查看: 2916|回复: 10
[经验] 浩辰cad2023的函数
发表于 2023-2-20 08:40:00 | 显示全部楼层 |阅读模式
WHILE
SETQ
IF
REPEAT
VLAX-FOR
FOREACH
DEFUN
COMMAND
OR
DEFUN-Q
COND
AND
FUNCTION
PROGN
UNTRACE
TRACE
EXPAND
ALLOC
MEM
GC
DEFUN-Q-LIST-SET
DEFUN-Q-LIST-REF
APPLY
EVAL
VL-ACAD-UNDEFUN
VL-ACAD-DEFUN
PRIN1
PRINC
PROMPT
PRINT
TEXTPAGE
TEXTSCR
REDRAW
GRAPHSCR
GRDRAW
VPORTS
GRVECS
GRTEXT
MENUCMD
GRCLEAR
MENUGROUP
EQUAL
EQ
BOOLE
1+
ABS
1-
COS
ATAN
SQRT
SIN
EXPT
EXP
FLOAT
FIX
LOG
GCD
LOGIOR
LOGAND
MAX
LSH
MINUSP
MIN
ZEROP
REM
TYPE
BOUNDP
NOT
SET
NUMBERP
NULL
ATOMS-FAMILY
ATOM
VL-SYMBOL-VALUE
VL-SYMBOL-NAME
VL-REGISTRY-WRITE
VL-SYMBOLP
VL-REGISTRY-DESCENDENTS
VL-REGISTRY-DELETE
VL-PRODUCTINFO
VL-REGISTRY-READ
DISTANCE
ANGLE
POLAR
INTERS
TEXTBOX
OSNAP
INITGET
ENTSEL
GETCORNER
GETANGLE
GETPOINT
GETDIST
GETREAL
GETINT
GETKWORD
GETFILED
GETSTRING
GETORIENT
NENTSELP
NENTSEL
GRREAD
XSTRCASE
TABLET
TERPRI
HANDENT
ENTDEL
ENTMAKE
ENTGET
ENTMOD
ENTMAKEX
ENTNEXT
ENTLAST
GETENV
ENTUPD
ACAD_COLORDLG
SETENV
GETCFG
GETCNAME
VER
SETCFG
SETVAR
GETVAR
ACAD-PUSH-DBMOD
VL-CMDF
ACAD_TRUECOLORCLI
ACAD-POP-DBMOD
HELP
ACAD_TRUECOLORDLG
ACAD_HELPDLG
SETFUNHELP
FNSPLITL
INITCOMMANDVERSION
OPEN
FINDFILE
VL-FILE-SIZE
CLOSE
VL-FILE-DELETE
VL-FILE-COPY
VL-FILE-RENAME
VL-FILE-DIRECTORY-P
VL-FILENAME-BASE
VL-FILE-SYSTIME
VL-FILENAME-EXTENSION
VL-FILENAME-DIRECTORY
WRITE-LINE
VL-MKDIR
READ-LINE
WRITE-CHAR
VL-DIRECTORY-FILES
READ-CHAR
REGAPP
VL-FILENAME-MKTEMP
XDSIZE
XDROOM
SSADD
SSGET
SSLENGTH
SSDEL
SSNAME
SSMEMB
SSGETFIRST
SSNAMEX
ACAD_STRLSORT
SSSETFIRST
ASSOC
APPEND
CDR
CAR
LAST
CONS
LISTP
LENGTH
MEMBER
MAPCAR
REVERSE
NTH
VL-LIST*
SUBST
VL-REMOVE-IF
VL-REMOVE
VL-SOME
VL-REMOVE-IF-NOT
VL-SORT-I
VL-SORT
VL-MEMBER-IF-NOT
VL-MEMBER-IF
VL-CONSP
VL-EVERY
VL-LIST->STRING
VL-LIST-LENGTH
_VL-TIMES
VL-POSITION
VL-BB-SET
VL-BB-REF
VL-PROPAGATE
VL-LOAD-ALL
CADR
CAAR
CDDR
CDAR
CAADR
CAAAR
CADDR
CADAR
CDADR
CDAAR
CDDDR
CDDAR
CAAADR
CAAAAR
CAADDR
CAADAR
CADADR
CADAAR
CADDDR
CADDAR
CDAADR
CDAAAR
CDADDR
CDADAR
CDDADR
CDDAAR
CDDDDR
CDDDAR
ANGTOS
ANGTOF
ATOF
ASCII
CHR
ATOI
DISTOF
CVUNIT
RTOS
ITOA
INNERCHECKVER
TRANS
ARXUNLOAD
ARX
AUTOLOAD
AUTOARXLOAD
STARTAPP
INITDIA
VL-VBALOAD
VLISP-COMPILE
LAYERSTATE-ADDLAYERS
VL-VBARUN
LAYERSTATE-DELETE
LAYERSTATE-COMPARE
LAYERSTATE-GETLASTRESTORED
LAYERSTATE-EXPORT
