查看: 1305|回复: 2
[提问] 各位大哥帮忙看下,拉进CAD界面加载就正常,设置启动组,自动加载就没了边框线
发表于 2023-8-19 11:51:12 | 显示全部楼层 |阅读模式
1明经币
各位大哥帮忙看下,这个拉进CAD界面加载就正常,可是设置启动组,自动加载就没了边框线 ,我看了函数都没哪里有问题啊,请各位大佬指点下
;;快速填充command版本
;;code by edata@mjtd
;;2014-6-16
;;变函数参数
;;(sk_hatch_cmd sk_ha_name sk_ha_scale sk_ha_ang)
;;sk_ha_name 填充名字符串
;;sk_ha_scale 填充比例 数字或数字字符串
;;sk_ha_ang 填充角度 0-360度数字或数字字符串
;;例子(sk_hatch_cmd "earth" 100 0.0)
(defun sk_hatch_cmd( sk_ha_name sk_ha_scale sk_ha_ang / bak_clay bak_col bak_cmd en0 en1 en2 p1 p3)
  (or sk_ha_name (setq sk_ha_name "earth"))
  (or sk_ha_scale (setq sk_ha_scale 100))
  (or sk_ha_ang (setq sk_ha_ang 0.0))
  (setq bak_clay(getvar 'clayer)
        bak_col(getvar 'cecolor)
        bak_cmd(getvar 'cmdecho)
  (if(not(tblobjname "layer" "00-填充"))
    (entmake (list '(0 . "LAYER")
                   '(100 . "AcDbSymbolTableRecord")
                   '(100 . "AcDbLayerTableRecord")
                   '(70 . 0)
                   '(6 . "Continuous")
                   (cons 2 "00-填充")
                   (cons 62 251)
  (setvar 'cmdecho 0)
  (while (and(setq p1(getpoint "\n指定第一点:"))
                 (setq p3(getcorner p1 "\n指定对角点:"))
      (if(> (getvar 'cmdactive) 0)(command))
      (setq en0(entlast))
      (command "_.RECTANG" "_non" p1 "_non" p3)
      (command "change" (entlast) "" "P" "C" 8 "")
      (setq en1(entlast))
      (command "-bhatch" "p" sk_ha_name sk_ha_scale sk_ha_ang "s" en1 "" "")
      (command "change" (entlast) "" "P" "la" "00-填充" "")
      (setq en2(entlast))
      (if(sk_h5_eq en1 en2)
        (alert "创建填充失败.")
        (if (not(sk_h5_eq en1 en0)) (entdel en1))
  (and bak_clay(setvar 'clayer bak_clay))
  (and bak_col(setvar 'cecolor bak_col))
  (and bak_cmd(setvar 'cmdecho bak_cmd))
(defun sk_dxf(ent code)(cdr(assoc code (entget ent))))
(defun sk_h5_eq(ent1 ent2)
  (= (sk_dxf ent1 5)(sk_dxf ent2 5))
(defun c:RF()
  (sk_hatch_cmd "CORK" 25 0.0)
(defun c:RFF()
  (sk_hatch_cmd "ANSI38" 30 0.0)
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
没啥问题。但是也不用这么繁琐的代码吧? 我自己是这样用的:
发表于 2023-8-19 11:51:13 | 显示全部楼层
没啥问题。但是也不用这么繁琐的代码吧?
我自己是这样用的:
  1. (defun c:hh (/ en ly *error* err myerr)
  2.   (defun myerr (msg)
  3.     (setvar 'CLAYER ly)
  4.     (setq *error* err)
  5.   )
  6.   (setq err *error* *error* myerr)
  7.   (setvar 'CMDECHO 0)
  8.   (setq ly (getvar 'CLAYER))
  9.   (if (= (tblsearch "layer" "HAT") nil)
  10.     (command "layer" "N" "HAT" "l" "Continuous" "HAT" "c" 8 "HAT" "")
  11.   )
  12.   (setvar 'CLAYER "HAT")
  13.   (command "_.rectang" pause pause)
  14.   (command "_.hatch" "ansi37" "1" "0" "L" "")
  15.   (setvar 'CLAYER ly)
  16.   (princ)
  17. )
 楼主| 发表于 2023-8-19 15:08:06 | 显示全部楼层
gaics 发表于 2023-8-19 13:47
没啥问题。但是也不用这么繁琐的代码吧?
我自己是这样用的:
谢谢大佬,可能是我这边插件冲突了
GMT+8, 2025-10-20 04:11 , Processed in 0.128389 second(s), 25 queries , Gzip On.
