查看: 1659|回复: 7
这是李麦克的一个内接圆程序,怎么将图层从随层改为制定图层
发表于 2022-12-31 18:59:21 | 显示全部楼层 |阅读模式
;;; maximum circle inscribed in a closed polyline
;;; Gian Paolo Cattaneo
(defun C:Q11 (/ POLY POLY_vl Dx Dy Lp List_vert_poly list_p_int P_center dist step1 step2)
    (prompt "\nSelect Polyline: ")
    (while (setq POLY (ssname (ssget ":S" '((0 . "LWPOLYLINE"))) 0))
            (setq i 1 timer (date2sec))
            (setq step1 60) ;--> grid_1
            (setq step2 20) ;--> grid_2
            (setq POLY_vl (vlax-ename->vla-object POLY))
            (setq list_vert_poly (LMWPoly->List POLY))
            (grid_1)
            (Point_int)
            (grid+)
            (Point_center)
            (repeat 3
                (grid_2)
                (Point_center)
            (entmake
                (list
                    (cons 0 "CIRCLE")
                    (cons 8 (getvar "clayer"))
                    (cons 10 P_center)
                    (cons 40 dist)
            (setq endtimer (date2sec))
            (princ (strcat "time = "(rtos (- endtimer timer) 2 3) " seconds"))
;; LWPolyline to Point List  -  Lee Mac
;; Returns a list of points describing the supplied LWPolyline
(defun LMWPoly->List ( ent / der di1 di2 inc lst par rad )
    (setq par 0)
    (repeat (cdr (assoc 90 (entget ent)))
        (if (setq der (vlax-curve-getsecondderiv ent par))
            (if (equal der '(0.0 0.0 0.0) 1e-8)
                (setq lst (cons (vlax-curve-getpointatparam ent par) lst))
                (if
                    (setq rad (distance '(0.0 0.0) (vlax-curve-getfirstderiv ent par))
                          di1 (vlax-curve-getdistatparam ent par)
                          di2 (vlax-curve-getdistatparam ent (1+ par))
                        (setq inc (/ (- di2 di1) (1+ (fix (* 25 (/ (- di2 di1) rad (+ pi pi)))))))
                        (while (< di1 di2)
                            (setq lst (cons (vlax-curve-getpointatdist ent di1) lst)
                                  di1 (+ di1 inc)
        (setq par (1+ par))
    lst
; Restituisce una griglia di punti all'interno del getboundingbox della poly selezionata
; Returns a grid of points within the BoundingBox of the selected poly
(defun grid_1 (/ P1_ P2_ n P> )
    (vla-getboundingbox POLY_vl 'p1 'p2)
    (setq P1_ (vlax-safearray->list p1))
    (setq P2_ (vlax-safearray->list p2))
    (setq P1_ (list (car P1_) (cadr P1_)))
    (setq P2_ (list (car P2_) (cadr P2_)))
    (setq Dx (/ (- (car P2_) (car P1_)) step1))
    (setq Dy (/ (- (cadr P2_) (cadr P1_)) step1))
    (setq n 0)
    (setq P> P1_)
    (setq Lp (list P1_))
    (repeat (* (1+ step1) step1)
        (setq P> (list (+ (car P>) Dx) (cadr P>)))
        (setq Lp (cons P> Lp))
        (setq n (1+ n))
        (if (= n step1)
                (setq n 0)
                (setq P1_ (list (car P1_) (+ (cadr P1_) Dy)))
                (setq P> P1_)
    (setq Lp (cdr Lp))
; Restituisce una griglia di punti intorno al punto centrale (provvisorio)
; Returns a grid of points around the center point (provisional)
(defun grid_2 (/ P1_  P> n)