LAYERSTATE-GETNAMES
LAYERSTATE-GETLAYERS
LAYERSTATE-IMPORT
LAYERSTATE-HAS
LAYERSTATE-REMOVELAYERS
LAYERSTATE-IMPORTFROMDB
LAYERSTATE-RESTORE
LAYERSTATE-RENAME
ALERT
LAYERSTATE-SAVE
QUIT
EXIT
VL-CATCH-ALL-ERROR-MESSAGE
VL-CATCH-ALL-APPLY
VL-BT
VL-CATCH-ALL-ERROR-P
STRCASE
READ
STRLEN
STRCAT
WCMATCH
SUBSTR
VL-STRING-POSITION
VL-STRING-SEARCH
VL-STRING->LIST
VL-STRING-ELT
VL-STRING-LEFT-TRIM
VL-STRING-TRIM
VL-STRING-TRANSLATE
VL-STRING-RIGHT-TRIM
VL-PRINC-TO-STRING
VL-STRING-SUBST
VL-STRING-MISMATCH
VL-PRIN1-TO-STRING
LAYOUTLIST
NAMEDOBJDICT
DICTNEXT
DICTSEARCH
DICTREMOVE
DICTADD
DICTRENAME
SNVALID
TBLNEXT
TBLSEARCH
SETVIEW
TBLOBJNAME
NEW_DIALOG
LOAD_DIALOG
DONE_DIALOG
START_DIALOG
UNLOAD_DIALOG
TERM_DIALOG
SET_TILE
ACTION_TILE
MODE_TILE
GET_TILE
START_LIST
GET_ATTR
END_LIST
ADD_LIST
DIMX_TILE
START_IMAGE
FILL_IMAGE
DIMY_TILE
SLIDE_IMAGE
VECTOR_IMAGE
CLIENT_DATA_TILE
END_IMAGE
VL-DOC-EXPORT
VL-ARX-IMPORT
VL-DOC-SET
VL-DOC-IMPORT
VL-LIST-EXPORTED-FUNCTIONS
VL-DOC-REF
VL-UNLOAD-VLX
VL-LIST-LOADED-VLX
VL-EXIT-WITH-ERROR
VL-VLX-LOADED-P
VL-GET-RESOURCE
VL-EXIT-WITH-VALUE
VL-LOAD-COM
TICKCOUNT
VLAX-ADD-CMD
VL-LOAD-REACTORS
ACET-SS-REDRAW
VLAX-REMOVE-CMD
ACET-STR-FORMAT
ACET-SS-UNION
ACET-PS-TO-MS
ACET-MS-TO-PS
ACET-VIEWPORT-NEXT-PICKABLE
ACET-LAYTRANS
ACET-VIEWPORT-LOCK-SET
ACET-CURRENTVIEWPORT-ENAME
ACET-ENT-GEOMEXTENTS
ACET-UCS-CMD
ACDIMENABLEUPDATE
ACET-ENT-CURVEPOINTS
RPAD
LPAD
TAN
TRIM
VMON
LOG10
ACET-ACAD-REFRESH
GCET-VPROTATE
ACET-ACADREACTOR-ID-REMOVE
ACET-ACADREACTOR-ID-ADD
ACET-ACADREACTOR-ID-SWAP
ACET-ACADREACTOR-ID-REMOVE-ALL
ACET-ADDGBINEXPRESS
ACET-ACADREACTOR-IDS-GET
ACET-ALT-VIEWPORT
ACET-ALERT
ACET-ANGLE-FORMAT
ACET-ANGLE-EQUAL
ACET-ARX-RE-LOAD
ACET-APPID-DELETE
ACET-AUTOLOAD
ACET-ARXLOAD-OR-BUST
ACET-AUTOLOAD-EXEC
ACET-AUTOLOAD-APPLY
ACET-LSP-LOAD
ACET-AUTOLOAD2
ACET-BLOCK-MAKE-ANON
ACET-BLINK-AND-SHOW-OBJECT
ACET-BS-STRIP
ACET-BLOCK-PURGE
ACET-CALC-ROUND
ACET-CALC-BITLIST
ACET-CMD-CHECK
ACET-CALC-TAN
ACET-DCL-LIST-MAKE
ACET-CMD-EXIT
ACET-DICT-FILTER-MATCH
ACET-DICT-ENAME
ACET-DICT-NAME-LIST
ACET-DICT-MAKE
ACET-DTOR
ACET-DISABLED-COMMAND
ACET-VBALOAD
ACET-DXF
ACET-VIEWPORT-FROZEN-LAYER-LIST-SET
ACET-WMFIN
ACET-VIEWPORT-VPFREEZE
ACET-MENU-LOAD2
ACET-MENU-LOAD
ACET-PARTIAL-MENU-STATUS-SET
