查看: 1163|回复: 3
[提问] 文本框取值
发表于 2023-8-12 21:24:54 | 显示全部楼层 |阅读模式
小白,参照别人代码写了个工具
请大神补充一下,要求运行 点取 取值按钮将选取的文本显示在 文本框窗体中。
代码中(defun GL:qz (),没有写[size=22.0875pt]
  1. (vl-load-com)
  2. (defun c:tc (/ fname fn x dclid lin)
  3.   (setq fname (vl-filename-mktemp nil nil ".dcl" ))
  4.   (setq fn (open fname "w" ))
  5.   (foreach x '(
  6.
  7.                 "  agtckz : dialog{"
  8.                 "  label="文本取值求和 V1.0";"
  9.                 "     :row{"
  10.                 "     :boxed_column{"
  11.                 "     :row{"
  12.                 "      :edit_box {key = "1";label = "求和";width = 240;height = 4;value ="3";}"
  13.                 "     }"
  14.                 "     :row{"
  15.                 "      :button{key="2";label="取值";width=16;}"
  16.                 "     cancel_button;"
  17.                 "     }"
  18.                 "     }"
  19.                 "     }"
  20.                 "}"
  21.               );end ;endlist
  22.     (princ x fn)
  23.     (write-line "" fn)
  24.   );end foreach
  25.   (close fn)
  26.   (setq fn (open fname "r" ))
  27.   (setq dclid (load_dialog fname))
  28.   (while (or (eq (substr (setq lin (vl-string-right-trim "" fn)" (vl-string-left-trim "(write-line "" (read-line fn)))) 1 2) "//" ) (eq (substr lin 1 (vl-string-search " " lin)) "" ) (not (eq (substr lin (+ (vl-string-search " " lin) 1) 9) " : dialog" ))))
  29.   (new_dialog (substr lin 1 (vl-string-search " " lin)) dclid)
  30.   (action_tile "2" "(done_dialog 2)" )
  31.   (setq re (start_dialog))
  32.   (cond
  33.     ((= re 2) (GL:qz))
  34.
  35.   );end cond
  36.   ;(unload_dialog dclid)
  37.   ;(close fn)
  38.   ;(vl-file-delete fname)
  39.   (princ)
  40. )
  41. (defun GL:qz ()
  42.     )
发表于 2023-8-12 22:47:41 | 显示全部楼层
 楼主| 发表于 2023-8-13 12:16:06 | 显示全部楼层
GMT+8, 2025-2-23 14:11 , Processed in 0.188928 second(s), 25 queries , Gzip On.
