查看: 21239|回复: 73
[资源] 重写经典---麦版面板dcl 短小精干(20241016传可伸缩版))
发表于 2023-1-31 20:53:20 | 显示全部楼层 |阅读模式
炒冷饭了,顶顶人气,互相经验交流
节前看有关DCL帖子有些多,新年了,也来一波
20241016上传一个可伸缩的版本-底部下载
以下是最初版本
;一直这样使用
;去年疫情影响,空闲多,无聊对主程序(最下面)做了改写,略微精简
;面板函数mainpaneldcl发动程序
(defun c:xx ()(mainpaneldcl(list
        (list "常用1"
                (list "快速选择" "ss")
                ;功能名称/命令,这种命令方式可空格/回车重复执行上次
                ;命令也可以是(*)方式
                (list "快速建块" "qblk")
                (list "选特定字" "sstxt")
                (list "对象替换" "rss")
                (list "原位缩放" "scs")
                (list "递增复制" "caf")
        (list "制图环境"
                (list "标准外框" "wtk")
                (list "建标注样" "dimset")
                (list "Dim刷字h" "dimSETtxtsize")
                (list "字h刷Dim" "txtSETdimScale")
                (list "MY 宋 体" "mysimsunb")
                (list "等线仿宋" "myHztxt")
                (list "换背景色" "bjs")
                (list "MY打印机" "setp")
                (list "》a" "laytool");进入子板a
))(princ))
(defun c:laytool ()(mainpaneldcl(list
        (list "层操作"
                (list "层 关 闭" "lcs")
                (list "层反关闭" "lcsa")
                (list "层 冻 结" "lfs")
                (list "层反冻结" "lfsa")
                (list "层 锁 定" "lks")
                (list "层反锁定" "lksa")
                (list "层全打开" "w1")
                (list "层全解冻" "w2")
                (list "层全解锁" "w3")
                (list "三个全部" "w123")
                (list "《" "XX");返回主板
))(princ))
;面板主程序
(vl-load-com)
(defun mainpaneldcl (strklst / maxl keylst n nn lcmd ff f id cmd)
        (setq ff(vl-filename-mktemp "temp_pannel.dcl") f(open ff "w"))
        (write-line "MYbutton:button{width =10;vertical_margin=none;horizontal_margin=none;}" f)
        (write-line "MYpanel:dialog{label=\"xx工具\";:row{" f)
        (setq n 0 nn(mapcar 'length (mapcar 'cdr strklst)) maxl(apply 'max nn));表长
        (mapcar (function(lambda(x / l1)
                (write-line(strcat ":column{label=" (vl-prin1-to-string(car x))";")f)
                (setq x(cdr x) x(append x(repeat(- maxl(length x))(setq l1(cons '("" "")l1)))));表补长
                (mapcar (function(lambda(y / k)
                        (setq k(strcat "key" (itoa(setq n(1+ n)))))
                        (write-line(strcat
                                ":MYbutton{label="(vl-prin1-to-string(car y))";key= "(vl-prin1-to-string k)
                                (if(= (setq y(cadr y)) "")";is_enabled = false;}" ";}");填充的空白键
                        )f)
                        (setq keylst(cons k keylst) lcmd(cons y lcmd));键表key1开始/命令表
                ))x)
                (write-line "}" f)
        ))strklst)
        (write-line "}:row{" f)
        (write-line(if(> (length nn)2)":text{label=\"盛年不再来!岁月不待人!\";is_enabled = false;}" "spacer_0;")f)
        (write-line":button{label=\"关闭\"; key=\"cancel\";is_cancel=true;width=6;fixed_width=true;}" f)
        (write-line "spacer_0;}}" f)
        (close f)
        (setq id(load_dialog ff))(vl-file-delete ff)
        (new_dialog "MYpanel" id "3" P_MYpaneldcl)
        (mapcar (function(lambda(x)(action_tile x(strcat "(setq P_MYpaneldcl(done_dialog "(substr x 4)"))"))))keylst)
        (setq n (start_dialog))(unload_dialog id)
        (if(> n 0)(if(wcmatch(setq cmd(nth(1- n)(reverse lcmd))) "(*)")(eval(read cmd));(函数)方式
                (vla-SendCommand(vla-get-ActiveDocument(vlax-get-acad-object))(strcat cmd "\n"));c:命令方式,方便重复执行
        ));点击按钮的值
参与人数 8明经币 +8 金钱 +20 收起 理由
hubeiwdlue + 1 赞一个!
leedun + 1 + 20 很给力!
lee50310 + 1 很给力!
丶俗人 + 1 很给力!
USER2128 + 1 赞一个!
趣意人生 + 1 很给力!
guosheyang + 1 很给力!
tigcat + 1 很给力!
