这是个老程序,来自于:http://bbs.mjtd.com/forum.php?mod=viewthread&tid=109829&highlight=%CD%BC%B2%E3%C8%AB&_dsign=85ce996e
这个程序本身写得不错,但是有个缺点,就是全部解锁还是淡显;如果RE一下就可以变亮;但是恢复锁定还是亮显,明显缺少了一个regon的刷新动作,我这里稍微改一下就可以实现
 - ;;35-图层3个全部3X,图层再次恢复4X
- (Defun STB(TAB / snl sll)
- (SetQ snl '()sll (TblNext TAB T))
- (While (SetQ snl (Cons (Cdr (Assoc 2 sll)) snl)sll (TblNext TAB nil)))
- (vl-sort snl '<))
- (defun c:3X();图层全开、解锁、解冻
- (princ "\n****图层全开、解锁、解冻,3个全部,程序加了自动RE****")
- (foreach x (setq *laystatus(mapcar'(lambda(x)(entget(TBLOBJNAME"layer"x)))(stb"layer")))
- (entmod(subst(cons 62 (abs(cdr(assoc 62 x))))(assoc 62 x)(subst'(70 . 0)(assoc 70 x)x))))(command-S "regen" ));天神,,,加入regen刷新命令
- (defun c:4X();;恢复图层
- (princ "\n****恢复图层,恢复全开之前状态****")
- (foreach x *laystatus
- (entmod x))
- (setq *laystatus nil)(command-S "regen" ));天神,,,加入regen刷新命令
