查看: 3095|回复: 18
根据坡比划线并标注
发表于 2023-1-17 10:02:18 | 显示全部楼层 |阅读模式
网上找的程序,划线并标注坡比。
(defun c:PD  ( / bd ang stp enp p1 gr p0)
   (vl-load-com)
   (setvar "DYNMODE" 0)
   (setvar "nomutt" 0)
   (setq SCALE (GETVAR "DIMSCALE"))
    (setq DIMHEIGHT 2.5)
   (defun gxl-error  (fun)
      (setq *olderror* *error*
            *Function* fun)
      (defun *error*  (msg)
         (if *Function*
            (VL-CATCH-ALL-APPLY *Function*))
         (setq *error* *olderror*
               *olderror* nil
               *Function* nil))
      (princ))
   (defun re () (setvar "nomutt" 0) (redraw))
   (gxl-error 're)
   (if (= aa nil)(setq aa 1))
   (if (null (setq bd (getreal (strcat "\n输入坡度 1: <" (vl-princ-to-string aa) ">" ))))
      (setq aa aa)
      (setq aa bd))
   (setvar "DYNMODE" 1)
   (setq ang (atan (/ 1 aa)))
   (setq stp (getpoint "\n输入或拾取起点:"))
   (setq p1 (polar stp ang 1e2))
   (while (not (member (car (setq gr (grread t 13 0))) '(2 3 25)))
      (redraw)
      (setq p0 (polar (cadr gr) (+ ang (/ pi 2)) 1e2))
      (setq enp (inters stp p1 p0 (cadr gr) nil))
      (grvecs (list -3 stp enp)))
   (entmake (list '(0 . "LINE") (cons 10 stp) (cons 11 enp)))
   (setq mip (mapcar '(lambda (x y) (/ (+ x y) 2)) stp enp))
(setq aa (abs aa))
   (entmake (list '(0 . "TEXT")
                  (cons 40 (* SCALE DIMHEIGHT))
                  (cons 41 0.85)
                  (cons 1 (strcat "1:" (if (eq aa (fix aa))(rtos aa 2 0) (vl-princ-to-string aa))))
                  (cons 10 mip)
                  (cons 50 ang)
                  '(72 . 1)
                  (cons 11 mip)))
   (vla-put-Alignment (vlax-ename->vla-object (entlast)) 13)
   (redraw)
   (princ))
 楼主| 发表于 2023-1-17 11:29:32 | 显示全部楼层
sandyvs 发表于 2023-1-17 10:31
额,不会编程,我把strcat那加了绝对值,结果不输出了。。
加在文字之前就可以了
   (vl-load-com)
   (setvar "nomutt" 0)
            *Function* fun)
         (if *Function*
               *olderror* nil
               *Function* nil))
      (princ))
   (gxl-error 're)
      (setq aa aa)
      (setq aa bd))
      (redraw)
   (setq aa (abs aa))
                  (cons 41 0.85)
                  (cons 10 mip)
                  (cons 50 ang)
                  '(72 . 1)
                  (cons 11 mip)))
   (redraw)
   (princ))
 楼主| 发表于 2025-5-6 09:37:15 | 显示全部楼层
江湖夜雨 发表于 2025-5-3 22:57
请问怎么改变标注文字的大小修改程序中的哪个地方?能否根据图面比例,1:1时字高为3.0,1:100时字高为300
根据当前标注的全局比例来的
   (setq DIMHEIGHT 3)
 楼主| 发表于 2023-1-17 10:26:58 | 显示全部楼层
自贡黄明儒 发表于 2023-1-17 10:10
(setq aa bd))后面加一句(setq aa (abs aa))试试。
不行呀黄老师,正的是往左坡,负的是往右坡,改成正的之后就不能往右画坡了,我是想怎么把标注那改成正的
发表于 2023-1-17 10:10:13 | 显示全部楼层
发表于 2023-1-17 10:28:20 | 显示全部楼层
根据角度判断一下,正的加abs
 楼主| 发表于 2023-1-17 10:31:39 | 显示全部楼层
自贡黄明儒 发表于 2023-1-17 10:28
根据角度判断一下,正的加abs
字符不能加绝对值  发表于 2023-1-17 10:52
发表于 2023-1-17 11:30:39 | 显示全部楼层
 楼主| 发表于 2023-1-17 11:56:06 | 显示全部楼层
感谢回复,应该不用判断是否小于0,反正要标的都是正的
发表于 2023-1-17 12:09:15 | 显示全部楼层
的确不用判断
发表于 2023-1-17 21:30:07 | 显示全部楼层
支持一下看看
GMT+8, 2025-5-24 15:38 , Processed in 0.191146 second(s), 26 queries , Gzip On.