ACET-PARTIAL-MENU-STATUS-GET
ACET-RE-MAKE
ACET-PATH-TO-LIST
ACET-REACTOR-REMOVE
ACET-REACTOR-EXISTS
ACET-GENERAL-PROPS-GACET-PAIRS
ACET-EDITOR-REACTOR-ADD
ACET-INIT-GACET-LIB-DIR
ACET-GENERAL-PROPS-SACET-PAIRS
ACET-SMTP-ADDRESS
ACET-PLINES-REBUILD-SACET-ELEVATION
ACET-FTP-DOWNLOAD
ACET-SMTP-SEND
ACET-SACET-CMDECHO
ACET-FTP-UPLOAD
_ACETAUTOLOAD
_ACETAUTOARXLOAD
GETFILEET
_ACETAUTOQLOAD
FINDFILEET
FINDTRUSTEDFILE
AI_RTOS
GETFILESUPPORTLANG
BNS_TBL_MATCH
BNS_TRUNCATE_2_VIEW
BNS_BLKTBL_MATCH
BNS_BLK_MATCH
BNS_ANNOTATION_SS
BNS_SS_MOD
ACET-REG-GET
ACET-REG-DEL
ACET-REG-PRODKEY
ACET-REG-PUT
ACET-REG-TREE-GET
ACET-REG-SETACTIVEX
ACET-REG-SETDEMANDLOAD
ACET-REG-TREE-SET
ACET-REG-MACHINE-PRODKEY
ACET-REG-SETCOMMAND
ACET-SYS-COMMAND
ACET-SYS-BEEP
ACET-SYS-FOREGROUND
ACET-SYS-CONTROL-DOWN
ACET-SYS-LASTERR
ACET-SYS-KEYSTATE
ACET-SYS-PROCID
ACET-SYS-LMOUSE-DOWN
ACET-SYS-SLEEP
ACET-SYS-SHIFT-DOWN
ACET-SYS-TERM
ACET-SYS-SPAWN
ACET-HOW-TO-GET-EXPRESS
ACET-SYS-WAIT
ACET-INI-SET
ACET-INI-GET
ACET-INIT-ACETUTIL-ARX
ACET-INIT
ACET-INIT-EXCLUDE-LIST
ACET-INIT-ADD-LIB-DIR
ACET-INIT-EXPRESS-NOT-INSTALLED-MSG
ACET-INIT-EXPRESS-INSTALLED
ACET-INIT-FORCE-LOAD-ARX-LIB
ACET-INIT-FAS-LIB
ACET-INIT-PLACEMENU
ACET-INIT-GET-LIB-DIR
ACET-INIT-GET-UPDATE
ACET-INIT-PRODKEY
ACET-STR-ENV-EXPAND
ACET-STR-COLLATE
ACET-STR-ESC-WILDCARDS
ACET-STR-EQUAL
ACET-STR-IS-PRINTABLE
ACET-STR-FIND
ACET-STR-LR-TRIM
ACET-STR-LIST-SELECT
ACET-STR-REPLACE
ACET-STR-M-FIND
ACET-STR-TO-LIST
ACET-STR-SPACE-TRIM
ACET-FULL-DWGNAME
ACET-STR-WCMATCH
ACET-GETVAR-CPROFILE
ACET-GETVAR
ACET-GETVAR-FIXED-PROFILE
ACET-GETVAR-DWG
ACET-SETVAR
ACET-SET-CMDECHO
ACET-SETVAR-DWG
ACET-SETVAR-CPROFILE
ACET-VAR-GETVAR
ACET-SETVAR-FIXED-PROFILE
ACET-SYSVAR-RESTORE
ACET-VAR-SETVAR
ACET-PLINE-IS-2D
ACET-SYSVAR-SET
ACET-PLINE-SEGMENT-LIST
ACET-PLINE-MAKE
ACET-PLINES-EXPLODE
ACET-PLINE-SEGMENT-LIST-APPLY
ACET-PLINES-REBUILD
ACET-PLINES-EXPLODE-WIDTH-DATA-GET
ACET-PLINES-REBUILD-SET-ELEVATION
ACET-PLINES-REBUILD-APPLY-WIDTHS
ACET-LWPLINE-MAKE
ACET-SPINNER
ACET-GROUP-MAKE-ANON
ACET-GO-TO-EXPRESS-PAGE
ACET-HATCH-LOOP-MAKE-DATA-GET
ACET-POINT-FLAT
ACET-HATCH-LOOPEDGE-MAKE
ACET-PSPACE-VIEWPORT-ENAME
ACET-PREF-SUPPORTPATH-LIST
ACET-RTOD
ACET-R12-DXF-CONVERT
ACET-TABLE-NAME-LIST
ACET-SAFE-COMMAND
