查看: 1207|回复: 8
[提问] 寻找高手~动态弯道标注,修改标注单位R为米,L为米单位
发表于 2023-1-23 19:54:48 | 显示全部楼层 |阅读模式
动态弯道标注,麻烦修改标注单位R为米,L为米单位,
谢谢
(本程序采摘自www.lisp123.com)
(defun c:WGBZ()
        (Form1_load)
(defun Form1_load( / dcl_id Dialog_Return key keysDcl_File)
        (vl-load-com)
        (setq dcl_id(load_dialog (setq Dcl_File (Write_Dcl_Form1))));对话框加载
        (vl-file-deleteDcl_File);加载后删除DCL文件
        (setqDialog_Return 2)
        ;(while (>Dialog_Return 1) ;循环控制对话框是否结束
                (new_dialog"Form1" dcl_id);建立窗体
;-->-->-对话框初始化->-->--
                (setq keys'("Command1" "Command2" "accept""cancel"));列表全部控件名称
                (foreach keykeys;全部控件的初始化
                        (if (eval(read (strcat key "_bak"))) (set_tile key (eval (read (strcat key"_bak")))));控件内容
                        (action_tilekey "(Action_Form1_Keys $key $value)");点击动作
;--<--<-对话框初始化完成-<--<--
                (setqDialog_Return (start_dialog));开启对话框(用户可见)
                (cond
                        ((=Dialog_Return 3)
                                (cj)
                        ((=Dialog_Return 4)
                                (gdcj)
        (unload_dialogdcl_id);退出时卸除对话框
        (princ);防止函数回显
(defun Action_Form1_Keys (key value) ;全部控件的点击动作触发
        (cond
                ((= key"accept") ;{确认按钮}
                        (Get_Form1_Data)
                        (done_dialog1);对话框退出返回主函数 传递给Dialog_Return值为1
                ((= key"cancel") ;{取消按钮}
                        (done_dialog0);对话框退出返回主函数 传递给Dialog_Return值为0
                ((= key"Command1") ; {"插件名字"}(按钮)
                        (done_dialog3)
                ((= key"Command2") ; {"更多插件"}(按钮)
                        (done_dialog4)
(defun Get_Form1_Data( / key);临时生成Dcl文件 返回文件名
        (foreach keykeys
                (set (read(strcat key "_bak")) (get_tile key));每个控件都赋给一个变量 用于下次开启初始化
(defun Write_Dcl_Form1( / Dcl_File file str)
        (setqDcl_File (vl-filename-mktemp nil nil ".Dcl"))
        (setq file(open Dcl_File "w"))
        (foreach str'(
                "Form1:dialog"
                " label= \"Lisp123出品插件\";"
                "    :row"
                "        :button"
                "            key = \"Command1\";"
                "            label = \"动态弯道标注\" ;"
                "            width = 18.15 ;"
                "            height = 1.875 ;"
                "        :button"
                "            key = \"Command2\";"
                "            label = \"更多插件\" ;"
                "            width = 10.95 ;"
                "            height = 1.875 ;"
                "ok_cancel;"
                (write-linestr file)
        (close file)
        Dcl_File
(defun gdcj ( / )
(COMMAND "browser""http://www.Lisp123.com")
(defun cj ( / )
   (prompt"\n 弯道标注程序加载成功,只支持圆弧线!")
