查看: 1104|回复: 3
[基础] 《求助》前面表怎么变成后面的表
发表于 2023-4-12 20:22:26 | 显示全部楼层 |阅读模式
论坛的大神们,前面的表有什么办法变成后面的表
(("1500" "2900" "5 ") ("1500" "3100" "10 ")) → '("Rectangle,1500,2900,5,,,,1" "Rectangle,1500,3100,10,,,,1")
发表于 2023-4-12 20:32:20 | 显示全部楼层
  1. (setq lst '(("1500" "2900" "5") ("1500" "3100" "10")))
  2. (setq tmplst '())
  3. (foreach x lst
  4.         (setq temstr "Rectangle")
  5.         (foreach a x
  6.                 (setq temstr(strcat temstr "," a))
  7.         )
  8.         (setq tmplst (append tmplst (list (strcat (vl-string-right-trim " " temstr) ",,,,1"))))
  9. )
发表于 2023-4-12 20:49:50 | 显示全部楼层
我怎么感觉你是在走弯路呢,不如直接说你想干嘛,最终的目的
发表于 2023-4-12 21:14:13 | 显示全部楼层
  1. (setq lst '(("1500" "2900" "5 ") ("1500" "3100" "10 ")))
  2. (setq res
  3.        (mapcar '(lambda(x)
  4.            (strcat "Rectangle,"
  5.              (car x)","(cadr x)","(vl-string-trim " " (caddr x))
  6.              ",,,,1"))
  7.   lst))
GMT+8, 2025-5-14 18:55 , Processed in 0.165990 second(s), 25 queries , Gzip On.