ACET-TEMP-SEGMENT
ACET-TABLE-PURGE
ACET-TJUST-GROUP-CODES
ACET-TJUST
ACET-UCS-CAPTURE-VIEWPORTS
ACET-TJUST-KEYWORD
ACET-UCS-RESTORE-VIEWPORTS
ACET-UCS-GET
ACET-UCS-SET-Z
ACET-UCS-SET
ACET-UNDO-BEGIN
ACET-UCS-TO-OBJECT
ACET-UNDO-INIT
ACET-UNDO-END
*PUSH-ERROR-USING-STACK*
ACET-UNDO-RESTORE
ACET-XDATA-GET
ACET-UTIL-VER
ACET-XREF-CPROJECT-PATH
ACET-XDATA-SET
ACET-GENERAL-PROPS-GET-PAIRS
ACET-GENERAL-PROPS-SET-PAIRS
ACET-EXPLODE
ACET-UCS-SACET-Z
ACET-GEOM-ANGLE-TRANS
ACET-GEOM-ANGLE-TO-ELLIPSEANGLE
ACET-GEOM-ARC-3P-D-ANGLE
ACET-GEOM-ARBITRARY-X
ACET-GEOM-VERTEX-LIST
ACET-GEOM-VECTOR-SIDE
ACET-GEOM-Z-AXIS
ACET-GEOM-VIEW-POINTS
ACET-GEOM-ARC-BULGE
ACET-GEOM-ZOOM-FOR-SELECT
ACET-GEOM-ARC-D-ANGLE
ACET-GEOM-ARC-CENTER
ACET-GEOM-ARC-POINT-LIST
ACET-GEOM-ARC-DELTA-ANGLE
ACET-GEOM-CROSS-PRODUCT
ACET-GEOM-CALC-ARC-ERROR
ACET-GEOM-ELLIPSE-ARC-LIST
ACET-GEOM-DELTA-VECTOR
ACET-GEOM-ELLIPSE-POINT-AT-E-ANGLE
ACET-GEOM-ELLIPSE-POINT-AT-ANGLE
ACET-GEOM-ELLIPSE-TO-PLINE
ACET-GEOM-ELLIPSE-POINT-LIST
ACET-GEOM-EXTENTS
ACET-GEOM-ELLIPSEANGLE-TO-ANGLE
ACET-GEOM-IMAGE-CLIP-LIST
ACET-GEOM-IMAGE-BOUNDS
ACET-GEOM-INSERT-POINT-LIST
ACET-GEOM-INSERT-CLIP-LIST
ACET-GEOM-IS-ARC
ACET-GEOM-INTERSECTWITH
ACET-GEOM-LIST-FUZ
ACET-GEOM-LIST-EXTENTS
ACET-GEOM-MATRIX-TRANS
ACET-GEOM-M-TRANS
ACET-GEOM-MTXTBOX
ACET-GEOM-MIDPOINT
ACET-GEOM-OBJECT-FUZ
ACET-GEOM-OBJECT-END-POINTS
ACET-GEOM-OBJECT-POINT-LIST
ACET-GEOM-OBJECT-NORMAL-VECTOR
ACET-GEOM-PIXEL-UNIT
ACET-GEOM-OBJECT-Z-AXIS
ACET-GEOM-PLINE-POINT-LIST
ACET-GEOM-PLINE-ARC-INFO
ACET-GEOM-POINT-INSIDE
ACET-GEOM-POINT-FUZ
ACET-GEOM-POINT-SCALE
ACET-GEOM-POINT-ROTATE
ACET-GEOM-SELF-INTERSECT
ACET-GEOM-RECT-POINTS
ACET-GEOM-SS-EXTENTS
ACET-GEOM-SPLINE-POINT-LIST
ACET-GEOM-SS-EXTENTS-FAST
ACET-GEOM-SS-EXTENTS-ACCURATE
ACET-GEOM-TRANS-IMAGE-TO-UCS
ACET-GEOM-TEXTBOX
ACET-GEOM-TXTBOX
ACET-GEOM-TRANS-UCS-TO-IMAGE
ACET-GEOM-VECTOR-ADD
ACET-GEOM-UNIT-VECTOR
ACET-GEOM-VECTOR-PARALLEL
ACET-GEOM-VECTOR-D-ANGLE
ACET-INSERT-ATTRIB-GET
ACET-GEOM-VECTOR-SCALE
ACET-INSERT-ATTRIB-SET
ACET-INSERT-ATTRIB-MOD
ACET-IS-SYMBOL-TABLE
ACET-INSERT-SPACIAL-FILTER
ACET-LAYER-LOCKED-LIST
ACET-LAYER-LOCKED
ACET-LIST-ASSOC-APPEND
ACET-LAYER-UNLOCK-ALL
ACET-LIST-ASSOC-REMOVE
ACET-LIST-ASSOC-PUT
ACET-LIST-INSERT-NTH
ACET-LIST-GROUP-BY-ASSOC