  (setqoldosmode (getvar "osmode"))
  (setq  l  (getvar "ltscale")
  scale   1.0
  textsize (*l 3.0)
(vl-load-com)
  (if (and (setqen1 (entsel "\n 请选取轨道中心线弧线:"))
     (setqarcobj (vlax-ename->vla-object (car en1)))
     ;;得到起点坐标
     (setqStartpt (vla-get-StartPoint arcobj))
     (setqStartpt (vlax-variant-value Startpt))
     (setqStartPoint (vlax-safearray->list Startpt))
     ;;得到终点坐标
     (setqEndpt (vla-get-EndPoint arcobj))
     (setqEndpt (vlax-variant-value Endpt))
     (setqEndPoint (vlax-safearray->list Endpt))
     ;;得到圆心坐标
     (setqCenterpt (vla-get-Center arcobj))
     (setqCenterpt (vlax-variant-value Centerpt))
     (setqCenterPoint (vlax-safearray->list Centerpt))
     ;;得到弧的夹角
     (setqtotalangle (vla-get-totalangle arcobj))
     ;;得到d-f-m
     (setqang_d (fix (/ (* totalangle 180) pi))
     ang_f(fix (* (- (/ (* totalangle 180) pi) ang_d) 60))
     ang_m(fix (* (- (/ (* totalangle 180) pi) ang_d (/ ang_f 60.0)) 3600))
     ;;得到转角数
     (setqang (strcat "θ="
          (itoa ang_d)
          (if (> ang_f 10)
            (itoa ang_f)
            (strcat "0" (itoa ang_f))
          (if (> ang_m 10)
            (itoa ang_m)
            (strcat "0" (itoa ang_m))
     ;;获取半径
     (setqradius (fix (* (vla-get-radius arcobj) 1000)))
     ;;取弧长
     (setqArcLength (fix (* (vla-get-ArcLength arcobj) 1000)))
     ;;绘制引线                                     θ
     (setqpt1 (getpoint "\n选择标注点:"))
     ;; 这个范例在模型空间中建立具有一个关系型注释的一条引线,
     ;; 接着显示新的引线的注释对象。
     (setqAcadObject   (vlax-get-acad-object)
    AcadDocument (vla-get-ActiveDocument Acadobject)
    mSpace        (vla-get-ModelSpaceAcaddocument)
     ;; 定义新的 MText 对象
     (setqtextString (strcat ang "\n" (strcat "R=" (itoa radius))"\n" (strcat "L=" (itoa ArcLength))))
     (setqinsertionPnt (vlax-make-safearray vlax-vbDouble '(0 . 2)))
    (vlax-safearray-fill insertionPnt pt1)
     (setqwidth (distance (car (textbox (list (cons 1 ang)))) (cadr (textbox (list (cons1 ang))))))
     ;; 在模型空间中建立MText 对象
     (setqMTextObj (vla-AddMText mSpace insertionPnt width textString))
     ;;填满wenzi
     (setqwenzi (vlax-make-safearray vlax-vbString '(1 . 9)))
       wenzi
      '("TopLeft" "TopCenter" "TopRight"  "MiddleLeft""MiddleCenter" "MiddleRight" "BottomLeft""BottomCenter" "BottomRight")
     ;; 引线数据
     (setqpnts (vlax-make-safearray vlax-vbDouble '(0 . 5)))
    (vlax-safearray-fill pnts (append pt1 (polar pt1 0 1)))
     ;;是否显示箭头
     (setqleaderType acLineWithArrow)
     ;;设置初始箭头为"实心闭合"
     (setqArrowheadType 0)
     ;;创建箭头类型列表
     (setqArrowheadTypeList (vlax-make-safearray vlax-vbstring '(1 . 20)))
       ArrowheadTypeList
      '("实心闭合""空心闭合""闭合""""建筑标记""倾斜""打开""指示原点""指示原点2""直角"  "30度角" "小点" "空心点""空心小点""方框""实心方框""基准三角形""实心基准三角形""积分""")
     ;; 在模型中建立Leader 对象,接着将MText对象设成
     ;;Leader注释,使新的MText对象和新的Leader对象建立关联
     (setqannotationObject MTextObj)
     (setqleaderObj (vla-AddLeader mSpace pnts annotationObject leaderType))
     (princ"\n")
    (progn(setq LST (list '(5
          (grdraw CenterPoint StartPoint 1)
          (grdraw CenterPoint EndPoint 1)
          (setq pt val)
           ;;更新文字插入点
          (vla-put-InsertionPoint MTextObj (vlax-3d-point pt))
           ;;更新文字插入点
           ;;设置文字的对齐点
          (vla-put-AttachmentPoint MTextObj acAttachmentPointBottomLeft)
           ;;修改文字颜色
          (vla-put-Color MTextObj 3)
           (vla-put-Layer MTextObj"zj")
          (vla-put-Width MTextObj width)
          (if
           (<= (car pt) (car pt1))
           ;;如果鼠标移动点的x坐标值小于等于最近点的X坐标值
