查看: 1299|回复: 2
[源码] 由于CAD刷新不彻底导致的字体乱码
发表于 2023-8-17 10:23:47 | 显示全部楼层 |阅读模式
画图过程中发现某些字体乱码,这些问题编辑一下或换个样式再换回来均能显示正常,基于此写下以下代码解决此问题:
  1. (defun C:RGT ( )
  2.   (setvar "cmdecho" 0)
  3.   (vl-load-com)
  4.   (setq ss (ssget "X" '((0 . "DIMENSION,TEXT,MTEXT"))))
  5.   (if ss
  6.     (progn
  7.       (setq len (sslength ss))
  8.       (setq n 0)
  9.       (repeat len
  10.         (setq ent (ssname ss n))
  11.         (setq entdata (entget ent))
  12.         (if (assoc 1 entdata)
  13.           (progn
  14.             (setq txt (cdr (assoc 1 entdata)))
  15.             (setq entdata (subst '(1 . "") (assoc 1 entdata) entdata))
  16.             (entmod entdata)
  17.             (setq entdata (subst (cons 1 txt) (assoc 1 entdata) entdata))
  18.             (entmod entdata)
  19.           )
  20.         )
  21.         (setq n (+ 1 n))
  22.       )
  23.     )
  24.   )
  25.   (setq acadObj (vlax-get-acad-object))
  26.   (setq doc (vla-get-activedocument acadObj))
  27.   ; (setq mspace (vla-get-mspace doc))
  28.   (setq n 0)
  29.   (setq Blocks (vla-get-blocks doc))
  30.   (vlax-for temptBlock Blocks  ;vla-item Blocks 2
  31.     (if (> n 1)
  32.       (progn
  33.         (setq blk_name (vla-get-Name temptBlock))
  34.         (setq blkr (tblsearch "block" blk_name)) ;获取 存储块的链表
  35.         (setq blkent (cdr (assoc -2 blkr))) ;获取块的第一个组成实体
  36.         (setq blkentdata (entget blkent))
  37.         (setq datatype (cdr (assoc 0 blkentdata)))
  38.         (if (or (= datatype "MTEXT") (= datatype "TEXT") (= datatype "DIMENSION"))
  39.           (progn
  40.             (setq txt (cdr (assoc 1 blkentdata)))
  41.             (setq blkentdata (subst '(1 . "") (assoc 1 blkentdata) blkentdata))
  42.             (entmod blkentdata)
  43.             (setq blkentdata (subst (cons 1 txt) (assoc 1 blkentdata) blkentdata))
  44.             (entmod blkentdata)
  45.             (print txt)
  46.           )
  47.         )
  48.         (setq blkent (entnext blkent)) ;获取块的第二个组成实体
  49.         (while blkent
  50.           (setq blkentdata (entget blkent))
  51.           (setq datatype (cdr (assoc 0 blkentdata)))
  52.           (if (or (= datatype "MTEXT") (= datatype "TEXT") (= datatype "DIMENSION"))
  53.             (progn
  54.               (setq txt (cdr (assoc 1 blkentdata)))
  55.               (setq blkentdata (subst '(1 . "") (assoc 1 blkentdata) blkentdata))
  56.               (entmod blkentdata)
  57.               (setq blkentdata (subst (cons 1 txt) (assoc 1 blkentdata) blkentdata))
  58.               (entmod blkentdata)
  59.               (print txt)
  60.             )
  61.           )
  62.           (setq blkent (entnext blkent))
  63.         )
  64.       )
  65.     )
  66.     (setq n (+ 1 n))
  67.   )
  68.   (command "REGEN")
  69.   (prin1)
  70. )
请各位老师指点:
发表于 2023-8-17 11:26:00 | 显示全部楼层
没有遇到过这种问题,发个测试图看看呢
发表于 2023-8-17 14:49:29 | 显示全部楼层
以前还发生过字体乱码后无法恢复的情况,换台电脑都打开都是乱码
GMT+8, 2025-9-14 04:54 , Processed in 0.153603 second(s), 24 queries , Gzip On.
