查看: 1158|回复: 4
[提问] 求输入tt,点击图块,获得属性的值到粘贴板
发表于 2023-5-25 16:33:23 | 显示全部楼层 |阅读模式
发表于 2023-5-25 17:33:39 | 显示全部楼层
图块可能有很多个属性,难道全部复制到剪切板么?
暂且这么认为吧
  1. (defun getatts(blk)
  2.   (if(equal(VL-CATCH-ALL-APPLY'vlax-get-property(list(setq blk(if(=(type blk)'ename)(vlax-ename->vla-object blk)blk))'HasAttributes)):vlax-true)
  3.     (mapcar(function(lambda(x)(strcat"\n"(strcase(vla-get-TagString x))"        "(vla-get-TextString x))))
  4.            (vlax-safearray->list(vlax-variant-value(vlax-invoke-method blk'GetAttributes))))))
  5. (defun c:tt(/ e atts Clip_board)
  6.   (vl-load-com)
  7.   (setq Clip_board(Vlax-Get-Property(Vlax-Get(vlax-create-object "htmlfile")'ParentWindow)'ClipboardData))
  8.   (while(setq e(ssget":E:S"'((0 . "insert")(66 . 1))))
  9.     (Vlax-Invoke Clip_board'SetData"text"(substr(apply'strcat(getatts(ssname e 0)))2)))
  10.   (vlax-release-object Clip_board))
 楼主| 发表于 2023-5-25 21:18:50 | 显示全部楼层
暂且这么认为吧
谢谢大佬........
发表于 2023-5-26 08:55:50 | 显示全部楼层
不错的帖子 顶一下
 楼主| 发表于 2023-5-26 20:40:15 | 显示全部楼层
兄弟希望你也能成为高手
GMT+8, 2025-5-9 16:43 , Processed in 0.258482 second(s), 26 queries , Gzip On.
