QUA,_INS,_TAN,_EXT"))(setq osmo 1))
(if (and(setq nearpt2 (osnap pt "_NEA"))(not (equal nearpt nearpt2 k)))
(setq osmo 2 nearpt nearpt2))
(if (and(setq nearpt2 (osnap pt "_MID"))(equal nearpt nearpt2 k))
(setq osmo 3 nearpt nearpt2))
(if (and(setq nearpt2 (osnap pt "_INT"))(equal nearpt nearpt2 k))
(setq osmo 4 nearpt nearpt2))))
(if name(entdel name))
(if nearpt
(setq ptx (car nearpt)pty (cadr nearpt))
(foreach x lst
(setq pt1 (list (- ptx x) (- pty x)) pt2 (list (+ ptx x) (- pty x))
pt3 (list (+ ptx x) (+ pty x)) pt4 (list (- ptx x) (+ pty x))
pt5 (list ptx (+ pty x)))
(cond
((= osmo 1)(grvecs (list color pt1 pt2 pt2 pt3 pt3 pt4 pt4 pt1)))
((= osmo 2)(grvecs (list color pt1 pt2 pt2 pt4 pt3 pt4 pt3 pt1)))
((= osmo 3) (grvecs (list color pt1 pt2 pt2 pt5 pt5 pt1)))
((= osmo 4) (grvecs (list color pt1 pt3 color pt2 pt4)))))
(setq pt nearpt)))
pt
;以下为隐藏内容
;;;主函数开始 动态放置直线 ----------------------------------------------------------------------------------
(DEFUN C:hhh(/ ANG CD ED ELI IP LS P P0 PICK PT QD ZD)
(setq qd(getpoint"\n请点击直线起点")
zd (getpoint qd"\n请点击直线终点")
cd(distance qd zd)
ang(angle zd qd))
(defun mc()
(setq eli
(list '(0 . "line") (cons 10 zd) (cons 11 (polar zd ang cd )) )
(entmake eli)
(SETQ p0 qd)
(while(= 0(distance (cadr(grread t 4 0)) p0)))
(mc)
(setq ls(entlast)
ed (entget ls)
pick nil)
(while(/=(car(setq p(grread t 15 0)))3)(redraw)
(setq p(grread t 4 0))
(setq ip (car p)
pt (osnappt ls (cadr p))
(if(= ip 5)
(setq ed (Subst (cons 10 pt) (assoc 10 ed) ed)
ed (Subst (cons 11(polar pt ang cd))(assoc 11 ed)ed))
(entmod ed)
(setq pick (= 3 ip))
