查看: 2763|回复: 6
急,刚用(entmod(subst ....))更新过的表,再assoc引用结果没更新?
发表于 2002-8-20 18:17:00 | 显示全部楼层 |阅读模式
发表于 2002-8-20 18:35:00 | 显示全部楼层
程序贴一段,看看
 楼主| 发表于 2002-8-20 20:02:00 | 显示全部楼层
贴了,帮忙看看..
;;; funtion 2
(defun th()
  (setq txtent(car (entsel "\n    选择标高文字: ")))
  (setq txtdata(entget txtent))
  (setq txtid(cdr (assoc 10 txtdata)))
  (setq txth(cdr (assoc 40 txtdata)))
  (setq txtm(cdr (assoc 1 txtdata)))
  (setq txt(cons 1 (strcat "(" "H" txtm ")")))
  (entmod (subst txt (assoc 1 txtdata) txtdata))  ;;;就是这段更新了txtdata表后,textbox这个表,类容是更新前的
  (setq txtidx(car txtid)
        txtidy(cadr txtid)
  (setq tx(+ (caadr (textbox txtdata)) txtidx))
  (setq ty(+ txtidy (/ txth 2)))
  (setq txy(strcat (rtos tx 2 2) "," (rtos ty 2 2)))
;;; end funtion 2
发表于 2002-8-21 08:18:00 | 显示全部楼层
因为实体更新后,变量txtdate并没有更新。
这句改为:
(entmod (setq txtdate (subst txt (assoc 1 txtdata) txtdata)))
发表于 2002-8-21 08:33:00 | 显示全部楼层
看看...
看看..
;;; funtion 2
(defun TH ()
  (setq TXTENT (car (entsel "\n择标高文字: ")))
  (setq TXTDATA (entget TXTENT))
  (setq TXTID (cdr (assoc 10 TXTDATA)))
  (setq TXTH (cdr (assoc 40 TXTDATA)))
  (setq TXTM (cdr (assoc 1 TXTDATA)))
  (setq TXT (cons 1 (strcat "(" "H" TXTM ")")))
;(entmod (subst TXT (assoc 1 TXTDATA) TXTDATA))
  (entmod (setq TXTDATA (subst TXT (assoc 1 TXTDATA) TXTDATA)))
;;;就是这段更新了txtdata表后,textbox这个表,类容是更新的
  (setq        TXTIDX (car TXTID)
        TXTIDY (cadr TXTID)
  (setq TX (+ (caadr (textbox TXTDATA)) TXTIDX))
  (setq TY (+ TXTIDY (/ TXTH 2)))
  (setq TXY (strcat (rtos TX 2 2) "," (rtos TY 2 2)))
;;; end funtion 2
 楼主| 发表于 2002-8-21 12:50:00 | 显示全部楼层
感谢龙龙和ll_j !!
发表于 2023-6-13 08:08:05 | 显示全部楼层
这句改为:
(entmod (setq txtdate (subst txt (asso ...
多谢指导
GMT+8, 2025-2-22 16:55 , Processed in 0.174427 second(s), 25 queries , Gzip On.
