查看: 5802|回复: 27
[源码] 快属性批量编辑
发表于 2023-3-19 14:35:38 | 显示全部楼层 |阅读模式
快属性批量编辑
我想在这个基础上加上文字旋转一项,请路过的高手帮忙
原帖地址http://bbs.mjtd.com/forum.php?mo ... FA%C1%BF&page=1
发表于 2024-4-10 20:00:03 | 显示全部楼层
KO你 发表于 2024-4-10 06:54
朋友,能私下发源码我吗
发表于 2023-11-30 15:05:04 | 显示全部楼层
;;文字角度为0度,
(defun c:te0 ( / ss flt j mode)
(acet-error-init
(list (list  "cmdecho" 0
             "highlight" (getvar "highlight")
              "limcheck" 0
             "pickstyle" 0
       );list
       T
);list
);acet-error-init
(setq flt '((-4 . "<OR")
             (0 . "TEXT")
             (0 . "ATTDEF")
             (0 . "MTEXT")
(-4 . "<AND")
              (0 . "INSERT")
              (66 . 1)
             (-4 . "AND>")
            (-4 . "OR>")
);setq
(princ "\nSelect TEXT, MTEXT, ATTDEF, or BLOCK inserts w/attributes...")
(if (and (setq ss (ssget flt))
         (setq ss (car (acet-ss-filter (list ss
                                             '(("LAYERUNLOCKED") ;Dis-allow locked layers, non-current-space
                                               ("CURRENTUCS")    ;and dis-allow objects not in current ucs
                                             T
                                       );list
                       );acet-ss-filter
                  );car
         );setq
    );and
     (setq ss (bns_annotation_ss ss))
     (setq mode 0);setq
     (setvar "highlight" 0)
     (setq j (bns_trot ss mode))
     (if ss
         (command "_.select" ss "")
     );if
     (princ (strcat "\n" (itoa j) " objects modified."))
    );progn then
    (princ "\nNo valid objects selected.")
);if
(acet-error-restore)
(defun bns_trot ( ss mode / na e1 n a b j )
  (setq j 0)
  (setq n 0)
  (repeat (sslength ss)
    (setq na (ssname ss n)
          e1 (entget na)
    );setq
    (if (= "MTEXT" (cdr (assoc 0 e1)))
        (setq a (cdr (assoc 50 e1)))
        (setq a (acet-geom-angle-trans (cdr (assoc 50 e1)) na 1))
    );if
    (setq a (- a (getvar "angbase")))
    (if (not mode)
         (setq a (* (/ 180.0 pi) a))
         (if (< a 0)
             (setq a (+ a 360));setq
         );if
         (if (and (> a 100.0) (< a 280.0))
              (bns_rotate_text e1 pi)
              (setq j (+ j 1));setq
             );progn then
         );if
        );progn then most-readable
         (setq a (- mode a));setq
         (bns_rotate_text e1 a)
        );progn else
    );if
    (setq n (+ n 1));setq
  );repeat
  j ;the number of objects modified.
);defun bns_trot
(defun bns_rotate_text ( e1 ang / p1 p2 a)
(setq p1 (acet-geom-textbox e1 0.2)
      p1 (acet-geom-midpoint (car p1) (caddr p1))
       a (+ ang a)
      e1 (subst (cons 50 a) (assoc 50 e1) e1)
);setq
(entmod e1)
(entupd (cdr (assoc -1 e1)))
(setq e1 (entget (cdr (assoc -1 e1))))
(setq p2 (acet-geom-textbox e1 0.2)
      p2 (acet-geom-midpoint (car p2) (caddr p2))
       a (acet-geom-delta-vector p2 p1)
       a (trans a 1 na T)
      p1 (cdr (assoc 10 e1))
      p1 (acet-geom-vector-add p1 a)
      p2 (cdr (assoc 11 e1))
      p2 (acet-geom-vector-add p2 a)
      e1 (subst (cons 10 p1) (assoc 10 e1) e1)
      e1 (subst (cons 11 p2) (assoc 11 e1) e1)
);setq
(entmod e1)
);defun bns_rotate_text
 楼主| 发表于 2024-4-16 06:26:05 | 显示全部楼层
把代码里的颜色选项这里的随层色        colorlist (cons "ByLayer" colorlist))
改成随块色效果更佳        colorlist (cons "ByBlock" colorlist))
发表于 2023-3-20 12:35:52 | 显示全部楼层
估计要整点币吸引大佬来帮忙了,哈哈。
 楼主| 发表于 2023-3-21 20:27:05 | 显示全部楼层
lxl217114 发表于 2023-3-20 12:35
估计要整点币吸引大佬来帮忙了,哈哈。
之前有问题发币都没人回应,等有人帮我解决问题,自有悬赏
发表于 2023-3-23 18:15:50 | 显示全部楼层
这个是不是自带battman  就可以?
 楼主| 发表于 2023-3-23 19:19:36 | 显示全部楼层
guokexx 发表于 2023-3-23 18:15
这个是不是自带battman  就可以?
battman 块属性管理器  改的话所有的块都改了
我就是想编辑指定的图块修改
 楼主| 发表于 2023-10-8 03:26:22 | 显示全部楼层
顶一下,顶出高手
发表于 2023-10-9 10:49:40 | 显示全部楼层
KO你 发表于 2023-10-8 03:26
顶一下,顶出高手
 楼主| 发表于 2023-10-9 20:47:57 | 显示全部楼层
能用我发上来的源码弄出来吗,加上面板选项
发表于 2023-10-9 20:56:12 | 显示全部楼层
发表于 2023-10-9 21:08:00 | 显示全部楼层
不知道符不符合你的要求?
GMT+8, 2025-12-2 08:54 , Processed in 0.175040 second(s), 28 queries , Gzip On.