    (setq list_p_int nil)
    (setq P1_ (list (- (car P_center) (* Dx 2)) (- (cadr P_center) (* Dy 2))))
    (setq Dx (/ (* 4 Dx) step2))
    (setq Dy (/ (* 4 Dy) step2))
    (setq n 0)
    (setq P> P1_)
    (setq list_p_int (list P1_))
    (repeat (* (1+ step2) step2)
        (setq list_p_int (cons P> list_p_int))
        (setq n (1+ n))
        (if (= n step2)
                (setq n 0)
                (setq P> P1_)
; restituisce la lista dei punti interni ad un poligono
; dati:  - lista coordinate dei punti -> Lp
;        - lista coordinate vertici poligono -> list_vert_poly
; Returns the list of points inside the polyline
(defun Point_int (/ P_distant n Pr cont attr p# Pa Pa_ Pb )
    (setq P_distant (list (car (getvar "extmax")) (* 2 (cadr (getvar "extmax")))))
    (foreach Pr Lp
         (setq cont -1)
        (setq attr 0)
        (setq p# nil)
         (setq Pa (nth (setq cont (1+ cont)) list_vert_poly))
        (setq Pa_ Pa)
        (repeat (length list_vert_poly)
            (setq Pb (nth (setq cont (1+ cont)) list_vert_poly))
            (if (= cont (length list_vert_poly)) (setq Pb Pa_))
            (setq P# (inters Pa Pb Pr P_distant))
            (if (/= P# nil) (setq attr (1+ attr)))
            (setq Pa Pb)
        (if (> (rem attr 2) 0) (setq list_p_int (cons Pr list_p_int)))
; Infittisce la griglia inserendo altri punti
; nel centro delle diagonali tra i punti interni
; Insert points (interior) to increase the density of the grid
(defun grid+ (/ G+)
    (setq G+
        (mapcar '(lambda ( x ) (list (+ (car x) (/ Dx 2)) (+ (cadr x) (/ Dy 2)))) list_p_int)
    (setq list_p_int (append G+ list_p_int))
; Da una lista di punti restituisce quello più lontano da un oggetto
; dati:  - lista dei punti -> list_p_int
;        - oggetto -> POLY_vl
; Returns the farthest point from the polyline
(defun Point_center (/ Pa n Pvic)
    (setq Dist 0.0000001)
    (setq P_center nil)
    (foreach Pa list_p_int
         (setq Pvic (vlax-curve-getClosestPointTo POLY_vl Pa))
        (if (> (distance Pa Pvic) Dist)
                (setq P_center Pa)
                (setq Dist (distance Pa Pvic))
        (if (>= Dist 0.5)  (setq Dist 0.5))
(defun date2sec ()
  (setq s (getvar "DATE"))
  (setq seconds (* 86400.0 (- s (fix s))))
(vl-load-com)
发表于 2022-12-31 21:24:02 | 显示全部楼层
  (cons 8 (getvar "clayer"))改成 (cons 8 “你的图层”)?
 楼主| 发表于 2023-1-2 08:16:54 | 显示全部楼层
q11
Select Polyline:
选择对象:
undo 当前设置: 自动 = 开,控制 = 全部,合并 = 是,图层 = 是
输入要放弃的操作数目或 [自动(A)/控制(C)/开始(BE)/结束(E)/标记(M)/后退(B)] <1>: e DXF 组不正确: (8)
 楼主| 发表于 2023-1-2 08:22:17 | 显示全部楼层
zm880928 发表于 2023-1-2 08:16
q11
Select Polyline:
选择对象:
没那么简单
发表于 2023-1-2 11:46:14 | 显示全部楼层
新手不太懂。。。没弄懂怎么的这个插件
发表于 2023-1-4 11:09:55 | 显示全部楼层
q11
Select Polyline:
选择对象:
yaojing38给出的是正确的,你不会全角连符号一起复制过去了吧?
人家说的“你的图层”是指你需要的图层名,要注意符号的正确性,保证它是一个有效字符串而不是一个变量
 楼主| 发表于 2023-1-4 13:35:49 | 显示全部楼层
人家说的“你的图层”是指你需要的图层 ...
你说的对,我把getvar也复制进去了,谢谢大哥的解答
 楼主| 发表于 2023-1-4 13:39:52 | 显示全部楼层
yaojing38 发表于 2023-1-2 11:46
新手不太懂。。。没弄懂怎么的这个插件
是我搞错了,你是对的,谢谢大哥
GMT+8, 2025-5-24 12:13 , Processed in 0.170780 second(s), 22 queries , Gzip On.
