查看: 1498|回复: 9
[提问] 求输入tt,点击图块,把图块的数值型 A 的值 复制到粘贴板
发表于 2023-9-18 14:45:14 | 显示全部楼层 |阅读模式
发表于 2023-9-18 14:58:25 | 显示全部楼层
发表于 2023-9-18 15:14:52 | 显示全部楼层
  1. (Defun lm-get-attribute (ty sx / lstattrs lstvar tagstring textstring vn0)
  2.   (setq vn (vlax-ename->vla-object ty))
  3.   (setq lstVar (vla-getattributes vn))
  4.   (setq lstAttrs (vlax-safeArray->list (vlax-variant-value lstVar)))
  5.   (setq TextString nil)
  6.   (foreach attr        lstAttrs
  7.     (setq TagString (vla-get-TagString attr))
  8.     (if        (equal TagString sx)        ;此处为你想要的元素
  9.       (setq TextString (vla-get-TextString attr))
  10.     )
  11.   )
  12.         TextString
  13. )
  14. (defun set-clip-string (str / html result)
  15.     (and (= (type str) 'str)
  16.          (setq html (vlax-create-object "htmlfile"))
  17.          (setq result (vlax-invoke (vlax-get (vlax-get html 'parentwindow) 'clipboarddata ) 'setdata "text" str))
  18.          (vlax-release-object html)
  19.     )
  20. )
  21. (set-clip-string (lm-get-attribute(car(entsel"\n选择属性块:")) "A"))
发表于 2023-9-18 17:29:47 | 显示全部楼层
lm-get-attribute 里边 foreach宜用vl-some
  1. (defun getattrib(blk tag)
  2.   (if(and(equal(VL-CATCH-ALL-APPLY(function vlax-get-property)
  3.                  (list(setq blk(if(=(type blk)'ename)(vlax-ename->vla-object blk)blk))'HasAttributes)):vlax-true)
  4.       (=(type tag)'str)
  5.          (setq tag(strcase tag)))
  6.     (vl-some(function(lambda(a)(if(=(strcase(vlax-get-property a"TagString"))tag)a)))
  7.             (vlax-safearray->list(vlax-variant-value(vlax-invoke-method blk'getattributes))))))
  8. (set-clip-string(VL-CATCH-ALL-APPLY(function vlax-get-property)(list(getattrib(car(entsel""))"A")"TextString")))
发表于 2023-9-18 19:04:09 | 显示全部楼层
这个好 换了之后简洁好多
发表于 2023-9-18 22:12:26 | 显示全部楼层
感谢大佬分享~
发表于 2023-9-19 08:28:23 | 显示全部楼层
怎么能把程序变成可以直接运行的程序呢,用一个命令
 楼主| 发表于 2023-9-19 14:25:32 | 显示全部楼层
我也不清楚,你问问大佬,你是做啥行业的兄弟
 楼主| 发表于 2023-9-19 14:26:40 | 显示全部楼层
 楼主| 发表于 2023-9-19 14:27:48 | 显示全部楼层
谢谢大佬分享
GMT+8, 2025-5-14 08:35 , Processed in 0.186189 second(s), 26 queries , Gzip On.
