查看: 2460|回复: 13
插入圆圈序号
发表于 2023-3-29 14:35:48 | 显示全部楼层 |阅读模式
2023.4.6
嗯。。达到要求了
(defun c:tt (/ *error* cc code gr loop n pt0 ptx xj xx zz)
  (defun *error* (msg)
    (if        (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
      (progn (princ (strcat "\n错误:" msg))
             (if cc
               (entdel cc)
             (if zz
               (entdel zz)
  (setvar "cmdecho" 0)
  (setvar "dynmode" 0)
  (setq scale (getvar "dimscale"))
  (setq n 1)
  (setq xx 0)
  (princ "/n 空格序号-1,右键退出,插入点更换:s左/f右/e上/d下:<左>")
  (setq loop t)                                ;grread
  (while loop
    (setq gr   (grread t 15 0)
          code (car gr)
          ptx  (cadr gr)
    (cond
      ((= code 3)
       (redraw)
       (setq cc nil)
       (setq zz nil)
       (setq n (1+ n))
      ((= code 5)                        ; 鼠标移动
       (redraw)
       (if cc
         (entdel cc)
       (if zz
         (entdel zz)
                                        ;(setq ptx (osnappt nil ptx))
       (setvar "osmode" 0)
       (setq pt0 (polar ptx xx (* scale 2)))
       (vl-cmdf "circle" pt0 (* scale 2))
       (setq cc (entlast))
       (entmakeX
         (list '(0 . "TEXT")
               (cons 1 (vl-princ-to-string n))
               (cons 10 pt0)
               (cons 40 (* scale 2))
               (cons 11 pt0)
               (cons 72 1)
               (cons 73 2)
       (setq zz (entlast))
      ((MEMBER (CADR GR) '(13 32))        ;空格 回车
       (setq n (- n 1))
      ((MEMBER (CADR GR) '(83 115))        ;a键
       (setq xx 0)
      ((MEMBER (CADR GR) '(70 102))        ;f键
       (setq xx pi)
      ((MEMBER (CADR GR) '(68 100))        ;d键
       (setq xx (* 0.5 pi))
      ((MEMBER (CADR GR) '(69 101))        ;e键
       (setq xx (* -0.5 pi))
      ((= code 25)
       (if cc
         (entdel cc)
       (if zz
         (entdel zz)
       (setq loop nil)
算是解决了吧,加个循环就好了。。空格 换方向,右击退出,但这个退出是因为错误退出。。
想要动态插入圆序号,请教下,有两个问题:1、最后一个生成的序号没用,如何删除?2、能否在移动过程中按键盘选择序圆插入点,比如上、下、左、右键对应圆的一、二、三、四象限。
  (defun *error* ( msg )
                        (progn (princ (strcat "\n错误:" msg)) (if cc (entdel cc)) (if zz (entdel zz)))
  (setq n 1)
  (setq tj t)
(while tj
  (initget "a s d w")
  (setq        xj
                (cond ((getkword "\n 选择插入点:[a 左/s 下/ d 右/w 上]<a>: ")) ("a")))
  (cond
    ((= xj "a")
                        (setq xx 0)
    ((= xj "d")
                        (setq xx pi)
    ((= xj "w")
    ((= xj "s")
  (while loop
                        code (car gr)
                        ptx  (cadr gr)
    (cond
      ((= code 3)
                                (redraw)
                                (setq cc nil)
                                (setq zz nil)
                                (setq n (1+ n))
      ((= code 5)                        ; 鼠标移动
                                (redraw)
                                (if cc
                                        (entdel cc)
                                (if zz
                                        (entdel zz)
                                (setvar "osmode" 0)
                                (setq cc (entlast))
                                (entmakeX
                                        (list '(0 . "TEXT")
                                                (cons 10 pt0)
                                                (cons 11 pt0)
                                                (cons 72 1)
                                                (cons 73 2)
                                (setq zz (entlast))
                        ;((= code 2) ; 键盘输入
                        ; (princ "\n键盘输入=")(princ pt))
      ((or(member code '(2 13))(member code '(2 32)))                       ; 空格,回车
                                (entdel cc)
                                (entdel zz)
                                (redraw)
                                (setq cc nil)
                                (setq zz nil)
                                (setq loop nil)
      (((= code 25))                       ; 鼠标右击
                                      (entdel cc)
                                (entdel zz)
                                (redraw)
                                (setq cc nil)
                                (setq zz nil)
                                (setq tj nil)
发表于 2023-3-29 15:51:27 | 显示全部楼层
修改一下这段试试:
((= code 25)  ; 鼠标右击
  (entdel cc)
  (entdel zz)
  (redraw)
  (setq cc nil)
  (setq zz nil)
  (setq loop nil)
发表于 2023-3-29 20:18:29 | 显示全部楼层
sandyvs 发表于 2023-3-29 17:39
感谢!可以了,就是按esc,还会留下最后那个。是要加个错误处理吗?错误处理还不太会
加了错误处理,按ESC第一次不会留最后一个,之后还是会留下最后那个
发表于 2023-4-6 19:37:41 | 显示全部楼层
p-3-ianlcc 发表于 2023-4-6 17:29
火爆的人工智能改的如何?
真的有这麽便利吗?
对,但是只是改进,如果完全要它写一个全新的就不太行,好几个都不能运行,也可能是我表达能力还不够。
发表于 2023-3-29 16:49:54 | 显示全部楼层
感谢分享,就是不知怎么调整文字大小。
 楼主| 发表于 2023-3-29 17:39:28 | 显示全部楼层
ssyfeng 发表于 2023-3-29 15:51
修改一下这段试试:
((= code 25)  ; 鼠标右击
 楼主| 发表于 2023-3-29 17:40:32 | 显示全部楼层
刚开始 发表于 2023-3-29 16:49
感谢分享,就是不知怎么调整文字大小。
额,13年的老哥,不应该啊
发表于 2023-3-29 17:57:49 | 显示全部楼层
加个错误处理:
 楼主| 发表于 2023-3-29 22:35:26 | 显示全部楼层
我这没问题啊
发表于 2023-3-31 12:02:49 | 显示全部楼层
sandyvs 发表于 2023-3-29 17:40
额,13年的老哥,不应该啊
唉!今天请chap3.5修改成输入文字大小圆孔始终和文字一样大。
 楼主| 发表于 2023-3-31 12:15:30 | 显示全部楼层
可以将文字高度、圆半径与当前标注比例关联,改比例的画就一起变了
GMT+8, 2025-5-24 11:58 , Processed in 0.192105 second(s), 25 queries , Gzip On.
