查看: 2081|回复: 6
以前lisp用的好好的,现在怎么出现错误?
发表于 2023-10-4 13:57:30 | 显示全部楼层 |阅读模式
之前在明经上下载的,一直用的好好的,上个月好好的就不能用了,出现错误,请问大家怎么回事?谢谢。。。
;;;             《相同刷》v2.2 =========================================================
;;; 功能:
;;;      <文字相同> 如源对象为文字,   则目标文字、天正文字内容相同(不支持天正多行, 点选程序刷属性和块内文字)
;;;      <半径相同>如源对象为圆或弧,则目标圆或圆弧刷成半径相同
;;;      <块相同> 如源对象为块,          则目标块刷成源块一样
;;;      <线宽相同>如源对象为多段线,则目标线、圆、圆弧、多段线等刷成同线宽
;;;      <线长相同>如源对象为直线,   则目标直线刷成长度相等
;;;      <尺寸相同> 如源对象为尺寸,  则目标尺寸刷成数值相等
;;;      <特性匹配> 如源对象为填充,  则目标特性匹配
;;;      <椭圆相同 > 如源对象为椭圆, 则目标椭圆相同
;;; 使用:命令:mm,选择一个源对象,程序自动判断,再选择集
(defun c:mm (/ #errxts $orr buk en1 ent i n name name1 obj p p1 p2 r snap ss tp ty uu)
  (defun #errxts (s)                       ; 出错处理程序
    (redraw name 4)
    (setvar "nomutt" 0)
    (setvar "PICKBOX" buk)
    (setvar "osmode" snap)
    (command ".UNDO" "E")
    (setq *error* $orr)
  (defun emod (ent i n)
    (subst (cons i n)(assoc i ent)ent)
  (setq $orr *error*)
  (setq *error* #errxts)
  (vl-load-com)                               ; 主程序开始
  (setvar "cmdecho" 0)
  (command ".UNDO" "BE")
  (setq snap (getvar "osmode"))
  (setvar "osmode" 0)
  (setq buk (getvar "PICKBOX"))
  (setvar "PEDITACCEPT" 1)               ; 下面程序选择合适的源对象,如没选到重新选
  (while (not (and
                (setq name1 (nentsel "\n选择源对象:"))
                (setq name (car name1))
                (setq ent (entget name))
                (setq ty (cdr (assoc 0 ent)))
                (member ty (list "TEXT" "MTEXT" "LWPOLYLINE" "CIRCLE" "INSERT" "LINE" "ARC" "HATCH" "DIMENSION" "ATTRIB" "TCH_ARROW" "TCH_TEXT" "TCH_DRAWINGNAME" "TCH_MULTILEADER" "TCH_ELEVATION" "ELLIPSE" ))
    (if (= 52 (getvar "errno"))(vl-exit-with-error ""))
  )                                       ; 下面程序加了一个判断,如果源对象选择的是块,且不是属性或者块内文字,则认为选择的是块
  (if (and (not (member ty (list "TEXT" "MTEXT" "ATTRIB")))
        (= (type (car (last name1))) 'ename)
        (member (cdr (assoc 0 (entget (car (last name1))))) '("INSERT" "DIMENSION")))
    (setq name (car (last name1))  ent (entget name)  ty (cdr (assoc 0 ent)))
  (redraw name 3)
  (setvar "nomutt" 1)
  (setvar "PICKBOX" (fix (+ 1 (* 1.2 buk))))
  (cond                                       ; 1、 如果源对象是文字、天正文字或者块内文字或者属性,则执行。。。
    ((member ty (list "TEXT" "MTEXT" "ATTRIB" "TCH_TEXT" "TCH_ARROW" "TCH_DRAWINGNAME" "TCH_MULTILEADER" "TCH_ELEVATION"))
      (setq uu (cdr (assoc 1 ent)))
      (princ (strcat "\n <文字相同>  T = " "\"" uu "\"  (点选刷属性或块内文字)"))
      (while t
        (setq ss (ssget ":S" '((0 . "TEXT,MTEXT,INSERT,TCH_ARROW,TCH_TEXT,TCH_DRAWINGNAME,TCH_MULTILEADER,TCH_ELEVATION"))))
        (repeat (setq i (sslength ss))
          (setq ent (entget (setq en1 (ssname ss (setq i (1- i)))))tp (cdr (assoc 0 ent)))
          (cond
            ((member tp (list "TCH_TEXT" "TCH_ELEVATION" "TCH_ARROW"))
              (vlax-put-property (vlax-ename->vla-object en1) 'text uu))
            ((= tp "TCH_DRAWINGNAME")
              (vlax-put-property (vlax-ename->vla-object en1) 'nametext uu))
            ((= tp "TCH_MULTILEADER")
              (vlax-put-property (vlax-ename->vla-object en1) 'uptext uu))
          (if (= (caar (setq name1 (ssnamex ss 0))) 1) ; 分两情况:第一种,目标文字是单选块内文字或者属性
              (setq ent (ssname ss 0)en1 (car (nentselp (trans (cadr (last (car name1))) 0 1)))
                    tp (cdr (assoc 0 (entget en1))))
              (if (member tp (list "TEXT" "MTEXT" "ATTRIB"))