ACET-LIST-ISORT
ACET-LIST-IS-DOTTED-PAIR
ACET-LIST-PUT-NTH
ACET-LIST-M-ASSOC
ACET-LIST-REMOVE-DUPLICATES
ACET-LIST-REMOVE-ADJACENT-DUPS
ACET-LIST-SPLIT
ACET-LIST-REMOVE-NTH
ACET-ELIST-ADD-DEFAULTS
ACET-LIST-TO-SS
ACET-ELIST-FILTER-AND-MATCH
ACET-ELIST-FILTER--4-MATCH
ACET-ELIST-FILTER-MATCH
ACET-ELIST-FILTER-GC-MATCH
ACET-ELIST-FILTER-OR-MATCH
ACET-ELIST-FILTER-NOT-MATCH
ACETAI_NOFILE
ACETAI_FFILE
ACETAUTOARXLOAD
ACETAUTOARXACEDLOAD
ACETAUTONATIVELOAD
ACETAUTOLOAD
ACET-SS-CLEAR-PREV
ACET-SS-ANNOTATION-FILTER
ACET-SS-DRAG-MOVE
ACET-SS-CONVERT-ELLIPSES-TO-PLINES
ACET-SS-DRAG-SCALE
ACET-SS-DRAG-ROTATE
ACET-SS-FILTER
ACET-SS-ENTDEL
ACET-SS-FILTER-ITEM
ACET-SS-FILTER-CURRENT-UCS
ACET-SS-FLT-CSPACE
ACET-SS-FILTER-VALIDATE
ACET-SS-NEW
ACET-SS-INTERSECTION
ACET-SS-REMOVE-DUPS
ACET-SS-REMOVE
ACET-SS-REMOVE-DUPS-GENERALIZE-ENT
ACET-SS-REMOVE-DUPS-EXTENTS-LIST
ACET-SS-SCALE-TO-FIT
ACET-SS-REMOVE-DUPS-REVERSE
ACET-SS-SORT
ACET-SS-SCALE-TO-FIT-BASE
ACET-SS-TO-LIST
ACET-SS-SSGET-FILTER
ACET-SS-ZOOM-EXTENTS
ACET-SS-VISIBLE
ACET-FILE-BACKUP
ACET-FILE-ATTR
ACET-FILE-BACKUP-RESTORE
ACET-FILE-BACKUP-DELETE
ACET-FILE-CWD
ACET-FILE-CHDIR
ACET-FILE-DIR
ACET-FILE-COPY
ACET-FILE-FIND-FONT
ACET-FILE-FIND
ACET-FILE-FIND-ON-PATH
ACET-FILE-FIND-IMAGE
ACET-FILE-MOVE
ACET-FILE-MKDIR
ACET-FILE-READDIALOG
ACET-FILE-OPEN
ACET-FILE-RMDIR
ACET-FILE-REMOVE
ACET-FILE-WRITEDIALOG
ACET-FILE-SYSTIME-COMPARE
ACET-FILENAME-ASSOCIATED-APP
ACET-FILENAME-ACAD-ROOT
ACET-FILENAME-DIRECTORY
ACET-FILENAME-DIR-ON-PATH
ACET-FILENAME-EXTENSION
ACET-FILENAME-EXT-REMOVE
ACET-FILENAME-SUPPORTPATH-REMOVE
ACET-FILENAME-PATH-REMOVE
ACET-HELP
ACET-FILENAME-VALID
ACET-ERROR-INIT
ACET-HELP-TRAP
ACET-UI-STATUS
ACET-ERROR-RESTORE
ACET-UI-PICKDIR
ACET-UI-MESSAGE
ACET-UI-PROGRESS
ACET-UI-TXTED
ACET-UI-PROGRESS-INIT
ACET-UI-PROGRESS-DONE
ACET-UI-GETCORNER
ACET-UI-PROGRESS-SAFE
ACET-UI-GET-LONG-NAME
ACET-UI-GETFILE
ACET-UI-DRAG
ACET-UI-M-GET-NAMES
ACET-UI-TABLE-NAME-FORMAT
ACET-UI-TABLE-NAME-GET
ACET-UI-TABLE-NAME-GET-CMD
ACET-UI-TABLE-NAME-CHECK-FLAGS
ACET-UI-TABLE-NAME-GET-DLG
ACET-UI-TABLE-NAME-GET-CMD-LIST
ACET-UI-TABLE-NAME-GET-IS-VALID
ACET-UI-TABLE-NAME-GET-ENAME
ACET-UI-TABLE-NAME-GET-PICKIT
ACET-UI-TABLE-NAME-GET-ITEM-LIST
ACET-UI-ENTSEL
ACET-UI-TABLE-NAME-OBJECT-DATA
