查看: 1089|回复: 1
【K:ChgSSgetOrder】选择集对象置顶OR置底
发表于 2023-9-14 16:49:26 | 显示全部楼层 |阅读模式
分享一个函数:
  1. ;CorLst:颜色列表
  2. ;LayLst:图层列表
  3. ;Type:置顶"F"或置底"B"
  4. (defun K:ChgSSgetOrder (CorLst LayLst Type / TmpLay CorLayLst SS)
  5.   (if CorLst
  6.     (progn
  7.         (setq CorLayLst Nil)
  8.         (while (setq TmpLay (tblnext "LAYER" (null TmpLay)))
  9.           (if (member (cdr (assoc 62 TmpLay)) CorLst)
  10.             (setq CorLayLst (cons (cdr (assoc 2 TmpLay)) CorLayLst))
  11.           )
  12.         )
  13.     )
  14.   );获取符合颜色列表的图层
  15.   (if (or CorLst LayLst)
  16.     (progn
  17.       (setq SS
  18.         (ssget "X"
  19.           (append
  20.             (if (eq 1 (getvar "cvport")) (list (cons 410 (getvar "ctab"))) (list (cons 410 "Model")));模型OR布局
  21.             (list (cons -4 "<OR"))
  22.               (if CorLst
  23.                 (append
  24.
  25.                   (list (cons -4 "<OR"))
  26.                   (mapcar '(lambda (x) (cons 62 x)) CorLst)
  27.                   (list (cons -4 "OR>"))
  28.                 )
  29.               )
  30.               (if LayLst
  31.                 (append
  32.                   (list (cons -4 "<OR"))
  33.                   (mapcar '(lambda (x) (cons 8 x)) LayLst)
  34.                   (list (cons -4 "OR>"))
  35.                 )
  36.               )
  37.               (if CorLayLst
  38.                   (append
  39.                     (list (cons -4 "<and"))
  40.                       (list (cons 62 256));随层
  41.                       (list (cons -4 "<OR"))
  42.                       (mapcar '(lambda (x) (cons 8 x)) CorLayLst)
  43.                       (list (cons -4 "OR>"))
  44.                     (list (cons -4 "and>"))
  45.                   )
  46.               )
  47.             (list (cons -4 "OR>"))
  48.           )
  49.         )
  50.       )
  51.       (command "_DrawOrder" SS "" Type)
  52.     )
  53.   )
  54.   (princ)
  55. )
;用法参考
  1. (K:ChgSSgetOrder
  2.     '(8 250 251 252 253 254 255);灰色对象
  3.     '("LayNam1" "LayNam2");图层列表:不知道为什么不能包含"0"图层
  4.     "B" ;置底
  5. )
发表于 2023-9-14 20:56:39 | 显示全部楼层
感谢大佬分享
GMT+8, 2025-5-24 12:12 , Processed in 0.152588 second(s), 22 queries , Gzip On.
