查看: 1409|回复: 8
[提问] 求编程:多个cad图内有多个图层,现在想要批量将所有文件按图层写出
发表于 2022-12-4 23:10:17 | 显示全部楼层 |阅读模式
5明经币
求编程:有一批cad图,内有多个图层,现在想要批量处理,将所有文件按图层写到新的文件,命名规则如:原CAD文件名+图层名.dwg。
最佳答案
查看完整内容
然后贴上我在2011年初学时候东拼西凑的一个源码 ;;;2011年11月8日 15:10:01 ;;;yanshengjiang收集整理 (defun c:tcsc(/ *ERROR* la leng n dwgname lu2 lu work dwgname-lujing wenjian-ls ss);;按图层输出到文件 (defun *ERROR*(msg)(princ)) (setvar "cmdecho" 0) (INITGET "All Sng") (setq work(getkword "\n[全图输出(A)/单一图层输出(S)] 默认(S)")) (if (/= "" work)(setq work "All")) (set ...
发表于 2022-12-4 23:10:18 | 显示全部楼层
  (INITGET "All Sng")
    (setq la(get_all_layer))
    (setq leng(length la))
    (setq dwgname (getvar "dwgname"))
    (setq dwgname-lujing (getvar "DWGPREFIX"))
    (setq lu2(MAKEFOLDER (strcat dwgname-lujing (vl-filename-base dwgname))))
    (setq lu(strcat  dwgname-lujing (vl-filename-base dwgname)"\\"(vl-filename-base dwgname) "_"))
(if (= "All" work)
           (command "_.undo" "m");标记
           (command "_.zoom" "e")
           (command "_.purge" "a" "*" "n")
    (setq n 0)
    (while (< n leng)
    (setq wenjian-ls (strcat lu (nth n la)))
      (if (= nil(findfile(strcat wenjian-ls ".dwg")))
           (if(setq ss (ssget "x" (list(cons 8 (nth n la)))))
        (command "_.wblock" wenjian-ls "" "0,0" ss "" "oops")
         (princ "\n已经保存到: ")
         (princ wenjian-ls)
          (princ (strcat "\n已经存在" wenjian-ls ".dwg"))
      (setq n(1+ n))
      (command "_.undo" "b");后退
      );progn
      (setq la(cdr(assoc 8(entget(car(entsel"\n请选择您要输出图层上的一个实体:"))))))
      (setq ss(ssget "x" (list(cons 8 la))))
      (if(= nil(findfile(strcat lu la ".dwg")))
        (command "_.wblock" (strcat lu la) "" "0,0" ss "" "oops")
        (princ(strcat"\n已输出到" lu la))
      (princ (strcat "\n已经存在" lu la ".dwg"))
   );progn
  );if
  (defun get_all_layer (/ lay layer2 layname);;;;;得到图层列表。。。by秋枫批打
    (setq layer2 nil
          lay (tblnext "LAYER" T)
    (while (/= lay nil)
      (setq layname (cdr (assoc 2 lay))
            layer2 (cons layname layer2)
      (setq lay (tblnext "LAYER"))
    (setq layer2 (ACAD_Strlsort layer2))
    layer2
(defun MAKEFOLDER (FNAME / SYS FOLDER);建立文件夹;;;By LUCAS(龙龙仔)
   (if (not (findfile FNAME))
           (setq SYS (vlax-create-object "Scripting.FileSystemObject"))
           (setq FOLDER (vlax-invoke-method SYS 'CREATEFOLDER FNAME))
           (vlax-put  FOLDER
    "Attributes"
    1        ;此处如果改成2.则创建隐藏文件夹
           (vlax-release-object FOLDER)
           (vlax-release-object SYS)
;;;       (alert (strcat "\"" FNAME "\" 档案夹已存在!!"))