ACET-UI-POLYGON-SELECT
ACET-UI-FENCE-SELECT
ACET-UI-GACET-LONG-NAME
ACET-UI-SINGLE-SELECT
PI
ACET-UI-M-GACET-NAMES
ACRX_CMD_MODAL
PAUSE
ACRX_CMD_TRANSPARENT
ACRX_CMD_REDRAW
:PROG-ID
ACRX_CMD_USEPICKSET
ACET:OK
:AUTOLISP
ACET:ABORTRETRYIGNORE
ACET:OKCANCEL
ACET:YESNO
ACET:YESNOCANCEL
ACET:ICONSTOP
ACET:RETRYCANCEL
ACET:ICONWARNING
ACET:ICONQUESTION
ACET:DEFBUTTON1
ACET:ICONINFORMATION
ACET:DEFBUTTON3
ACET:DEFBUTTON2
ACET:IDOK
ACET:DEFBUTTON4
ACET:IDABORT
ACET:IDCANCEL
ACET:IDIGNORE
ACET:IDRETRY
ACET:IDNO
ACET:IDYES
ACET:IDHELP
ACET:IDCLOSE
ACET:HIDDEN
ACET:READONLY
ACET:DIRECTORY
ACET:SYSTEM
ACET:NORMAL
ACET:ARCHIVE
VLAX-MAP-COLLECTION
VLAX-MAKE-SAFEARRAY
VLAX-3D-POINT
VLAX-ENAME->VLA-OBJECT
VLAX-MAKE-VARIANT
VLAX-SAFEARRAY->LIST
VLAX-VLA-OBJECT->ENAME
VLAX-SAFEARRAY-GET-DIM
VLAX-SAFEARRAY-FILL
VLAX-SAFEARRAY-GET-L-BOUND
VLAX-SAFEARRAY-GET-ELEMENT
VLAX-SAFEARRAY-PUT-ELEMENT
VLAX-SAFEARRAY-GET-U-BOUND
VLAX-TMATRIX
VLAX-SAFEARRAY-TYPE
VLAX-VARIANT-TYPE
VLAX-VARIANT-CHANGE-TYPE
VARIANT-VALUE
VLAX-VARIANT-VALUE
VLAX-GET-OBJECT
SAFEARRAY-VALUE
VLAX-GET-OR-CREATE-OBJECT
VLAX-CREATE-OBJECT
VLAX-GET-ACAD-OBJECT
VLAX-IMPORT-TYPE-LIBRARY
VLAX-ERASED-P
VLAX-DUMP-OBJECT
VLAX-WRITE-ENABLED-P
VLAX-READ-ENABLED-P
VLAX-OBJECT-RELEASED-P
VLAX-RELEASE-OBJECT
VLAX-GET
VLAX-TYPEINFO-AVAILABLE-P
VLAX-PUT
VLAX-GET-PROPERTY
VLAX-PROPERTY-AVAILABLE-P
VLAX-PUT-PROPERTY
VLAX-INVOKE-METHOD
VLAX-INVOKE
VLAX-CURVE-GETAREA
VLAX-METHOD-APPLICABLE-P
VLAX-CURVE-GETSTARTPOINT
VLAX-CURVE-GETSTARTPARAM
VLAX-CURVE-GETENDPARAM
VLAX-CURVE-GETENDPOINT
VLAX-CURVE-ISPERIODIC
VLAX-CURVE-ISCLOSED
VLAX-CURVE-GETDISTATPARAM
VLAX-CURVE-ISPLANAR
VLAX-CURVE-GETPOINTATDIST
VLAX-CURVE-GETPARAMATDIST
VLAX-CURVE-GETFIRSTDERIV
VLAX-CURVE-GETPOINTATPARAM
VLAX-CURVE-GETDISTATPOINT
VLAX-CURVE-GETSECONDDERIV
VLAX-CURVE-GETCLOSESTPOINTTO
VLAX-CURVE-GETPARAMATPOINT
VLAX-PRODUCT-KEY
VLAX-CURVE-GETCLOSESTPOINTTOPROJECTION
VLAX-LDATA-GET
VLAX-LDATA-DELETE
VLAX-LDATA-PUT
VLAX-LDATA-LIST
VLAX-VBEMPTY
VLAX-LDATA-TEST
VLAX-VBINTEGER
VLAX-VBNULL
VLAX-VBSINGLE
VLAX-VBLONG
VLAX-VBSTRING
VLAX-VBDOUBLE
VLAX-VBBOOLEAN
VLAX-VBOBJECT
VLAX-VBABORT
VLAX-VBARRAY
VLAX-VBAPPLICATIONMODAL
VLAX-VBABORTRETRYIGNORE
VLAX-VBCANCEL
VLAX-VBARCHIVE
VLAX-VBCURRENCY
VLAX-VBCRITICAL
VLAX-VBDATE
