查看: 3174|回复: 19
七夕撩妹心形(其实像苹果)
发表于 2023-8-22 11:00:13 | 显示全部楼层 |阅读模式
  1. <div class="blockcode"><blockquote>
  2. (defun C:tt ( / center center2 dist)
  3.   (setq acad (vlax-get-acad-object))
  4.   (setq dist 100)  ;制心形大小
  5.   (setq center (getpoint "\n指定点:"))
  6.   (makeheart  dist center)
  7.   (setq center2 (polar center 0 200))
  8.   (makeheart  dist center2)
  9.   (vla-zoomwindow
  10.     acad
  11.     (vlax-3d-point center)
  12.     (vlax-3d-point center2)
  13.   )
  14.   (vla-ZoomScaled acad 0.2 acZoomScaledRelative)
  15.   (princ)
  16.   )
  17. (defun ang2rad (ang) (* pi (/ ang 180.)))
(defun makeheart (dist center / e10 inpt plt r rad rang p1 p2)
(setq plt nil)
(setq p1 (polar center -1.5708 100))
(setq p2 (polar p1 0 -70))
(setq rang 0)
(entmake(list(cons 0 "TEXT")
                  (cons 1 "搞钱!搞钱!别瞎想!")
                  (cons 10 p2)
                  (cons 62 1)
                  (cons 40 15)
  (repeat 361
    (setq rad (ang2rad rang))
    (setq r (* dist (- 1 (sin rad))))
    (setq inpt (polar center rad r))
    (setq rang (+ 1 rang))
    (setq plt (cons inpt plt))
  (setq ent (entmakex
      (append (list '(0 . "LWPOLYLINE")
                    '(100 . "AcDbEntity")
                    '(100 . "AcDbPolyline")
                    (cons 8 "heart")
                    (cons 90 (length plt))
                    (cons 43 0)
                    (cons 62 1)
              (mapcar '(lambda (e10) (cons 10 e10)) plt)
              '((210 0. 0. 1.))
;(command "zoom" "ob" ent "")
参与人数 2明经币 +2 收起 理由
baitang36 + 1 更像苹果
tigcat + 1 很给力!
发表于 2023-8-22 13:38:47 | 显示全部楼层
  1. (DEFUN C:W1 (/ a num i p0 lst e)
  2.   (SETQ        A  300 ;;;;;控制图形大小
  3.         num a;;;控制数量
  4.         i 10;;;控制颜色
  5.         h 1;;;;控制递减间隔
  6.   )
  7.   (SETQ P0(GETPOINT"\n请插入点"))
  8.   (if(not p0)(vl-exit-with-value 0))
  9.   (REPEAT num
  10.     (SETQ LST (QQ1 A)
  11.           E   (EntmakeSpline LST)
  12.           A   (- A h)
  13.           i(1+ i)
  14.     )
  15.     (IF (<= (/ NUM I )2)(SETQ I 1));;;;控制颜色循环
  16.     (VLA-PUT-COLOR (vlax-ename->vla-object (ENTLAST))I)
  17.     (vla-move (vlax-ename->vla-object (ENTLAST))
  18.               (vlax-3D-point (list 0 0 0))
  19.               (vlax-3D-point p0)
  20.     )
  21.   )
  22.     (redraw)
  23. )
  24. (defun EntmakeSpline (pts / PT)
  25.   (entmakeX
  26.     (append
  27.       (list '(0 . "SPLINE")
  28.             '(100 . "AcDbEntity")
  29.             '(100 . "AcDbSpline")
  30.             '(71 . 6)
  31.       )
  32.       (mapcar '(lambda (pt) (cons 11 pt)) pts)
  33.     )
  34.   )
  35. )
  36. (DEFUN QQ (A  / LST I p0);;;;;苹果
  37.
  38.   (SETQ        I   0
  39.         LST '()
  40.         p0  (list 0 0 0)
  41.   )
  42.   (REPEAT 361
  43.     (SETQ I   (1+ I)
  44.           P1  (POLAR P0
  45.                      (* I (/ PI 180))
  46.                      (* A (- 1 (SIN (* I (/ PI 180)))))
  47.               )
  48.           LST (CONS P1 LST)
  49.     )
  50.   )
  51. (vl-remove 'nil lst)
  52. )
  53. (DEFUN QQ1 (A  / LST I I1 P1);;;;桃子
  54.   (SETQ        I   0
  55.         LST '()
  56.   )
  57.   (REPEAT 361
  58.     (SETQ I   (1+ I)
  59.           I1  (* I (/ PI 180))
  60.           P1  (LIST (* A (* 16 (* (SIN I1) (SIN I1) (SIN I1))))
  61.                     (* A
  62.                        (+ (* 13 (COS I1))
  63.                           (* -5 (COS (* 2 I1)))
  64.                           (* -2 (COS (* 3 I1)))
  65.                           (* -1 (COS (* 4 I1)))
  66.                        )
  67.                     )
  68.               )
  69.           LST (CONS P1 LST)
  70.     )
  71.   )
  72. (vl-remove 'nil lst)
  73. )
两种公式  拿去装逼
做不了动画
这个炫酷  发表于 2023-8-22 15:07
发表于 2023-8-23 22:14:28 | 显示全部楼层
liuhe 发表于 2023-8-22 13:38
两种公式  拿去装逼
做不了动画
大佬搞的真酷
发表于 2023-8-22 15:59:22 | 显示全部楼层
真实情况是这样的: 妹子点了几下, 发觉打不开, 于是便扔进了回收站.
发表于 2023-8-22 11:02:27 | 显示全部楼层
看看什么效果
发表于 2023-8-22 11:04:49 | 显示全部楼层
十年前,我学lisp写的第二个程序就是这个
发表于 2023-8-22 11:05:12 | 显示全部楼层
66666666666
发表于 2023-8-22 11:17:18 | 显示全部楼层
666666666666666666
发表于 2023-8-22 12:01:35 | 显示全部楼层
厉害厉害厉害
发表于 2023-8-22 12:52:45 | 显示全部楼层
关键妹纸不用CAD!
发表于 2023-8-22 13:50:51 | 显示全部楼层
看看什么效果!!!!!
发表于 2023-8-22 14:31:19 | 显示全部楼层
看看什么效果
GMT+8, 2025-5-24 11:47 , Processed in 0.175412 second(s), 30 queries , Gzip On.
