查看: 997|回复: 2
VC ActiveX 图形填充AddHatch调用AppendOuterLoop出错,有偿500rmb求解决
发表于 2023-4-26 01:03:29 | 显示全部楼层 |阅读模式
//定义矩形框的四个点
                int nPoints = 4;
                double x[4] = {100, 100, -100, -100};
                double y[4] = {-50, 50,  50,   -50};
                double *pPt = new double [nPoints*3];
                for(int i=0; i<nPoints; i++)
                        pPt[3*i]        = x[i];
                        pPt[3*i+1]        = y[i];
                        pPt[3*i+2]        = 0.0;
                //向AutoCAD输出矩形框
                COleSafeArray s1;
                VARIANT *pPointArray;
                s1.CreateOneDim(VT_R8, nPoints*3, pPt);
                pPointArray = (LPVARIANT)s1;
                LPDISPATCH        Object[1];                                                        //实体对象数组
                Object[0]                                = ModeSpace.AddPolyline(*pPointArray);
                IAcadPolyline PolyLine = (IAcadPolyline)Object[0];
                PolyLine.SetClosed(TRUE);                                                //闭环
                //调用填充函数
                HatchObjectType                = 0;
                VARIANT                                ObjectType;
                ObjectType.vt                = VT_I4;                        //指明整型数据
                ObjectType.lVal                = HatchObjectType;  //赋值
                IAcadHatch Hatch        = ModeSpace.AddHatch(0, "ANSI31", TRUE, ObjectType);
                //下面定义pObjectArray应该是出错了
                COleSafeArray s2;
                VARIANT *pObjectArray;
                s2.CreateOneDim(VT_DISPATCH, 1, PolyLine);
                pObjectArray = (LPVARIANT)s2;
                //调用这个函数出错Unhandled exception in test.exe: 0xC0000005: Access Violation
                Hatch.AppendOuterLoop(*pObjectArray);
                Hatch.Evaluate();
//有偿求解决,可加Q 152274848,回帖解决了问题也算
 楼主| 发表于 2023-4-26 01:05:30 | 显示全部楼层
刚发帖就解决了,很弱的一个错误,哎
 楼主| 发表于 2023-4-26 01:06:32 | 显示全部楼层
改为 s2.CreateOneDim(VT_DISPATCH, 1, Object);
GMT+8, 2025-5-25 10:23 , Processed in 0.225808 second(s), 23 queries , Gzip On.