                  (vla-put-textstring (vlax-ename->vla-object en1) uu)
                  (entupd en1)  (entupd ent))
            (if (member tp '("TEXT" "MTEXT")) ; 第一种,目标文字多选文字
              (entmod (emod ent 1 uu))
    ((member ty '("CIRCLE" "ARC"))     ; 3、 如果源对象是圆,则循环更新目标圆的直径
      (setq uu (cdr (assoc 40 ent)))
      (princ (strcat "\n <半径相同>  R = " (rtos uu 2 2)))
      (while (setq ss (ssget ":S" '((0 . "CIRCLE,ARC"))))
          (setq ent (entget (ssname ss (setq i (1- i)))))
          (entmod (emod ent 40 uu))
    ((member ty '("INSERT" "ELLIPSE")) ; 4、 如果源对象是块,则拷贝源块到目标块的位置,删除目标块
      (princ (strcat " \n <" (cadr (assoc ty '(("INSERT" "块") ("ELLIPSE" "椭圆")))) "相同>")); 5、 椭圆同上
      (setq uu (cdr (assoc 10 ent)) name1 (cdr (car ent)))
      (while (setq ss (ssget ":S" (list (cons 0 ty))))
          (command "COPY" name "" uu (cdr (assoc 10 ent)))
        (if (ssmemb name1 ss) (ssdel name1 ss))
        (command "ERASE" ss "")
    ((= ty "LWPOLYLINE")               ; 6、 如果源对象是多义线,则转化目标对象的线宽
      (if (not (setq uu (cdr (assoc 43 ent))))(setq uu (cdr (assoc 40 ent))))
      (princ (strcat "\n <线宽相同>   W = " (rtos uu 2 2)))
      (while (setq ss (ssget ":S" '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE,CIRCLE"))))
          (setq name1 (ssname ss (setq i (1- i)))tp (cdr (assoc 0 (setq ent (entget name1)))))
          (cond
            ((member tp '("LINE" "ARC"))
              (command "pedit" name1 "w" uu "x"))
            ((member tp '("POLYLINE" "LWPOLYLINE"))
            ((= tp "CIRCLE")
              (command "donut" (- (* (cdr (assoc 40 ent)) 2) uu) (+ (* (cdr (assoc 40 ent)) 2) uu) (cdr (assoc 10 ent)) "")
              (entdel name1)
    ((= ty "LINE")                       ; 7、如果源对象是直线,则目标直线线长相同
      (setq uu (* 0.5 (distance (cdr (assoc 10 ent)) (cdr (assoc 11 ent)))))
      (princ (strcat "\n <线长相同>  L = " (rtos uu 2 2)))
      (while (setq ss (ssget ":S" '((0 . "LINE"))))
          (setq ent (entget (ssname ss (setq i (1- i))))p1 (cdr (assoc 10 ent))
                p2 (cdr (assoc 11 ent))        r (angle p1 p2)
                p (polar p1 r (* 0.5 (distance p1 p2))))
          (entmod (emod (emod ent 10 (polar p r (* -1 uu))) 11 (polar p r uu)))
    ((= ty "DIMENSION")                       ; 8、如果源对象是尺寸,则尺寸数值相同
      (setq obj (vlax-ename->vla-object name)  uu (vla-get-textoverride obj))
      (if (or(= uu "")(wcmatch uu "*<>*"))
        (setq uu (rtos (vla-get-measurement obj) 2 (vla-get-toleranceprecision obj)))
      (princ (strcat "\n <尺寸相同>  T = " uu))
      (while (setq ss (ssget ":S" '((0 . "DIMENSION"))))
    ((member ty '("HATCH"))               ; 9、如果源对象是填充,则调用特性匹配命令
      (princ "\n <特性匹配>")
      (while (setq ss (ssget ":S" '((0 . "HATCH"))))
        (command "matchprop" name ss "")
        (princ "\n <特性匹配>")
  (redraw name 4)
  (setvar "nomutt" 0)
  (setq *error* $orr)
发表于 2023-10-4 15:30:00 | 显示全部楼层
按照提示把自定义ERROR中的COMMAND 改成 COMMAND-S
发表于 2023-10-4 16:36:29 | 显示全部楼层
你用了高版本的CAD,所以出现这个错误,把所有command替换成(if command-s command-s command)应该就可以了
 楼主| 发表于 2023-10-4 19:47:26 | 显示全部楼层
感谢回复 ,好像不行,我用的是CAD2023,之前CAD2023用一直有用的,突然就没用。怪事!
 楼主| 发表于 2023-10-4 19:59:19 | 显示全部楼层
感谢回复,好像不行,我用的是CAD2023,之前CAD2023用一直有用的,突然就没用。怪事!
发表于 2023-10-8 09:34:02 | 显示全部楼层
cad版本太高了
 楼主| 发表于 2023-10-10 14:17:32 | 显示全部楼层
请问,有什么办法能调整一下吗?
GMT+8, 2025-6-17 04:24 , Processed in 0.142150 second(s), 23 queries , Gzip On.
