查看: 1014|回复: 2
求助大佬们,这个运行显示“基本建模失败”是啥原因啊
发表于 2023-3-16 23:30:50 来自手机 | 显示全部楼层 |阅读模式
Sub Example_AddExtrudedSolidAlongPath()
    ' This example extrudes a solid from a region
    ' along a path defined by a spline.
    ' The region is created from an arc and a line.
    Dim curves(0 To 1) As AcadEntity
    ' Define the arc
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).startPoint, curves(0).endPoint)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ' Define the extrusion path (spline object)
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
      Dim startPoint(0 To 2) As Double   '定义起点坐标数组
    Dim endPoint(0 To 2) As Double     '定义终点坐标数组
     startPoint(0) = 0#
    startPoint(1) = 0#
    startPoint(2) = 0#
    '设置终点坐标
    endPoint(0) = 10#
    endPoint(1) = 10#
    endPoint(2) = 0#
    '创建直线对象
    Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    ' Define the Spline Object
    ' Create the solid
    Dim solidObj As Acad3DSolid
    Set solidObj = ThisDrawing.ModelSpace.AddExtrudedSolidAlongPath(regionObj(0), lineObj)
    ZoomAll
End Sub
发表于 2023-3-21 19:44:40 | 显示全部楼层
看图,我想是因为路径不能用直线吧?
发表于 2023-3-21 20:02:09 | 显示全部楼层
     startPoint(0) = 0#
    startPoint(1) = 0#
    startPoint(2) = 0#
    '设置终点坐标
    endPoint(0) = 10#
    endPoint(1) = 10#
    endPoint(2) = 0#
刚才试了一下这个起点终点坐标都在0#z轴坐标,那么就是一个没有拉伸的平面。所以错误了。应该改一下终点坐标为非零坐标。
GMT+8, 2025-5-22 22:19 , Processed in 0.187733 second(s), 24 queries , Gzip On.