VLAX-VBDATAOBJECT
VLAX-VBDEFAULTBUTTON2
VLAX-VBDEFAULTBUTTON1
VLAX-VBDIRECTORY
VLAX-VBDEFAULTBUTTON3
VLAX-VBEXCLAMATION
VLAX-VBERROR
VLAX-VBHIRAGANA
VLAX-VBHIDDEN
VLAX-VBINFORMATION
VLAX-VBIGNORE
VLAX-VBLOWERCASE
VLAX-VBKATAKANA
VLAX-VBNO
VLAX-VBNARROW
VLAX-VBOK
VLAX-VBNORMAL
VLAX-VBOKONLY
VLAX-VBOKCANCEL
VLAX-VBQUESTION
VLAX-VBPROPERCASE
VLAX-VBRETRY
VLAX-VBREADONLY
VLAX-VBSYSTEM
VLAX-VBRETRYCANCEL
VLAX-VBUPPERCASE
VLAX-VBSYSTEMMODAL
VLAX-VBVOLUME
VLAX-VBVARIANT
VLAX-VBYES
VLAX-VBWIDE
VLAX-VBYESNOCANCEL
VLAX-VBYESNO
AcDb-Reactor
DeepClone-Reactor
Command-Reactor
DWG-Reactor
DocManager-Reactor
Editor-Reactor
DXF-Reactor
Linker-Reactor
Insert-Reactor
Miscellaneous-Reactor
Lisp-Reactor
Object-Reactor
Mouse-Reactor
Toolbar-Reactor
SysVar-Reactor
Wblock-Reactor
Undo-Reactor
XREF-Reactor
Window-Reactor
:VLR-COMMAND-REACTOR
:VLR-ACDB-REACTOR
:VLR-DOCMANAGER-REACTOR
:VLR-DEEPCLONE-REACTOR
:VLR-DXF-REACTOR
:VLR-DWG-REACTOR
:VLR-INSERT-REACTOR
:VLR-EDITOR-REACTOR
:VLR-LISP-REACTOR
:VLR-LINKER-REACTOR
:VLR-MOUSE-REACTOR
:VLR-MISCELLANEOUS-REACTOR
:VLR-SYSVAR-REACTOR
:VLR-OBJECT-REACTOR
:VLR-UNDO-REACTOR
:VLR-TOOLBAR-REACTOR
:VLR-WINDOW-REACTOR
:VLR-WBLOCK-REACTOR
:VLR-OBJECTAPPENDED
:VLR-XREF-REACTOR
:VLR-OBJECTREAPPENDED
:VLR-OBJECTUNAPPENDED
:VLR-OBJECTMODIFIED
:VLR-OBJECTOPENEDFORMODIFY
:VLR-OBJECTUNERASED
:VLR-OBJECTERASED
:VLR-COMMANDWILLSTART
:VLR-UNKNOWNCOMMAND
:VLR-COMMANDCANCELLED
:VLR-COMMANDENDED
:VLR-BEGINDEEPCLONE
:VLR-COMMANDFAILED
:VLR-ABORTDEEPCLONE
:VLR-BEGINDEEPCLONEXLATION
:VLR-DOCUMENTCREATED
:VLR-ENDDEEPCLONE
:VLR-DOCUMENTLOCKMODEWILLCHANGE
:VLR-DOCUMENTTOBEDESTROYED
:VLR-DOCUMENTLOCKMODECHANGED
:VLR-DOCUMENTLOCKMODECHANGEVETOED
:VLR-DOCUMENTTOBEACTIVATED
:VLR-DOCUMENTBECAMECURRENT
:VLR-BEGINCLOSE
:VLR-DOCUMENTTOBEDEACTIVATED
:VLR-DATABASETOBEDESTROYED
:VLR-DATABASECONSTRUCTED
:VLR-ENDDWGOPEN
:VLR-BEGINDWGOPEN
:VLR-BEGINSAVE
:VLR-DWGFILEOPENED
:VLR-BEGINDXFIN
:VLR-SAVECOMPLETE
:VLR-DXFINCOMPLETE
:VLR-ABORTDXFIN
:VLR-ABORTDXFOUT
:VLR-BEGINDXFOUT
:VLR-LISPWILLSTART
:VLR-DXFOUTCOMPLETE
:VLR-LISPCANCELLED
:VLR-LISPENDED
:VLR-SYSVARCHANGED
:VLR-SYSVARWILLCHANGE
:VLR-BEGININSERTM
:VLR-BEGININSERT
:VLR-ENDINSERT
:VLR-OTHERINSERT
:VLR-RXAPPLOADED
:VLR-ABORTINSERT
:VLR-PICKFIRSTMODIFIED
:VLR-RXAPPUNLOADED
