 - (setq col 1)
- (foreach n hd-lst (vlax-put-property xcells 'item (setq col(1+ col)) 1 n))
- (setq col 1)
- (foreach n st-lst (vlax-put-property xcells 'item (setq col(1+ col)) 2 n))
- (setq col 1)
- (foreach n gy-lst (vlax-put-property xcells 'item (setq col(1+ col)) 3 n))
- (setq col 1)
- (foreach n ncdl-lst (vlax-put-property xcells 'item (setq col(1+ col)) 4 n))
- (setq col 1)
- (foreach n qtld-lst (vlax-put-property xcells 'item (setq col(1+ col)) 5 n))
- (setq col 1)
- (foreach n gq-lst (vlax-put-property xcells 'item (setq col(1+ col)) 6 n))
- (setq col 1)
- (foreach n ktsm-lst (vlax-put-property xcells 'item (setq col(1+ col)) 7 n))
- (setq col 1)
- (foreach n hlsm-lst (vlax-put-property xcells 'item (setq col(1+ col)) 8 n))
- (setq col 1)
- (foreach n nczjd-lst (vlax-put-property xcells 'item(setq col(1+ col)) 9 n))
- (setq col 1)
- (foreach n glyd-lst (vlax-put-property xcells 'item (setq col(1+ col)) 10 n))
- (setq col 1)
- (foreach n gyyd-lst (vlax-put-property xcells 'item (setq col(1+ col)) 11 n))