发表于 2023-2-17 21:35:33 | 显示全部楼层
  1. ;快捷键---图层控制
  2. (defun c:ww ()
  3. (mainpaneldcl
  4. (list
  5. (list "图层控制tcg"
  6. (list "图层关闭/l-" "layoff")
  7. (list "图层关闭(反)/tcgbf" "tcgbf")
  8. (list "全部显示/`"   "layon")
  9. (list "孤立图层/q" "layiso")
  10. (list "退出孤立/qq" "layuniso")
  11. )
  12. ))
  13. (princ))
  14. ;面板主程序
  15. (vl-load-com)
  16. (defun mainpaneldcl (strklst / maxl keylst n nn lcmd ff f id cmd)
  17.         (setq ff(vl-filename-mktemp "temp_pannel.dcl") f(open ff "w"))
  18.         (write-line "MYbutton:button{width =10;vertical_margin=none;horizontal_margin=none;}" f)
  19.         (write-line "MYpanel:dialog{label="xx工具";:row{" f)
  20.         (setq n 0 nn(mapcar 'length (mapcar 'cdr strklst)) maxl(apply 'max nn));表长
  21.         (mapcar (function(lambda(x / l1)
  22.                 (write-line(strcat ":column{label=" (vl-prin1-to-string(car x))";")f)
  23.                 (setq x(cdr x) x(append x(repeat(- maxl(length x))(setq l1(cons '("" "")l1)))));表补长
  24.                 (mapcar (function(lambda(y / k)
  25.                         (setq k(strcat "key" (itoa(setq n(1+ n)))))
  26.                         (write-line(strcat
  27.                                 ":MYbutton{label="(vl-prin1-to-string(car y))";key= "(vl-prin1-to-string k)
  28.                                 (if(= (setq y(cadr y)) "")";is_enabled = false;}" ";}");填充的空白键
  29.                         )f)
  30.                         (setq keylst(cons k keylst) lcmd(cons y lcmd));键表key1开始/命令表
  31.                 ))x)
  32.                 (write-line "}" f)
  33.         ))strklst)
  34.         (write-line "}:row{" f)
  35.         (write-line(if(> (length nn)2)":text{label="盛年不再来!岁月不待人!";is_enabled = false;}" "spacer_0;")f)
  36.         (write-line":button{label="关闭"; key="cancel";is_cancel=true;width=6;fixed_width=true;}" f)
  37.         (write-line "spacer_0;}}" f)
  38.         (close f)
  39.         (setq id(load_dialog ff))(vl-file-delete ff)
  40.         (new_dialog "MYpanel" id "3" P_MYpaneldcl)
  41.         (mapcar (function(lambda(x)(action_tile x(strcat "(setq P_MYpaneldcl(done_dialog "(substr x 4)"))"))))keylst)
  42.         (setq n (start_dialog))(unload_dialog id)
  43.         (if(> n 0)(if(wcmatch(setq cmd(nth(1- n)(reverse lcmd))) "(*)")(eval(read cmd));(函数)方式
  44.                 (vla-SendCommand(vla-get-ActiveDocument(vlax-get-acad-object))(strcat cmd "\n"));c:命令方式,方便重复执行
  45.         ));点击按钮的值
  46. )
我的程序  汉字面板为什么是  乱码的啊?
 楼主| 发表于 2024-10-17 15:30:35 | 显示全部楼层
decemc 发表于 2024-10-17 13:06
大佬,我一直用你之前的面板,刚试过了最新的版本,默认是收缩的,个人觉得不太方便,还有就是每列的对齐, ...
第一个问题,稍有接触lsp就可以改啊
(if mytoolgnall strklst0(list(car strklst0)(cadr strklst0)))
改为
(if mytoolgnall (list(car strklst0)(cadr strklst0))strklst0)
":button{label=\""(if mytoolgnall "《" "》")"\"; key=\"key1\";width=4;}"
改为
":button{label=\""(if mytoolgnall "》" "《")"\"; key=\"key1\";width=4;}"
第二个问题,这种改法不通用,也失去简洁的意义了,自己继续学习试做修改吧
 楼主| 发表于 2024-10-16 15:42:16 | 显示全部楼层
Qwer1243 发表于 2024-10-14 16:24
我也想问这个,感觉太挤了,看着有点眼花
改为
(write-line "MYbutton:button{width =10;horizontal_margin=none;}" f)
(write-line "MYbutton:button{width =10;}" f)
发表于 2023-1-31 22:16:40 | 显示全部楼层
谢谢楼主分享
发表于 2023-2-1 07:57:26 | 显示全部楼层
老大,复制试了一下,太牛了。。。。
发表于 2023-2-1 08:00:30 | 显示全部楼层
謝謝樓主分享
发表于 2023-2-1 09:19:14 | 显示全部楼层
🐮  感谢分享源码!
发表于 2023-2-1 09:24:52 | 显示全部楼层
手机上看,有运行时截图吗
发表于 2023-2-1 09:44:33 来自手机 | 显示全部楼层
老迈的好像还带自定义命令的,你精简掉了吗
发表于 2023-2-1 10:01:30 | 显示全部楼层
謝謝樓主分享!!!!
发表于 2023-2-1 10:31:08 | 显示全部楼层
很好,谢谢分享。
GMT+8, 2025-10-18 05:38 , Processed in 0.172494 second(s), 29 queries , Gzip On.