:VLR-BEGINDOUBLECLICK
:VLR-LAYOUTSWITCHED
:VLR-CANCELLED
:VLR-BEGINRIGHTCLICK
:VLR-ERASED
:VLR-COPIED
:VLR-GOODBYE
:VLR-UNERASED
:VLR-MODIFIED
:VLR-OPENEDFORMODIFY
:VLR-MODIFYUNDONE
:VLR-SUBOBJMODIFIED
:VLR-UNAPPENDED
:VLR-MODIFIEDXDATA
:VLR-OBJECTCLOSED
:VLR-REAPPENDED
:VLR-TOOLBARBITMAPSIZECHANGED
:VLR-TOOLBARBITMAPSIZEWILLCHANGE
:VLR-UNDOSUBCOMMANDCONTROL
:VLR-UNDOSUBCOMMANDAUTO
:VLR-UNDOSUBCOMMANDEND
:VLR-UNDOSUBCOMMANDBEGIN
:VLR-UNDOSUBCOMMANDBACK
:VLR-UNDOSUBCOMMANDMARK
:VLR-WBLOCKNOTICE
:VLR-UNDOSUBCOMMANDNUMBER
:VLR-BEGINWBLOCKID
:VLR-BEGINWBLOCKPT
:VLR-OTHERWBLOCK
:VLR-BEGINWBLOCK
:VLR-ENDWBLOCK
:VLR-ABORTWBLOCK
:VLR-DOCFRAMEMOVEDORRESIZED
:VLR-BEGINWBLOCKOBJECTS
:VLR-BEGINATTACH
:VLR-MAINFRAMEMOVEDORRESIZED
:VLR-ABORTATTACH
:VLR-OTHERATTACH
:VLR-REDIRECTED
:VLR-ENDATTACH
:VLR-BEGINRESTORE
:VLR-COMANDEERED
:VLR-ENDRESTORE
:VLR-ABORTRESTORE
:VLR-XREFSUBCOMMANDATTACHITEM
:VLR-XREFSUBCOMMANDBINDITEM
:VLR-XREFSUBCOMMANDDETACHITEM
:VLR-XREFSUBCOMMANDOVERLAYITEM
:VLR-XREFSUBCOMMANDRELOADITEM
:VLR-XREFSUBCOMMANDPATHITEM
ALL-DOCUMENTS
:VLR-XREFSUBCOMMANDUNLOADITEM
ACTIVE-DOCUMENT-ONLY
dtucad + 1 很给力!
发表于 2023-2-20 08:49:24 | 显示全部楼层
大神 666666666.   这个浩辰vlax是一个不支持啊。。  曲线函数是相对难搞么?
 楼主| 发表于 2023-2-20 09:16:45 | 显示全部楼层
你看到的是半成品,已改进,请重新下载
发表于 2023-2-20 09:34:33 | 显示全部楼层
期待楼主公布一款针对浩辰的免费加密软件
类似中望的
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=185019
 楼主| 发表于 2023-2-20 09:39:17 | 显示全部楼层
ludaweb 发表于 2023-2-20 09:34
期待楼主公布一款针对浩辰的免费加密软件
回复: 浩辰怎样把lsp文件编译成fas?
发件人:support_dev <support_dev@gstarcad.com>
时   间:2023年2月17日(星期五)下午2 : 39
收件人:
baitang36 <5520971@qq.com>
通过autocad编译成fas以后在浩辰平台可以加载运行
--------- 原始邮件信息 ---------
发件人: "baitang36" <5520971@qq.com>
收件人: "support_dev" <support_dev@gstarcad.com>
主题: 浩辰怎样把lsp文件编译成fas?
日期: 2023/02/17 14:13:26 (周五)
浩辰怎样把lsp文件编译成fas?
中望有个命令,compile
autocad用(vlisp-compile 'st "test.lsp")
浩辰用什么?
发表于 2023-2-20 10:29:19 | 显示全部楼层
浩辰的还给反馈了哦
发表于 2023-2-20 12:58:36 | 显示全部楼层
谢谢楼主分享
发表于 2023-2-20 20:05:24 | 显示全部楼层
谢谢楼主分享
发表于 2023-2-20 23:06:15 | 显示全部楼层
那个版本的vlisp的函数chm有个小小的笔误
目录的ars 应该是 arx
 楼主| 发表于 2023-2-21 16:32:32 | 显示全部楼层
vladimirputin 发表于 2023-2-21 15:08
浩辰与autocad的区别在哪里?楼主可以明确一下吗
浩辰指令较少,有些指令没有导致和acad结果不同,甚至崩溃
GMT+8, 2025-5-14 16:00 , Processed in 0.219068 second(s), 27 queries , Gzip On.
