查看: 6380|回复: 20
[讨论] 我编写DCL的方法
发表于 2022-12-28 15:40:25 | 显示全部楼层 |阅读模式
学习了 baitang36 一键合并DCL和LSP文件,我谈谈自己编写DCL的方法,供大家参考。
《操作对话框》
第一步,用vlide编写DCL
第二步,用命令dcl2lsp转成lisp文件
第三步,写(getdata) (setdata)(do3) 和主函数(do1)
大功告成!
下面是我用的dcl2lsp
  1. ;;===========2014.12.24==================DCL文件转成需要的.lsp
  2. (defun c:dcl2lsp (/ DCLNAME FN1 FN1L FN2 FN2L FNAME1 FNAME2 INITDIR K)
  3.   (setq fname1 (getfiled "***选择DCL文件***" "" "dcl" 16))
  4.   (setq Initdir (strcat (vl-filename-directory fname1) "\\22"))
  5.   (setq fn1 (open fname1 "r"))
  6.   (setq fname2 (getfiled "***Lisp文件保存到***" Initdir "lsp" 1))
  7.   (setq fn2 (open fname2 "w"))
  8.   (write-line "(defun dialog ()" fn2)
  9.   (write-line "(setq fname (vl-filename-mktemp nil nil \".dcl\"))"
  10.         fn2
  11.   )
  12.   (write-line "(setq fn (open fname \"w\"))" fn2)
  13.   (while (setq fn1l (read-line fn1))
  14.     (if  (wcmatch fn1l "*:*dialog*")
  15.       (setq DCLName (VL-STRING-TRIM " " (car (parse3 fn1l "[^:]+"))))
  16.     )
  17.     (setq fn2l (strcat "(write-line " (VL-PRIN1-TO-STRING fn1l) " fn)"))
  18.     (write-line fn2l fn2)
  19.   )
  20.   (close fn1)
  21.
  22.   (write-line "(close fn)" fn2)
  23.   (write-line "" fn2)
  24.   (write-line "(setq dclid (load_dialog fname))" fn2)
  25.   (write-line ";;如果不循环,去掉下面123" fn2)
  26.   (write-line "(setq return# 3);1" fn2)
  27.   (write-line "(while (> return# 2);2" fn2)
  28.   (write-line (strcat "(new_dialog \"" DCLName "\" dclid)") fn2)
  29.   (write-line "(setdata)" fn2)
  30.   (write-line "(action_tile \"accept\" \"(getdata)(done_dialog 1)\")"
  31.         fn2
  32.   )
  33.   (write-line "(setq return# (start_dialog))" fn2)
  34.   (write-line "(cond ((equal return# 3) (do3)));3" fn2)
  35.   (write-line ")" fn2)
  36.   (write-line "(unload_dialog dclid)" fn2)
  37.   (write-line "(vl-file-delete fname)" fn2)
  38.   (write-line "(cond ((equal return# 1) (do1)))" fn2)
  39.   (write-line ")" fn2)
  40.   (close fn2)
  41.   (princ"\n dcl2lsp")
  42.   (princ)
  43. )
  44. ;;===========2014.12.24==================DCL文件转成需要的.lsp
参与人数 3明经币 +3 收起 理由
菜鸟初来乍到 + 1
dtucad + 1 很给力!
guosheyang + 1 赞一个!
发表于 2022-12-28 16:48:30 | 显示全部楼层
接着黄大师的话题,我也说说我是怎么写DCL的:
实际上很长时间以来,我是很不愿意去写DCL的,因为手工写DCL,出错是个必然,而且出错的位置不少。
在刚开始能上网的1998年左右,我找来了一个老外写的创建DCL的辅助LISP工具,DCG (加了点密)。
后来发现他不支持Windows 95开始的长文件名,我就解密后做了相关的修正,后来一直使用这个改版DCG创建DCL,效果和效率都很不错。
一直到本坛大神飞诗发布了DCL编辑器,这个确实是我所用过的多种DCL创建工具中的王者!有了这个工具,DCL再也不是问题了,把我之前多年以来用惯的DCG都彻底下班了。
不过这时候DCL是个单独的文件,有需要时打包到vlx里。没有代码化和动态创建DCL。
代码化和动态创建DCL,有个前提就是需要有一个解析函数,能对飞诗创建出的DCL数据(注意是数据,不是DCL文件)做解析,读入数据,函数返回DCL文本的行内容list数据,最后动态写出DCL文件。
然后就是设计这个解析函数,并编码,调试,测试,改进...最后这个函数ok了,现在我只需要在飞诗DCL Editor中设计好对话框,生成dcl数据文件,复制其中数据到 lisp 文件中简单变量赋值即可。其他的LISP中都是固定代码和套路。
自贡黄明儒 + 1 很给力!
