查看: 2969|回复: 5
请教如何设置打印横向
发表于 2004-3-30 10:23:00 | 显示全部楼层 |阅读模式
;;打印测算表
;;在options中plotting设置打印机
(defun plotTbl (layer / s i len pt1 pt2)
(setvar "osmode" 0)
(setvar "cmdecho" 0)
(princ "\n请选择需打印的测算表:\n")
(if (setq s (ssget))
(if (setq s (Filter1 s 0 "INSERT" 8 layer))
(setq i 0
len (sslength s)
(princ (strcat "选择到" (itoa len) "个表格!\n"))
(while (< i len)
(setq e (ssname s i))
(setq pt1 (ev 10 e)
pt2 (list (+ (car pt1) 210) (+ (cadr pt1) 297))
;;;====================Custom==================================
(command "plot" "Y" "" "" "" "M" "P"
"N" "W" pt1 pt2 "1:1" "C" "" ""
"" "" "N" "Y" "Y"
;;;============================================================ (setq i (1+ i))
(princ "打印完毕!\n")
发表于 2004-3-30 11:39:00 | 显示全部楼层
(command "plot" "Y" "" "" "" "M" "L"
"" "" "N" "Y" "Y"
 楼主| 发表于 2004-3-30 12:20:00 | 显示全部楼层
谢谢
 楼主| 发表于 2004-3-30 12:29:00 | 显示全部楼层
再次请教如何选纸张A4或A3
发表于 2004-3-30 14:01:00 | 显示全部楼层
(command "plot" "Y" "" "" "A4" "M" "L"
"" "" "N" "Y" "Y"
 楼主| 发表于 2004-3-30 19:21:00 | 显示全部楼层
再次感谢,下次有可能还要麻烦您。
GMT+8, 2025-5-13 20:25 , Processed in 0.184971 second(s), 25 queries , Gzip On.