发表于 2022-12-8 16:16:40 | 显示全部楼层
转发z版的一个源码
(vl-load-com)
;按层存文件 明经 ZZXXQQ 2011.1.6 ,nuist 2015.12.18
(defun c:tt ()
  (setvar "CMDECHO" 0)
  (setq lnm nil)
  (setq filepath (strcat (vla-get-Path (vla-get-ActiveDocument (vlax-get-acad-object))) "\\") )
  (setq filepath (strcat (strcat filepath (getvar "dwgname")) "1\\") )
  (command "sh" (strcat "rd/s/q " filepath))
  (command "sh" (strcat "md " filepath))
  (while (setq lnm (tblnext "LAYER" (not lnm)))
    (if (setq ss (ssget "X" (list (cons 8 (cdr(assoc 2 lnm))))))
      (command ".WBLOCK" (strcat (strcat filepath (cdr(assoc 2 lnm))) ".dxf") "" "" "0,0" ss "")
  (setvar "CMDECHO" 1)
 楼主| 发表于 2022-12-8 22:37:33 | 显示全部楼层
(defun c:ltt ()
(setq newpath (strcat (getvar "DWGPREFIX") "out") )
(if (= (vl-file-directory-p newpath)  nil)  (vl-mkdir newpath))
(setq lnm nil)
(while (setq lnm (tblnext "LAYER" (not lnm))  )
  (if (setq ss  (ssget "X"  (list (cons 8 (cdr (assoc 2 lnm) ) )  )  )  )
      (command ".WBLOCK"  (strcat newpath "\\" (vl-filename-base  (getvar  "DWGNAME" )) "-"  (cdr (assoc  2  lnm)))  "" "0,0" ss "" "oops")
 楼主| 发表于 2022-12-8 22:44:43 | 显示全部楼层
yanshengjiang 发表于 2022-12-8 16:16
转发z版的一个源码
(vl-load-com)
感谢回复。之前借鉴Z版代码了,程序不能批处理一个文件夹,还需要用批处理工具,再一个需要打开文件才能处理,速度不是很快。
发表于 2022-12-9 09:51:15 | 显示全部楼层
  1. (defun GetFolder(msg / WinShell shFolder path catchit);选取文件夹
  2.   (setq shFolder(vlax-invoke-method (vlax-create-object "Shell.Application")'BrowseForFolder 0 msg 1))
  3.   (setq  catchit(vl-catch-all-apply'(lambda()(setq shFolder(vlax-get-property shFolder'self))
  4.                                       (setq path(vlax-get-property shFolder'path)))))
  5.   (if(vl-catch-all-error-p catchit)nil path))
  6. (defun xdirectory(folder)
  7.   (setq folder(list(list folder)))
  8.   (while(car(setq folder(cons(apply'append(mapcar'(lambda(x)(mapcar'(lambda(y)(strcat x"\\"y))(cddr(vl-directory-files X nil -1))))
  9.                                                  (car folder)))folder))))(apply'append folder))
  10. (defun getpath(msg ext / path paths files)
  11.   (and(setq path(GETFOLDER msg))
  12.       (setq paths(XDIRECTORY path))
  13.       (setq files(apply'append(mapcar'(lambda(x)(mapcar'(lambda(y)(strcat x "\\"y))(VL-DIRECTORY-FILES x ext 1)))paths)))
  14.       )(list paths files))
  15. (defun l2array(l / A)
  16.   (vlax-safearray-fill(vlax-make-safearray 9(cons 0(1-(length l))))
  17.     (mapcar(function(lambda(x / a)(setq a(type x))(cond((='ename a)(vlax-ename->vla-object x))((='VLA-OBJECT a)x))))l)))
  18. (defun c:tt(/ files acad layers *DBX *Dbmdl blk doc blkname acVer)
  19.   (vl-load-com)
  20.   (setq acad(vlax-get-acad-object)
  21.         doc(vlax-get-property acad'activedocument)
  22.         acVer(atoi(getvar "ACADVER"))
  23.         *DBX(vla-GetInterfaceObject *ACAD(if(< acVer 16)"ObjectDBX.AxDbDocument"(strcat"ObjectDBX.AxDbDocument."(itoa acVer))))
  24.         *Dbmdl(vla-get-ModelSpace *dbxobj)
  25.         blk(vlax-invoke-method(vlax-get-property doc'blocks)'add(vlax-3d-point 0 0)"*U")
  26.         blkname(vlax-get-property blk'name))
  27.   (and(setq files(cadr(GETPATH"指定要合并的Excel文件夹""*.dwg")))
  28.       (vl-some(function(lambda(x / lays la lay)
  29.                          (vlax-for x blk(vlax-invoke-method x 'delete))
  30.                          (and(not(VL-CATCH-ALL-ERROR-P(VL-CATCH-ALL-APPLY(function vlax-invoke-method)(List(*DBX"open"x)))))
  31.                              (vlax-for x(vlax-get-property *DBX'layers)(setq lays(cons(list(vlax-get-property x 'name))lays)))
  32.                              (vlax-for x *Dbmdl
  33.                                (setq la(assoc(vlax-get-property x'layer)lays)lays(cons(vl-list*(car la)x(cdr la))(vl-remove la lays))))
  34.                              (vl-some(function(lambda(a)
  35.                                                 (and(cadr a)
  36.                                                     (vlax-invoke-method doc'wblock(strcat(VL-FILENAME-DIRECTORY x)(VL-FILENAME-base x)(car a)".dwg")
  37.                                                       (vlax-invoke-method *DBX'CopyObjects(l2array(cdr a))))
  38.                                                     nil)))lays))))
  39.               files))
  40.   (vlax-invoke-method blk 'delete))
未来得及测试
参与人数 2明经币 +2 收起 理由
shiyj + 1
yanshengjiang + 1
 楼主| 发表于 2022-12-9 23:52:50 | 显示全部楼层
不懂就问,第33行代码中有一句 (car la x) ,好像car参数只有一个:表,为甚能有两个参数?
发表于 2022-12-10 13:43:46 | 显示全部楼层
没注意到。写错了
已更正
 楼主| 发表于 2022-12-11 12:35:13 | 显示全部楼层
大佬,你的代码我使劲调试还是不能运行,提示:参数类型错误: VLA-OBJECT nil  能否抽个使劲帮忙试运行一次。
GMT+8, 2025-7-19 02:27 , Processed in 0.226050 second(s), 25 queries , Gzip On.
