查看: 1524|回复: 8
[提问] 如何rtos函数怎么保留输入数值末尾的0,如输入1.200,文字则显示为1.200
发表于 2023-6-26 16:45:42 | 显示全部楼层 |阅读模式
    1. (defun c:AQ(/ ang p0 p1 p2 p3 pc pd tt xz1)
    2.   (vl-load-com)
    3.   (setvar "cmdecho" 0)
    4.   (setq TCBF (getvar "clayer"))
    5.   (setvar "osmode" 16383)
    6.   (or t3 (setq t3 '(0.950)))
    7.   (mapcar 'set '( t2 ) t3)
    8.   (if (setq t1 (getreal (strcat "\n默认高度<" (rtos T2 2 3) ">: ")))
    9.     (setq t2 t1)
    10.   )
    11.     (setq t3 (list t2 ))
    12.   (setq p0 (getpoint "\n指定第一点:"))
    13.   (setq p1 (getpoint p0 "\n指定第二点:"))
    14.   (setq P2 (polar P1 (- (angle P0 P1) (/ PI 2)) 200))
    15.   (setq P3 (polar P0 (- (angle P0 P1) (/ PI 2)) 200))
    16.   (setq ang (angle p0 p1))
    17.   (setq ang (atoi (angtos ang 0 0)))
    18.   (while (> ang 90) (setq ang (- ang 180)))
    19.   (setq ang (/ (* ang pi) 180))
    20.   (setq pc (polar p0 (angle p0 p2) (/ (distance p0 p2) 2)))
    21.   (setq PD (polar PC (- (angle P0 P1) (/ Pi 2)) 200))
    22.   (setq tt (strcat  "CT:Hs+" (rtos (abs T2) 2 3)))
    23.   (setvar "OSMODE" 0)
    24.   (command "layer" "m" "T-窗台" "c" "120" "T-窗台" "")
    25.   (command "PLINE" P0 P1 P2 P3 "C")
    26.   (setq xz1 (entlast))
    27.   (command "-HATCH" "P" "AR-HBONE" "" ang "S" XZ1 "" "")
    28.   (entmake
    29.     (list
    30.       '(0 . "text")
    31.       (cons 8 "T-窗台")
    32.       (cons 72 4)
    33.       (cons 1 TT)
    34.       (cons 41 0.6)
    35.       (cons 10 pD)
    36.       (cons 11 pD)
    37.       (cons 40 120)
    38.       (cons 50 ang)
    39.       (cons 7 "Standard")
    40.     )
    41.   )
    42.   (setvar "clayer" TCBF)
    43.   (setvar "cmdecho" 1)
    44.   (prin1)
    45. )
发表于 2023-6-27 13:46:51 | 显示全部楼层
rtos 受 dimzin 变量控制,临时将 dimzin 设置为 0,命令完成后恢复现场。
发表于 2023-6-26 17:05:44 | 显示全部楼层
  2.   (vl-load-com)
  6.   (setq dimzin (getvar "dimzin"))
  7.   (setvar "dimzin" 0)
  8.   (or t3 (setq t3 '(0.950)))
  9.   (mapcar 'set '( t2 ) t3)
  10.   (if (setq t1 (getreal (strcat "\n默认高度<" (rtos T2 2 3) ">: ")))
  11.     (setq t2 t1)
  12.   )
  13.   (setq t3 (list t2 ))
  14.   (setq p0 (getpoint "\n指定第一点:"))
  15.   (setq p1 (getpoint p0 "\n指定第二点:"))
  16.   (setq P2 (polar P1 (- (angle P0 P1) (/ PI 2)) 200))
  17.   (setq P3 (polar P0 (- (angle P0 P1) (/ PI 2)) 200))
  18.   (setq ang (angle p0 p1))
  19.   (setq ang (atoi (angtos ang 0 0)))
  20.   (while (> ang 90) (setq ang (- ang 180)))
  21.   (setq ang (/ (* ang pi) 180))
  22.   (setq pc (polar p0 (angle p0 p2) (/ (distance p0 p2) 2)))
  23.   (setq PD (polar PC (- (angle P0 P1) (/ Pi 2)) 200))
  24.   (setq tt (strcat  "CT:Hs+" (rtos (abs T2) 2 3)))
  25.   (setvar "dimzin" dimzin)
  26.   (setvar "OSMODE" 0)
  27.   (command "layer" "m" "T-窗台" "c" "120" "T-窗台" "")
  28.   (command "PLINE" P0 P1 P2 P3 "C")
  29.   (setq xz1 (entlast))
  30.   (command "-HATCH" "P" "AR-HBONE" "" ang "S" XZ1 "" "")
  31.   (entmake
  32.     (list
  33.       '(0 . "text")
  34.       (cons 8 "T-窗台")
  35.       (cons 72 4)
  36.       (cons 1 TT)
  37.       (cons 41 0.6)
  38.       (cons 10 pD)
  39.       (cons 11 pD)
  40.       (cons 40 120)
  41.       (cons 50 ang)
  42.       (cons 7 "Standard")
  43.     )
  44.   )
  45.   (setvar "clayer" TCBF)
  46.   (setvar "cmdecho" 1)
  47.   (prin1)
  48. )
发表于 2023-6-26 16:51:49 | 显示全部楼层
(rtos x 2 3)?不要abs
 楼主| 发表于 2023-6-26 17:11:23 | 显示全部楼层
谢谢大佬,之前找到了这个方式,放错位置了,一直没搞明白
 楼主| 发表于 2023-6-26 17:13:08 | 显示全部楼层
yaojing38 发表于 2023-6-26 16:51
(rtos x 2 3)?不要abs
这样不行,我试过了
发表于 2023-6-26 18:45:09 | 显示全部楼层
(setvar 'dimzin 0)
发表于 2023-6-26 21:20:34 | 显示全部楼层
我是取小数后,按剩余长度,另外补零的。
发表于 2023-6-30 20:34:48 | 显示全部楼层
又学习了一招
GMT+8, 2025-2-19 06:57 , Processed in 0.159914 second(s), 26 queries , Gzip On.
