查看: 7862|回复: 66
[尺规拾趣] 求作已知三角形的内接直角三角形
发表于 2023-4-16 12:46:05 | 显示全部楼层 |阅读模式
网上看到的一道题。
参与人数 1明经币 +1 金钱 +21 收起 理由
qjchen + 1 + 21 赞一个!
发表于 2023-4-19 13:11:33 | 显示全部楼层
原来是调和点列的性质。
参与人数 1明经币 +1 金钱 +15 收起 理由
qjchen + 1 + 15 很给力!
发表于 2023-4-16 21:55:36 | 显示全部楼层
按照楼上大佬思路写的
  1. (defun c:tt(/ an b bf-curve-subsegment-picked-points bf-curve-subsegment-points c gs1- gs1+ gs2 h jd1 jd2 lm-3d2d lm-entmake-pline pt pt1 pt2 pt3 pts1 pts2 ptx ty x1 x2)
  2.         (defun BF-curve-subsegment-picked-Points (obj p)
  3.                 (BF-curve-subsegment-points
  4.                         obj
  5.                         (fix
  6.                                 (vlax-curve-getParamAtPoint
  7.                                         obj
  8.                                         (vlax-curve-getClosestPointTo obj (trans p 1 0))
  9.                                 )
  10.                         )
  11.                 )
  12.         )
  13.         (defun BF-curve-subsegment-points (curve n)
  14.                 (list
  15.                         (lm-3d2d(vlax-curve-getPointAtParam curve (fix n)))
  16.                         (lm-3d2d(vlax-curve-getPointAtParam curve (1+ (fix n))))
  17.                 )
  18.         )
  19.         (defun lm-3d2d (pt) (mapcar '+ '(0 0) pt))
  20.   (defun lm-entmake-pline (pldata / a s1 ptlst bihe co tc)
  21.                 (mapcar'set '(ptlst bihe co tc) pldata)
  22.                 (or co (setq co 256))
  23.                 (or tc (setq tc (getvar "clayer")))
  24.                 (entmake (append (list
  25.        '(0 . "LWPOLYLINE")
  26.        '(100 . "AcDbEntity")
  27.        '(100 . "AcDbPolyline")
  28.        (cons 62 co)
  29.        (cons 8 tc)
  30.        (cons 90 (length ptlst))
  31.        (cons 70 (if bihe 1 0))
  32.        (cons 38 (if (setq h(nth 2 (car ptlst))) h 0))
  33.        )
  34.                                                          (mapcar '(lambda (a) (cons 10 a)) ptlst))
  35.                 )
  36.                 (entlast)
  37.         )
  38.         (setq ty (car(entsel "选择三角形多段线:")))
  39.         (setq pts1(mapcar 'cdr (vl-remove-if-not '(lambda(x) (= (car x) 10) ) (entget ty))))
  40.         (setq pt (getpoint "\n指定D点:"))
  41.         (setq pts2(vl-sort (BF-curve-subsegment-picked-Points ty pt) '(lambda (p1 p2)(< (car p1) (car p2)))))
  42.         (foreach x pts2 (setq pts1(vl-remove x pts1)))
  43.         (setq
  44.                 pt1(car pts2)
  45.                 pt2(cadr pts2)
  46.                 pt3(car pts1)
  47.                 an1(angle pt pt1)
  48.                 h(distance pt pt3)
  49.                 b(distance pt pt1)
  50.                 c(distance pt pt2)
  51.         )
  52.         (setq gs1+(* h (+ (* 3.0 c) b (sqrt (* (+ b c (/ (* 2.0 b c) h)) (+ b c (- (/ (* 2.0 b c) h))))))))
  53.         (setq gs1-(* h(+ (* 3.0 c) b (- (sqrt (* (+ b c (/ (* 2.0 b c) h)) (+ b c (- (/ (* 2.0 b c) h)))))))))
  54.         (setq gs2(+ (/ (* 2 b c) h) (/ (* 4 h c) b) (* 2 h)))
  55.         (setq x1 (/ gs1+ gs2))
  56.         (setq x2 (/ gs1- gs2))
  57.         (setq ptx(polar pt an1 x1))
  58.         (setq jd1(inters ptx (polar ptx (+ an1 (* pi 0.5)) 0.5) pt1 pt3 nil))
  59.         (setq an(- (angle pt jd1) (* pi 0.5)))
  60.         (setq jd2(inters pt (polar pt an 0.5) pt2 pt3 nil))
  61.         (lm-entmake-pline(list (list pt jd1 jd2) t 4))
  62.         (setq ptx(polar pt pi x2))
  63.         (setq jd1(inters ptx (polar ptx (+ an1(* pi 0.5)) 0.5) pt1 pt3 nil))
  64.         (setq an(- (angle pt jd1) (* pi 0.5)))
  65.         (setq jd2(inters pt (polar pt an 0.5) pt2 pt3 nil))
  66.         (lm-entmake-pline(list (list pt jd1 jd2) t 3))
  67.         ;(entmake (list '(0 . "CIRCLE")'(100 . "AcDbEntity")'(100 . "AcDbCircle")(cons 62 1)(cons 10 pt)(cons 40 x1)))
  68.         ;(entmake (list '(0 . "CIRCLE")'(100 . "AcDbEntity")'(100 . "AcDbCircle")(cons 62 2)(cons 10 pt)(cons 40 x2)))
  69.         (princ)
  70. )
参与人数 1明经币 +1 金钱 +30 收起 理由
chenmik + 1 + 30 很给力!
发表于 2023-4-16 15:40:17 | 显示全部楼层
以D为坐标原点建立直角坐标,求出距离X。
发表于 2023-4-18 08:27:46 | 显示全部楼层
参与人数 5明经币 +4 金钱 +105 收起 理由
highflybird + 1 + 30 很给力!
qjchen + 2 + 15 很给力!
chenmik + 50 解得漂亮!
guosheyang + 1 很给力!
mahuan1279 + 10 很给力!
发表于 2023-4-18 10:53:55 | 显示全部楼层
再进一步,若AM/MD=n(n不等于1),还能做吗?
感觉有难度。  发表于 2023-4-18 12:11
 楼主| 发表于 2023-4-18 12:22:47 | 显示全部楼层
多谢各位大神的解答。这道作图题改编于下面这道证明题。我所知道的证法有点繁琐,各位大神有兴趣的也可证一下,看是否有更简洁的。
发表于 2023-4-18 13:05:59 | 显示全部楼层
如果AM/MD=2,那么只要把我的作图法中的圆半径改为AD/4并与AB相切,其他步骤一样,其他的n应该是同样的规律,我还没摸清楚。
发表于 2023-4-18 16:49:54 | 显示全部楼层
解出来了,AM:MD=n
在AD上取点P,使AD:PD=2*n,以P为圆心,PD为半径作圆,
其他作法不变。
参与人数 1金钱 +10 收起 理由
mahuan1279 + 10 漂亮的通姐!
发表于 2023-4-19 08:04:02 | 显示全部楼层
chenjun_nj 发表于 2023-4-18 16:49
解出来了,AM:MD=n
其他作法不变。
怎么证明呢?
GMT+8, 2025-5-20 20:16 , Processed in 0.189613 second(s), 26 queries , Gzip On.
