查看: 1531|回复: 7
[提问] 求帮助单独选择改批量选择如何修改??????
发表于 2023-10-13 18:13:53 | 显示全部楼层 |阅读模式
2明经币
以下为明经源码,感谢原作者,有个问题,执行命令需要一个个点选多段线框才能打印,能否改为 一次性批量框选多段线框直接打印
尝试改了下:S不行,应该不是单纯改这里就行的,实际情况是不能用的,请大神帮忙看看如何改
  1. ;;; 快速打印程序,选一堆矩图框,再批量打印
  2. (defun c:ksdy (/ ent fx i maxpoint maxx0 maxy0 minpoint minx0 miny0 os pmax pmin ptlist ss sstk)
  3.   (vl-load-com)
  4.   (setvar "cmdecho" 0) (setq os (getvar "osmode")   ss (ssadd)    sstk (ssadd)  )
  5.   (princ "\n 请选取矩形图框:")
  6.   (while (setq ss (ssget ":S" (list '(0 . "LWPOLYLINE") '(90 . 4))))
  7.     ;(while (setq ss (ssget (list '(0 . "LWPOLYLINE") '(90 . 4))))
  8.     (setq ent (ssname ss 0))
  9.     (vla-getboundingbox (vlax-ename->vla-object ent) 'minpoint 'maxpoint)
  10.     (setq pmax (vlax-safearray->list maxpoint)  pmin (vlax-safearray->list minpoint)
  11.           minx0 (car pmin)  miny0 (cadr pmin)   maxx0 (car pmax)  maxy0 (cadr pmax))
  12.     (if (>= (- maxx0 minx0) (- maxy0 miny0))   (setq fx "L")      (setq fx "P") )
  13.         ;;;生成矩形的对角线并将对角线加入选择集sstk
  14.     (entmake (list '(0 . "LINE") (cons 62 6) (cons 10 (list minx0 miny0 0)) (cons 11 (list maxx0 maxy0 0))))
  15.     (setq sstk (ssadd (entlast) sstk))
  16.     (entmake (list '(0 . "LINE") (cons 62 6) (cons 10 (list minx0 maxy0 0)) (cons 11 (list maxx0 miny0 0))))
  17.     (setq sstk (ssadd (entlast) sstk))
  18.         ;;;生成矩形的对角线并将对角线加入选择集sstk结束
  19.     (setq ptlist (cons (list pmin pmax fx) ptlist))
  20.   )
  21.   (initget "Y N ")
  22.   (if (/= (getpoint (strcat "\n 确定批量打印?[确认(Y)/退出(N)]:<Y> ")) "N")
  23.     (progn
  24.       (command "erase" sstk "")
  25.       (repeat (setq i (length ptlist))
  26.         (setq ent (nth (setq i (1- i)) ptlist )  pmin (car ent) pmax (cadr ent) fx (last ent))
  27.         (command "_.PLOT" "Y" "" "pdfFactory Pro" "A3" "M" fx "N" "W" pmin pmax "F" "C" "Y" "monochrome.ctb" "Y" "N" "N" "N" "Y")
  28.         (princ (strcat "\n 程序正在打印第" (itoa (- (length ptlist) i)) "张>>>>>>>> "))
  29.       )
  30.     )
  31.     (command "erase" sstk "")
  32.   )
  33.   (setvar "osmode" os)                 ; 恢复捕捉模式
  34.   (princ)
  35. )
最佳答案
查看完整内容
(defun c:ksdy () (vl-load-com) (setvar "cmdecho" 0) (princ "\n请选取矩形图框: ") (if (setq ss (ssget (list '(0 . "LWPOLYLINE") '(90 . 4)))) (progn (xyp-MkLaCo "fzx" 1) (setq lst (xyp-Sort-Plist (xyp-Sort ss "1" "Y-max") 1) i 1 s0 (entlast) ptn (mapcar '(lambda (x) (setq p1 (xyp-9pt x 1) p9 (xyp-9pt x 9) s1 (xyp-Line p1 p9) ...