回复 支持 2 反对 0
发表于 2023-3-6 15:58:42 | 显示全部楼层
补个函数,防小白迷路
(defun xty-str-substall ( new old str / inc len )
    (setq len (strlen new)
          inc 0
    (while (setq inc (vl-string-search old str inc))
        (setq str (vl-string-subst new old str inc)
              inc (+ inc len)
    str
 楼主| 发表于 2022-12-29 08:11:31 | 显示全部楼层
用命令dcl2lsp ,将<MyI 指定距离插入块.dcl>转成lisp,大致模样如下:
;;离曲线d 插入块
;;164.23 [功能] 多段线所击点离起点近
;;示例(HH:PickToStart (car(setq en(entsel))) (cadr en))
(defun HH:PickToStart (curve p / L1 L2 PP)
  (setq pp (vlax-curve-getclosestpointto curve (trans p 1 0)))
  (setq        L2 (vlax-curve-getDistAtParam curve
                                      (vlax-curve-getEndParam curve)
  (setq L1 (vlax-curve-getDistAtPoint curve pp))
  (> (- L2 L1) L1)
(defun C:MyI (/ DIALOG DO1 DO3 PICK SETDATA GETDATA _HH:MYI _HH:MYI2 DO ANG ANGB BETWEEN D DCLDATA DCLID E ECURVE EN FLAG FN FNAME KEY1 KEY2 KEY3 KEY4 KEY5 KEY6 KEY7 KEY8 L P PARAM PRCS RETURN# X)
  (defun do (d L)
    (if        (<= d L)
      (if Flag
        (_HH:MyI2 d)
        (_HH:MyI2 (- L d))
  ;;在曲线d处插入块
  (defun _HH:MyI2 (d)
  ;;e曲线 (setq key2 "235*2 200*2,20+50") key1 块名 key6为"1"时屏幕上旋转 key8镜向
  (defun _HH:MyI ()
  (defun getdata (/ DCLDATA I KEY)
    (setq i 0)
    (repeat 8                                                    ;"key1"到"key8"
      (setq i (1+ i))
      (setq key (strcat "key" (itoa i)))
      (set (read key) (get_tile key))
      (setq DCLData (cons (cons key (eval (read key))) DCLData))
    (setenv "DDJJB\\MyI" (VL-PRIN1-TO-STRING DCLData))
  (defun setdata (/ DCLDATA X)
    (cond ((setq DCLData (getenv "DDJJB\\MyI"))
           (setq DCLData (read DCLData))
           (mapcar '(lambda (x) (Set_tile (car x) (cdr x))) DCLData)
           (if (= (cdr (assoc "key6" DCLData)) "1")
             (mode_tile "key7" 1)                            ;1灰色
  (defun pick ()
    (if        (= key6 "1")
      (mode_tile "key7" 0)                                    ;0可用 1灰色 2聚焦
  ;;拾取块名
  (defun do3 (/ e)
    (setq e (LM:ssget "\n 点取文字、者块"
                      '("_+.:E:S" ((0 . "INSERT")))
    (if        e
        (setq e (ssname e 0))
        (setq en (entget e))
        (setq key1 (cdr (assoc 2 en)))
        (if (setq DCLData (getenv "DDJJB\\MyI"))
            (setq DCLData (subst (cons "key1" key1) (assoc "key1" DCLData) DCLData))
          (setq DCLData (cons (cons "key1" key1) DCLData))
  ;;主程序
  (defun do1 ()
    (vl-load-com)
    ((if command-s
       command-s
       vl-cmdf
     )                    "_.ucs"
    (setvar "INSUNITS" 0)                                    ;设置为无单位缩放
    (ACET-UNDO-BEGIN)
    (vl-catch-all-apply '_StartOsmode nil)                    ;捕捉开始 ;关闭捕捉.
