- (defun c:FE ()(command "LAYFRZ" ));冻结关闭视口内图层
- ;;;打开视口内所有图层
- (defun c:fr (/ ssent laList i)
- (if (= (getvar "tilemode") 1)
- (setvar "tilemode" 0)
- (if (/= (getvar "cvport") 1)
- (command "_PSPACE")
- (if (setq ssent (ssget '((0 . "VIEWPORT"))))
- (progn
- (setq i 0)
- (repeat (sslength ssent)
- (if (/= ""
- (setq laList (LA:GetFreezeLayerForView
- (vlax-ename->vla-object (ssname ssent i))
- (command "_.vplayer" "T" laList "S" (ssname ssent i) "" "")
- (setq i (1+ i))
- (princ)
- (defun LA:GetFreezeLayerForView (VpObj / xt xd lyrlst a b)
- (vla-getxdata VpObj "ACAD" 'xt 'xd)
- (mapcar 'set
- '(xt xd)
- (list (safearray-value xt) (safearray-value xd))
- (setq lyrlst "")
- (mapcar '(lambda (a b)
- (if (= a 1003)
- (setq lyrlst (strcat lyrlst (strcase (variant-value b)) ","))
- xt
- xd
- lyrlst
- ;;;;====================图层工具===================================
- ; 隔离图层,选择层除外,关闭其它所有层
- (defun c:r1(/ x)
- (vl-cmdf "LAYISO" "s" "o" "o" )
- (princ )
- ; *打开所有层
- (defun c:r2( / )
- (vl-cmdf "layer" "on" "*" "")
- (princ )
- (defun c:r3(/ x)
- (IF (setq e (car(entsel"\n选择对象关闭所在图层")))
- (progn
- (setq lay (cdr(assoc 8 (entget e))))
- (cond
- ((and (= lay (getvar "CLAYER")) (/= lay "0"))
- (progn
- (setvar "CLAYER" "0")
- (vla-put-layeron(vlax-ename->vla-object(tblobjname "LAYER" lay)):vlax-false)
- ((/= lay (getvar "CLAYER"))
- ((and (= lay (getvar "CLAYER")) (= lay "0"))
- (princ"当前图层和对象图层都在0层,请重新执行")
- (princ)
- (defun c:r4(/ x)
- (vl-cmdf "LAYvpi" )
- (princ )