发表于 2023-10-13 18:13:54 | 显示全部楼层
(defun c:ksdy ()
  (vl-load-com)
            i         1
            s0         (entlast)
                                  p9 (xyp-9pt x 9)
                                  s1 (xyp-Line p1 p9)
                                  s2 (xyp-Line (xyp-9pt x 3) (xyp-9pt x 7))
                                  s3 (xyp-Text 5 (xyp-9pt x 5) (itoa i))
                                  s3 (xyp-SubUpd s3 40 6000)
                                  i  (1+ i)
                                  fx (if (> (- (car p9) (car p1)) (- (cadr p9) (cadr p1)))
                                       "L"
                                       "P"
                            (list p1 p9 fx)
                         (mapcar 'cdr lst)
            sstk (xyp-SsEntnext s0)
            i         -1
            kw         (Ukword 1 "Y N" "[批量打印: 确认(Y)/退出(N)]" kw)
      (if (= kw "Y")
          (foreach aa ptn
            (setq p1 (car aa)
                  p9 (cadr aa)
                  fx (last aa)
            (command "_.PLOT" "Y" "" "pdfFactory Pro" "A3" "M" fx "N" "W" p1 p9        "F" "C"        "Y" "monochrome.ctb" "Y" "N" "N" "N" "Y")
                           (itoa (- (length ptn) i))
                           "张>>>>>>>> "
 楼主| 发表于 2023-10-13 21:17:28 | 显示全部楼层
有木有人帮忙解答下
发表于 2023-10-14 10:48:17 | 显示全部楼层
;; ksdy(快速打印)
(defun c:ksdy (/ s1 fx i maxx0 maxy0 minx0 miny0 os p1 p9 ptn ss sstk)
  (vl-load-com)
            sstk (ssadd)
            ptn  '()
            i  -1
      (while (setq s1 (ssname ss (setq i (1+ i))))
        (vla-getboundingbox (vlax-ename->vla-object s1) 'p1 'p9)
        (setq p9 (vlax-safearray->list p9)
              p1 (vlax-safearray->list p1)
              minx0 (car p1)
              miny0 (cadr p1)
              maxx0 (car p9)
              maxy0 (cadr p9)
              fx (if (>= (- maxx0 minx0) (- maxy0 miny0)) "L" "P")
              ptn (cons (list p1 p9 fx) ptn)
        (entmake (list '(0 . "LINE")(cons 62 6)(cons 10 p1)(cons 11 p9)))
        (entmake (list '(0 . "LINE")(cons 62 6)(cons 10 (list minx0 maxy0 0))(cons 11 (list maxx0 miny0 0))))
      (initget "Y N ")
      (if (= (getpoint (strcat "\n 确定批量打印?[确认(Y)/退出(N)]:<Y> ")) "Y" )
          (repeat (setq i (length ptn))
            (setq aa (nth (setq i (1- i)) ptn)
                  p1 (car aa)
                  p9 (cadr aa)
                  fx (last aa)
            (princ (strcat "\n 程序正在打印第" (itoa (- (length ptn) i)) "张>>>>>>>> "))
 楼主| 发表于 2023-10-14 11:56:10 | 显示全部楼层
;; ksdy(快速打印)
(defun c:ksdy (/ s1 fx i maxx0 maxy0 mi ...
感谢院长,还有个小小问题,看能不能帮忙解决下
1、图纸打印出来顺序能加个判断么,因为是框选,所以无论那种选择方式能保证打印图纸大致是左到右,上到下方式呢
 楼主| 发表于 2023-10-14 12:09:49 | 显示全部楼层
;; ksdy(快速打印)
不太懂代码,看里面好像是有方向判断,但是目前打印出来顺序是乱的,我琢磨了下没搞出来,
 楼主| 发表于 2023-10-14 15:17:32 | 显示全部楼层
xyp1964 发表于 2023-10-14 14:40
(defun c:ksdy ()
  (vl-load-com)
院长是不是缺少函数啊,提示no function definition: XYP-MKLACO
 楼主| 发表于 2023-10-14 21:45:50 | 显示全部楼层
(defun c:ksdy ()
  (vl-load-com)
后面这个没法使用了,是不是有问题呢,缺少函数,麻烦有空看下哈
GMT+8, 2025-6-4 00:07 , Processed in 0.201287 second(s), 24 queries , Gzip On.