    (if        (and (tblobjname "BLOCK" key1)
             (setq e (nentsel "\n 点取曲线:"))
      (_HH:MyI)
      (alert (strcat "块" key1 "不存在!..."))
    (vl-catch-all-apply '_EndOsmode nil)                    ;捕捉结束 ;打开捕捉.
    (ACET-UNDO-END)
    (gc)
  (defun dialog        ()
    (setq fname (vl-filename-mktemp nil nil ".dcl"))
    (setq fn (open fname "w"))
    (write-line "MyIdialog:dialog{label=\"离线端头插入块\";" fn)
    (write-line " :boxed_row{label=\"块名\";" fn)
    (write-line "    :edit_box{key=\"key1\";}" fn)
    (write-line        "    :button{key=\"key11\";label=\"&Pick<<\";}"
                fn
    (write-line "  }" fn)
    (write-line " :boxed_column{" fn)
    (write-line        "  :text{key=\"key12\";value=\"示例:235*2 200*2,20+50\";}"
                fn
    (write-line        "  :edit_box{label=\"距离\";key=\"key2\";value=\"0\";}"
                fn
    (write-line        " :edit_box{label=\"X比例\";key=\"key3\";value=\"1\";}"
                fn
    (write-line        " :edit_box{label=\"Y比例\";key=\"key4\";value=\"1\";}"
                fn
    (write-line        " :edit_box{label=\"Z比例\";key=\"key5\";value=\"1\";}"
                fn
    (write-line " :boxed_row{label=\"旋转\";" fn)
    (write-line        "    :toggle{key=\"key6\";label=\"在屏幕上指定\";value=\"1\";}"
                fn
    (write-line        "    :edit_box{key=\"key7\";label=\"角度\";value=\"0\";}"
                fn
    (write-line        " :toggle{label=\"镜向\";key=\"key8\";value=\"0\";}"
                fn
    (write-line " ok_cancel;" fn)
    (write-line "}" fn)
    (close fn)
  (dialog)
  (setq return# 3)
    (new_dialog "MyIdialog" dclid)
    (setdata)
    (action_tile "key6" "(setq key6 $value)(pick)")
    (action_tile "key11" "(getdata)(done_dialog 3)")
    (mode_tile "key2" 2)                                    ;聚焦
    (action_tile "accept" "(getdata)(done_dialog 1)")
  (princ "\n 插入块 MyI SM")
;;离曲线d 插入块
对话框中"key1"到"key8",连续编号。。。。
发表于 2022-12-29 09:57:40 | 显示全部楼层
我就喜欢手写DCL
最主要的原因
我需要精细调整控件的位置
属于特殊强迫症
没办法
这用DCG做起来也没方便多少
飞诗体验过没深入使用
感觉还没有DCG方便
最后
非常不喜欢dcl2lsp的方式
主要还是隔上一段时间
就忍不住要动动自己那些程序
加几个或固定或临时的功能
 楼主| 发表于 2022-12-28 15:51:52 | 显示全部楼层
对于 (getdata) (setdata)如何写呢?
