查看: 1811|回复: 9
如何得到vba制作的自定义菜单的菜单句柄?
发表于 2004-3-31 21:45:00 | 显示全部楼层 |阅读模式
我想在自定义下拉菜单实现像win98的垂直渐变条, Sub Menu()'转载的
'定义变量
Dim NewMenuGroup As AcadMenuGroup '群组
Dim NewMenu As AcadPopupMenu '列
Dim NewMenuItemName As AcadPopupMenuItem '菜单项
Dim Menuseparator As AcadPopupMenuItem '分隔条
Dim NewMenuItemName1 As AcadPopupMenu '菜单项
Dim subMenuItem
'子菜单
'定义下拉菜单群组
Set NewMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
'创建下拉菜单列
Set NewMenu = NewMenuGroup.Menus.Add("螺母")
'创建下拉菜单项
Set NewMenuItemName1 = NewMenu.AddSubMenu(NewMenu.Count + 1, "螺母1")
Set subMenuItem = NewMenu.Item(0).SubMenu.AddMenuItem(1, "螺母1", "-vbarun uf1 ")
Set subMenuItem = NewMenu.Item(0).SubMenu.AddMenuItem(2, "螺母1", "-vbarun uf2 ")
Set subMenuItem = NewMenu.Item(0).SubMenu.AddMenuItem(3, "螺母1", "-vbarun uf3 ")
Set subMenuItem = NewMenu.Item(0).SubMenu.AddMenuItem(4, "螺母1", "-vbarun uf4 ")
Set NewMenuItemName1 = NewMenu.AddSubMenu(NewMenu.Count + 2, "螺 母")
Set subMenuItem = NewMenu.Item(1).SubMenu.AddMenuItem(1, "六角螺母", "-vbarun uf5 ")
Set subMenuItem = NewMenu.Item(1).SubMenu.AddMenuItem(2, "开槽螺母", "-vbarun uf6 ")
Set subMenuItem = NewMenu.Item(1).SubMenu.AddMenuItem(3, "圆 螺 母", "-vbarun uf7 ")
Set subMenuItem = NewMenu.Item(1).SubMenu.AddMenuItem(4, "蝶形螺母", "-vbarun uf8 ")
Set NewMenuItemName1 = NewMenu.AddSubMenu(NewMenu.Count + 3, "销类零件")
Set subMenuItem = NewMenu.Item(2).SubMenu.AddMenuItem(1, "圆 柱 销", "-vbarun uf9 ")
Set subMenuItem = NewMenu.Item(2).SubMenu.AddMenuItem(2, "圆 锥 销", "-vbarun uf10 ")
Set subMenuItem = NewMenu.Item(2).SubMenu.AddMenuItem(3, "开 口 销", "-vbarun uf11 ")
Set subMenuItem = NewMenu.Item(2).SubMenu.AddMenuItem(4, "A型销轴", "-vbarun uf12 ")
Set NewMenuItemName = NewMenu.AddSeparator(NewMenu.Count + 4)
Set NewMenuItemName = NewMenu.AddMenuItem(NewMenu.Count + 6, "退 出", "-vbarun uf60 ")
'显示新菜单
NewMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Sub 上述是网上仁兄的借用的 我使用SetBitmap加入图片,我想得到句柄,不知如何得到
 楼主| 发表于 2004-4-3 19:40:00 | 显示全部楼层
我想得到菜单对象的handle,不知如何才能得到?
 楼主| 发表于 2004-4-3 19:46:00 | 显示全部楼层
我有vb下自定义下拉菜单实现像win98的垂直渐变条的例子,不知哪位仁兄仁妹能把vb下转为vba将他们合二为一,我将感激不尽,想要源码我给
发表于 2004-4-3 22:51:00 | 显示全部楼层
发给我看看吧,我最近的毕业设计好象跟你有点相似。gzy@mjtd.com
发表于 2004-4-4 15:11:00 | 显示全部楼层
首先得到Application对象的句柄,然后使用GetMenu返回菜单,GetSubMenu返回它的子菜单,以后的操作全部使用相关的API来操作了。
 楼主| 发表于 2004-4-4 22:00:00 | 显示全部楼层
我已发了,得到答案希望能够回复我,我感激不尽
 楼主| 发表于 2004-4-4 22:14:00 | 显示全部楼层
to :gzy 引用你的代码,不反对吧?
发表于 2004-4-5 01:14:00 | 显示全部楼层
murphyr发表于2004-4-4 22:14:00to :gzy 引用你的代码,不反对吧?
没有关系!反正又不是重要的代码,一个菜单而已,很多书上都有的。 另外:EMAIL我已经收到,明天再答复你,今天太晚了,都1点多了,呵呵!
 楼主| 发表于 2004-4-8 13:22:00 | 显示全部楼层
gzy谢谢你,能够得到你的帮助,
 楼主| 发表于 2004-4-9 22:52:00 | 显示全部楼层
不知gzy斑竹解决了否,我又找到了一个关于写垂直条的代码,原理和原有的不一样,好像似api函数直接画的渐变条,我功力浅,有些看不懂,斑竹是否要?
GMT+8, 2025-5-25 20:56 , Processed in 0.193596 second(s), 24 queries , Gzip On.