           (vla-put-AttachmentPoint MTextObj 9)
           ;;更改文字的贴附点为9(右下角)
           (vla-put-AttachmentPoint MTextObj 7)
           ;;更改文字的贴附点为7(左下角)
          ;;end_if
          (setq pnts1 (vlax-make-safearray vlax-vbDouble '(0 . 5)))
          (vlax-safearray-fill pnts1 (append pt1 (polar pt 0 1)))
           (vla-put-Coordinates leaderObj pnts1)
           ;;更新引线插入点
           ;;设置文字标注在上方
          (vla-put-VerticalTextPosition leaderObj acAbove)
           ;;设置文字与标注线的垂直距离
          (vla-put-TextGap leaderObj (* l 1))
           ;;设置标注线的图层
           (vla-put-layer leaderObj"zj")
           ;;设置标注线的颜色
          (vla-put-DimensionLineColor leaderObj 1)
           ;;设置初始箭头大小
          (vla-put-ArrowheadSize leaderObj scale)
          (princ "\n按加减号改变箭头大小<+/->, </> 键改变文字高度,Tab键改变箭头样式:")
         '(2
           ;;TAB
           (9
           (setq ArrowheadType (+ ArrowheadType 1))
           (if
            (> ArrowheadType 19)
            (setq ArrowheadType 0)
           ;;修改箭头大小
           (vla-put-ArrowheadType leaderObj ArrowheadType)
            (princ
            (strcat
       "\n箭头变换啦***"
       " 当前箭头样式为->"
       (vlax-safearray-get-element ArrowheadTypeList (+ ArrowheadType 1))
          (43
           (setq scale (+ scale 0.1))
           ;;修改箭头大小
            (vla-put-ArrowheadSize leaderObjscale)
           (princ (strcat "\n箭头增大啦***"" 当前比例="(rtos scale 2 1)))
          (45
           (setq scale (- scale 0.1))
           ;;修改箭头大小
           (if
            (> scale 0.18)
       (princ (strcat "\n箭头减小啦***"" 当前比例="(rtos scale 2 1)))
            (princ "\n箭头已经是最小了!")
           ;;修改文字高度
          (44
           (setq width (* width (/ (+ textsize 0.1) textsize)))
           (setq textsize (+ textsize 0.1))
           (vla-put-Height MTextObj textsize)
           (princ (strcat "\n文字高度增大啦***"" 当前高度="(rtos textsize 2 1)))
          (46
           (setq width (* width (/ (- textsize 0.1) textsize)))
           (setq textsize (- textsize 0.1))
           (princ (strcat "\n文字高度减小啦***"" 当前高度="(rtos textsize 2 1)))
         ;;左击
          (3(setq pt val)
            (initget 1 " y n Y N  ")
            (setq xunwen (getkword "\n是否绘制半径[Y/N或回车退出]:"))
             (if (or (= xunwen "y") (=xunwen "Y") (= xunwen " "))
        (progn (command "line" CenterPoint StartPoint "")(command "line" CenterPoint EndPoint ""))
            (redraw)
            (setq TEST NIL)
            (setvar "osmode" oldosmode)
            '(25 (redraw) (setq TEST NIL))
            '(11 (redraw) (setq TEST NIL))
    (ZML-GRREAD lst)
(defun ZML-GRREAD (LST / test tmp mode val tmp2)
  (setq testt)
  (while test
    (setqtmp  (grread 2)
    mode (cartmp)
    val  (cadr tmp)
    (cond ((=mode 2)
     (if (and(setq tmp2 (assoc mode lst)) (setq tmp2 (cdr tmp2)) (setq tmp2 (assoc valtmp2)))
       (eval(cons 'progn (cdr tmp2)))
    ((setqtmp2 (assoc mode lst)) (eval (cons 'progn (cdr tmp2))))
    (t (princtmp))
(princ "\n本程序采摘自www.lisp123.com更多内容敬请期待!")
(princ "\n本程序命令:WGBZ")
 楼主| 发表于 2023-1-25 13:35:21 | 显示全部楼层
xyp1964 发表于 2023-1-25 13:26
;; 慎用:需要e派工具箱(XCAD)的支持
能不能不要e派工具箱,也能够用
不用院长的内库很简单啊,DIY  发表于 2023-1-29 15:13
发表于 2023-1-23 20:32:22 | 显示全部楼层
谢谢楼主分享
发表于 2023-1-24 18:59:45 | 显示全部楼层
代码错误太多,扔了吧!
 楼主| 发表于 2023-1-25 10:13:20 | 显示全部楼层
xyp1964 发表于 2023-1-24 18:59
代码错误太多,扔了吧!
院长有更好的吗?
发表于 2023-1-25 13:26:35 | 显示全部楼层
发表于 2023-1-26 11:31:09 | 显示全部楼层
发表于 2023-1-29 10:55:08 | 显示全部楼层
院长一如既往的牛叉~
GMT+8, 2025-5-14 23:32 , Processed in 0.226532 second(s), 28 queries , Gzip On.