我觉得采用highflybird大师的办法,先将edit_box toggle list_box....的key连续编号,以便于保存和获取
  1. (defun getdata (/ DCLDATA I KEY)
  2.     (setq i 0)
  3.     (repeat 5                                                    ;"key1"到"key5"
  4.       (setq i (1+ i))
  5.       (setq key (strcat "Key" (itoa i)))
  6.       (set (read key) (get_tile key))
  7.       (setq DCLData (cons (cons key (eval (read key))) DCLData))
  8.     )
  9.     (Setenv "MyD" (VL-PRIN1-TO-STRING DCLData))
  10.   )
  11.   (defun setdata (/ DCLDATA X)
  12.     (cond ((setq DCLData (getenv "MyD"))
  13.            (setq DCLData (read DCLData))
  14.            (mapcar '(lambda (x) (Set_tile (car x) (cdr x))) DCLData)
  15.           )
  16.     )
  17.   )
发表于 2022-12-28 16:49:53 | 显示全部楼层
感谢大佬分享~方便举个完整的例子不
发表于 2022-12-28 16:54:33 | 显示全部楼层
我觉得已经非常完美了,很有价值的代码,希望楼主补全一个例子,学习了
发表于 2022-12-28 19:43:19 | 显示全部楼层
谢谢楼主分享
发表于 2022-12-28 20:07:50 | 显示全部楼层
学习到了新方法,谢谢,再举个例子吧
发表于 2022-12-29 09:00:00 | 显示全部楼层
贴个自己常用的,没有老黄的直接,仅针对DCL,没考虑控制。
  1. ;;;=============================================
  2. ;;;      通用函数  文本转为LIST复制到剪贴板
  3. ;;;参数: file------文件
  4. ;;;       name------表名
  5. ;;;返回值:nil
  6. (defun xty-sys-copyclipdcl (file name / rf str html t1)
  7.   (setq rf (open file "r"))
  8.   (setq str (strcat "(setq " name "'(\n"))
  9.   (while (setq t1 (read-line rf))
  10.     (setq
  11.       str (strcat str "\"" (xty-str-substall "\\\"" "\"" t1) "\"\n")
  12.     )
  13.   )
  14.   (setq str (strcat str ")\n)"))
  15.   (setq HTML (vlax-create-object "htmlfile"))
  16.   (vlax-invoke
  17.     (vlax-get (vlax-get HTML 'PARENTWINDOW) 'CLIPBOARDDATA)
  18.     'SETDATA
  19.     "Text"
  20.     str
  21.   )
  22.   (vlax-release-object HTML)
  23.   (close rf)
  24. )
  25. ;;;=============================================
  26. ;;;      通用函数  写字符串表到文件
  27. ;;;参数:filename----文件名
  28. ;;;      strlst------需写入文件字符串表
  29. ;;;返回值:文件名
  30. (defun xty-sys-makeFbylst (filename strlst / f n)
  31.   (setq f (open filename "w"))
  32.   (foreach n strlst
  33.     (if  (eq (type n) 'STR)
  34.       (write-line n f)
  35.       (write-line (vl-princ-to-string n) f)
  36.       )
  37.     )
  38.   (close f)
  39.   filename
  40.   )
  1. (xty-sys-copyclipdcl (getfiled "dcl" "" "dcl" 16) "dcllst")
  2. ;;;ctrl+v粘贴,得下表
  3. (setq dcllst
  4.        '(
  5.    "MyIdialog:dialog{label=\"离线端头插入块\";"
  6.    " :boxed_row{label=\"块名\";"
  7.    "    :edit_box{key=\"key1\";}"
  8.    "    :button{key=\"key11\";label=\"&Pick<<\";}"
  9.    "  }"
  10.    " :boxed_column{"
  11.    "  :text{key=\"key12\";value=\"示例:235*2 200*2,20+50\";}"
  12.    "  :edit_box{label=\"距离\";key=\"key2\";value=\"0\";}"
  13.    " }"
  14.    " :edit_box{label=\"X比例\";key=\"key3\";value=\"1\";}"
  15.    " :edit_box{label=\"Y比例\";key=\"key4\";value=\"1\";}"
  16.    " :edit_box{label=\"Z比例\";key=\"key5\";value=\"1\";}"
  17.    " :boxed_row{label=\"旋转\";"
  18.    "    :toggle{key=\"key6\";label=\"在屏幕上指定\";value=\"1\";}"
  19.    "    :edit_box{key=\"key7\";label=\"角度\";value=\"0\";}"
  20.    "  }"
  21.    " :toggle{label=\"镜向\";key=\"key8\";value=\"0\";}"
  22.    " ok_cancel;"
  23.    "}"
  24.    )
  25.       )
  26. (xty-sys-makeFbylst (vl-filename-mktemp nil nil ".dcl")dcllst)
自贡黄明儒 + 1
GMT+8, 2025-7-16 06:28 , Processed in 0.172586 second(s), 28 queries , Gzip On.
