查看: 1417|回复: 7
[源码] 请大师帮忙在路径后面加个当前文件的文件名
发表于 2023-7-7 16:30:47 | 显示全部楼层 |阅读模式
原贴:快速插入单行文字,记忆文字高度,或居中插入自动计算高度
http://bbs.mjtd.com/forum.php?mo ... amp;fromuid=7331742
(出处: 明经CAD社区)
请大师帮忙在路径后面加个当前文件的文件名、字体能用两点确认(或者缩放)
(defun C:TT1()
                (defun *error* (msg)(setvar "osmode" os0))
        (if (not(tblsearch "style" "MY"))(vl-cmdf "-style" "MY" "gbenor.shx,hztxt.shx" "" 0.8 "" "" "" ""))
        (if (not(tblsearch "layer" "A-TEXT")) (vl-cmdf "-layer" "N" "A-TEXT" "c" "7" "A-TEXT" "p" "p" "A-TEXT" ""))
        (setvar "cmdecho" 0)
        (setq os0 (getvar "osmode"))
        (setq xmnr (getvar "dwgprefix"))
                                (setvar "osmode" (+ os0 16384))
        (setq inpt (getpoint "\n指定插入点:"))
        (entmake (list '(0 . "TEXT") (cons 1 xmnr) (cons 8 "A-TEXT") (cons 7 "MY") (cons 41 0.7) (cons 72 0)(cons 73 1) (cons 10 inpt) (cons 11 inpt) (cons 40 50)))
        (entmake)
        (setvar "cmdecho" 1)
发表于 2023-7-7 18:39:46 | 显示全部楼层
liuhe 发表于 2023-7-7 16:51
你都不愿意自己学学么?,  全是伸手党啊
最神的是:求助免费,分享搬运来的免费插件收币
发表于 2023-7-7 17:20:30 | 显示全部楼层
  1. (defun C:TT5()
  2.   (defun *error* (msg)
  3.     (setvar "osmode" os0) ; 错误处理函数,将osmode恢复为原始值
  4.   )
  5.   (if (not (tblsearch "style" "MY")) ; 如果样式表中不存在名为"MY"的样式
  6.     (vl-cmdf "-style" "MY" "gbenor.shx,hztxt.shx" "" 0.8 "" "" "" "") ; 创建名为"MY"的样式
  7.   )
  8.   (if (not (tblsearch "layer" "A-TEXT")) ; 如果图层表中不存在名为"A-TEXT"的图层
  9.     (vl-cmdf "-layer" "N" "A-TEXT" "c" "7" "A-TEXT" "p" "p" "A-TEXT" "") ; 创建名为"A-TEXT"的图层
  10.   )
  11.   (setvar "cmdecho" 0) ; 关闭命令行回显
  12.   (setq os0 (getvar "osmode")) ; 获取当前osmode的值并保存到变量os0中
  13.   (setq xmnr (strcat (getvar "dwgprefix") (getvar "dwgname"))) ; 获取当前文件名并添加为前缀
  14.   (setvar "osmode" (+ os0 16384)) ; 将osmode设置为os0的值加上16384
  15.   (setq inpt (getpoint "\n指定插入点:")) ; 获取用户指定的插入点
  16.   (setq txtHt (getreal "\n指定文字高度:")) ; 获取用户指定的文字高度
  17.   (entmake (list '(0 . "TEXT") (cons 1 xmnr) (cons 8 "A-TEXT") (cons 7 "MY") (cons 40 txtHt) (cons 72 0) (cons 73 1) (cons 10 inpt) (cons 11 inpt) (cons 50 0))) ; 创建一个TEXT实体
  18.   (setvar "osmode" os0) ; 恢复osmode的值为原始值
  19.   (setvar "cmdecho" 1) ; 打开命令行回显
  20. )
  21. (princ) ; 输出结果
zwq8629 + 1
发表于 2023-7-7 16:51:49 | 显示全部楼层
你都不愿意自己学学么?,  全是伸手党啊
 楼主| 发表于 2023-7-7 17:02:07 | 显示全部楼层
你都不愿意自己学学么?,  全是伸手党啊
才接触,只会搞一点点
 楼主| 发表于 2023-7-7 18:31:15 | 显示全部楼层
谢谢,我没用上"strcat",连不起来
发表于 2023-7-7 19:17:00 | 显示全部楼层
我也是抄的,哈哈
 楼主| 发表于 2023-7-7 20:03:25 | 显示全部楼层
请看仔细点,我有币时我那次没给的
GMT+8, 2025-5-14 19:14 , Processed in 0.172349 second(s), 26 queries , Gzip On.
