查看: 1140|回复: 5
[提问] 如何获取批量给字符串变量所赋的值?
发表于 2023-9-15 20:53:21 | 显示全部楼层 |阅读模式
  1. (defun C:GG(/)
  2. ;; 批量给字符串变量赋值
  3. (setq n 0)
  4. (repeat 8
  5. (setq n (1+ n))
  6. (set (read (strcat "lst_" (itoa n))) (strcat "A_" (itoa n)))
  7. )
  8. ;; 如何批量获取变量的值???
  9. (setq n 0)
  10. (repeat 8
  11. (setq n (1+ n))
  12. (princ "\n")
  13. (princ (read (strcat "lst_" (itoa n))))
  14. )
  15. (princ)
  16. )
 楼主| 发表于 2023-9-15 21:07:26 | 显示全部楼层
问题已解决,不好意思
  1. (defun C:GG(/)
  2. ;; 批量给字符串变量赋值
  3. (setq n 0)
  4. (repeat 8
  5. (setq n (1+ n))
  6. (set (read (strcat "lst_" (itoa n))) (strcat "a_" (itoa n)))
  7. )
  8. ;; 批量获取变量值
  9. (setq n 0)
  10. (repeat 8
  11. (setq n (1+ n))
  12. (setq str(vl-symbol-value (read (strcat "lst_" (itoa n)))))
  13. (princ "\n")
  14. (princ str)
  15. )
  16. (princ)
  17. )
发表于 2023-9-15 22:50:57 | 显示全部楼层
(eval(read (strcat "lst_" (itoa n)))) eval也可以
 楼主| 发表于 2023-9-15 22:56:56 来自手机 | 显示全部楼层
感谢大佬解惑
发表于 2023-9-15 23:41:11 | 显示全部楼层
  1. (defun c:tt (/)
  2.   "批量给字符串变量赋值"
  3.   (setq        n   0
  4.         lst '()
  5.   )
  6.   (repeat 8
  7.     (setq n   (1+ n)
  8.           a   (strcat "lst_" (itoa n))
  9.           b   (strcat "a_" (itoa n))
  10.           lst (cons a lst)
  11.     )
  12.     (set (read a) b)
  13.   )
  14.   "批量获取变量值"
  15.   (setq lst (reverse lst))
  16.   (princ (mapcar '(lambda (x) (eval (read x))) lst))
  17.   (princ)
  18. )
 楼主| 发表于 2023-9-16 07:50:24 来自手机 | 显示全部楼层
xyp1964 发表于 2023-9-15 23:41
谢谢,了解了
GMT+8, 2025-5-14 07:58 , Processed in 0.167002 second(s), 24 queries , Gzip On.
