查看: 2855|回复: 13
[源码] 引线标注
发表于 2023-8-7 08:27:43 | 显示全部楼层 |阅读模式
  1. (defun c:tb1(/ k pt1 pt2  pt3 pt4 pt5 pt6 pt7 pt8 t1 t2 t3 P4 pt1_mid chklay wordstr dd dcl_id word_list vvs l_ast l_ast1)
  2. (HJSZ)
  3.    (setvar "cmdecho" 0)
  4.    (setq word_list'("TB2012-1" "TS2012-2"  "15J401" "02J331"))
  5.    (chk_style)
  6.    (dcl_tb)
  7.    (HFHJSZ)
  8.    (prin1)
  9. )
  10. (defun dcl_tb(/ dd dcl_id)
  11. (if (not jd1) (setq jd1 "0"))
  12. (if (not jd2) (setq jd2 "0"))
  13.    (setq dcl_id (load_dialog "tb"))
  14.    (new_dialog "tb" dcl_id)
  15.    (start_list "klist")
  16.    (mapcar 'add_list word_list)
  17.    (end_list)
  18.    (set_tile "klist" "0")
  19.    (sub_klist "0")
  20.   ;;(if (= jd1 "1" )(setq jd2 "0"))
  21. ;;(if (= jd2 "1" )(setq jd1 "0"))
  22.    (set_tile "rb1" jd1)
  23.    (set_tile "rb2" jd2)
  24.    ;(setq th1 (get_attr rb1 "label"))
  25.    ;(setq th2 (get_attr rb2 "label"))
  26.    ;(if(= th1 "加圆圈") (mode_tile "rb1" 0)(mode_tile  "rb2" 1))
  27.    ;(if(= th2 "加点") (mode_tile "rb2" 0)(mode_tile  "rb1" 1))
  28.    (action_tile "klist" "(sub_klist $value)")
  29.    (action_tile "accept" "(ok_tb)(done_dialog 1)")
  30.    (setq dd(start_dialog))
  31.    (if (= dd 1)
  32.        (progn
  33. (setvar "cmdecho" 0)
  34. (setvar "osmode" 0)
  35.            (setq pt1 (getpoint "\n索引区域中心点位置:"))
  36.        (if  ( = jd1 "1")
  37.    (progn
  38.    (command "circle" pt1 pause )
  39.    (setq l_ast (entlast))
  40.    )
  41.    )
  42.    (if  ( = jd2 "1")
  43.    (command "Donut" "0" "80" pt1 "")
  44.    )
  45. (setq pt2 (getpoint pt1 "\n索引线转折点:"))
  46. (command "line" "non" pt1 pt2 "")
  47. (setq l_ast1 (entlast))
  48. (if  ( = jd1 "1")
  49. (command "trim" l_ast "" (list l_ast1 pt1) "")
  50. )
  51. (setVar "OrthoMode" 1)
  52. (setq pt5 (getpoint pt2 "\n索引符号方位:"))
  53. (setq k (angle pt2 pt5))
  54. (setq pt3 (polar pt2 k 2200))
  55. (setq pt4 (polar pt3 k 1000))
  56. (setq pt6 (mid_pt pt3 pt4))
  57. (setq pt7 (polar pt6 (* pi 0.5) 200)) ;索引号定位点
  58. (setq pt8 (polar pt6 (* pi -0.5) 210));图集页码号定位点
  59. (command "line" "non" pt2 pt4 "")
  60. (command "circle"  "2p" "non" pt3  "non" pt4)
  61. (setq pt1_mid (mid_pt pt2 pt3)
  62.       p4   (polar pt1_mid (* 0.5 pi) 100) ;;文字起点
  63.       )
  64.     (command "-text" "j" "c" p4 350 0 wordstr )
  65.     (command "-text" "j" "m" pt7 350 0 t1)
  66.     (command "-text" "j" "m" pt8 350 0 t2)
  67.        )
  68.    )
  69. )
  70. (defun sub_klist(vvs)
  71.    (set_tile "wordstr" (nth (atoi vvs) word_list))
  72. )
  73. (defun ok_tb()
  74.    (setq wordstr(get_tile "wordstr"))
  75.    (setq t1(get_tile "syh"))
  76.    (setq t2(get_tile "tyh"))
  77.    (setq jd1 (get_tile "rb1"))
  78.    (setq jd2 (get_tile "rb2"))
  79. )
  80. (defun chk_style();检查字型
  81.      (setq chklay(tblsearch "layer" "文字"))
  82.      (if (null chklay)
  83.    (command "layer" "m" "文字" "c" "3" "" "lt" "CONTINUOUS" "" "");文字图层
  84.          ;(command "_layer" "m" "文字" "c" "3" "文字" "")
  85.      )
  86.      (setvar "clayer" "文字")
  87. )
 楼主| 发表于 2023-8-7 08:32:13 | 显示全部楼层
tb:dialog{
label="图集大样选用";
:list_box{
label="常用图集编号";
key="klist";
width=30;
height=10;
fixed_width_font=true;
:edit_box{label="图集编号";key="wordstr";}
:row{
fixed_width=true;
alignment=centered;
:edit_box{label="索引代号";key="syh";edit_width=4;}
:edit_box{label="图集页码";key="tyh";edit_width=4;}
:row{
:toggle{label="加圆圈";alignment=centered; key="rb1";}
:toggle{label="加点";alignment=centered; key="rb2";}
spacer_1;                //空开一列
ok_cancel;
参与人数 1明经币 +1 金钱 +5 收起 理由
tigcat + 1 + 5 很给力!
 楼主| 发表于 2023-8-7 08:30:54 | 显示全部楼层
(HJSZ)
   (chk_style)
   (dcl_tb)
   (HFHJSZ)
   (prin1)
   (end_list)
   (sub_klist "0")
   (if (= dd 1)
(setvar "osmode" 0)
                   (if  ( = jd1 "1")
   (if  ( = jd2 "1")
(if  ( = jd1 "1")
(defun ok_tb()
     (if (null chklay)
这个程序的加圆圈和加点怎么设置成互换的样式,点了加点就不能点加圆圈,反之亦然
 楼主| 发表于 2023-8-10 09:39:28 | 显示全部楼层
 楼主| 发表于 2023-8-10 09:40:55 | 显示全部楼层
就是这里的选项只能选一个,相互制约
发表于 2023-8-10 09:43:42 | 显示全部楼层
用radio_button替换toggle
 楼主| 发表于 2023-8-10 09:58:44 | 显示全部楼层
radio_button应该是必选一个吧,这里大部分是两个都不选
发表于 2023-8-10 13:44:59 | 显示全部楼层
三个button,加个无不就是了
发表于 2023-8-11 08:26:56 | 显示全部楼层
缺少子程序呢 HJSZ 和 HFHJSZ
GMT+8, 2025-4-21 18:01 , Processed in 0.247473 second(s), 30 queries , Gzip On.
