查看: 3524|回复: 14
[经验] 分享一个沿着线切割图纸的LSP
发表于 2023-9-13 15:17:08 | 显示全部楼层 |阅读模式
有时候删除图纸一部分很麻烦,使用这个相对简单,不过填充无法删除,但也很爽快了。
下面是程序,有几个命令,奈何我只是个搬运工,使用“EXTRIM”命令,选择自己画好的切割线,然后鼠标右键选择删除的方向。
(defun c:exb2c ( / colect_entdata store_entdata colect_modified_entdata sel_mod_ents
                  hig osm c1 c2 p ss entdata )
(defun colect_entdata ( / ss i ent entdata )
   (setq ss (ssget "_X"))
   (setq i -1)
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq entdata (cons (entget ent) entdata))
   entdata
(defun store_entdata nil
   (setq entdata (colect_entdata))
;;; Modify entities ;;;
(defun colect_modified_entdata ( / ss i ent entdatachk entdatamod )
   (setq i -1)
     (setq entdatachk (cons (entget ent) entdatachk))
   (foreach data entdatachk
     (if (not (vl-some '(lambda ( x ) (equal x data 1e-6)) entdata))
       (setq entdatamod (cons data entdatamod))
   entdatamod
(defun sel_mod_ents nil
   (setq ss (ssadd))
   (foreach data (colect_modified_entdata)
     (ssadd (cdr (assoc -1 data)) ss)
;;; Main function ;;;
(vl-load-com)
(setq hig (getvar 'highlight))
(setq osm (getvar 'osmode))
(setvar 'osmode 0)
(if (not (or etrim (not (vl-catch-all-error-p (vl-catch-all-apply 'load (list (findfile "extrim.lsp")))))))
     (alert "\nExpress Tool EXTRIM not available - quitting...")
     (exit)
(setq c1 (car (entsel "\nPick first curve")))
(while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c1)))
   (prompt "\nPicked entity isn't curve entity. Try again...")
(setq c2 (car (entsel "\nPick second curve")))
(while (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getstartparam (list c2)))
(initget 1)
(setq p (getpoint "\nPick or specify point between 2 prviously picked curves where do you want extrim to be processed : "))
(store_entdata)
(etrim c1 p)
(sel_mod_ents)
(command "_.copybase" '(0.0 0.0 0.0) ss "")
(command "_.undo" "3")
(etrim c2 p)
(command "_.pasteclip" '(0.0 0.0 0.0))
(setvar 'osmode osm)
(setvar 'highlight hig)
发表于 2023-9-22 16:51:22 | 显示全部楼层
汉化一下不更好吗?
(defun c:exb2c( / colect_entdata store_entdata colect_modified_entdata sel_mod_ents
   (setq i -1)
   entdata
   (setq i -1)
   entdatamod
   (setq ss (ssadd))
(vl-load-com)
(setvar 'osmode 0)
     (alert "\n快速修剪工具不可用,退出...")
     (exit)
(setq c1 (car (entsel "\n选择第一条线")))
   (prompt "\n选取的曲线属性不正确,重选...")
(setq c2 (car (entsel "\n选择第二条线")))
(initget 1)
(setq p (getpoint "\n在两条先前拾取的曲线之间拾取或指定要处理外部的点 : "))
(store_entdata)
(etrim c1 p)
(sel_mod_ents)
(etrim c2 p)
 楼主| 发表于 2023-9-13 18:36:32 | 显示全部楼层
ynhh 发表于 2023-9-13 17:00
谢谢分享
行业不同
要有个示范动画就好理解了
好的,有时间做个动画
 楼主| 发表于 2023-11-10 15:35:20 | 显示全部楼层
kexiya123 发表于 2023-9-22 17:23
不能用啊,看看能不能不用什么ET
忘了说了,调用命令是EXTRIM
发表于 2023-9-13 17:00:09 | 显示全部楼层
谢谢分享
行业不同
要有个示范动画就好理解了
无法试,感觉差一个文件
extrim.lsp
发表于 2023-9-13 20:47:08 | 显示全部楼层
etrim,子函数没有吧?
发表于 2023-9-13 23:19:43 | 显示全部楼层
错误了吧,用不了
发表于 2023-9-14 16:24:22 | 显示全部楼层
可以使用,需要ET扩展工具
发表于 2023-9-14 19:07:02 | 显示全部楼层
多谢分享。可惜我用不了。
发表于 2023-9-15 09:24:48 | 显示全部楼层
这个不错哦,安装了et工具就能用了。非常不错,谢谢楼主分享。
发表于 2023-9-15 18:14:20 | 显示全部楼层
测试之后发现很方便,可以省去匡选的动作,更加有效律的修剪。
发表于 2023-9-17 15:24:15 来自手机 | 显示全部楼层
非常感谢楼主分享好源码
GMT+8, 2025-7-3 04:39 , Processed in 0.320435 second(s), 27 queries , Gzip On.
